I got this after changing resolution of my computer. After it I install kernel 5.14 because my screen is tearing/glitch.
manjaro.moson.eu
is a mirror (a mirror is a server that provides an exact copy of data from another server).
This will cause more problems than solutions because 5.14
is EOL. Switch to a supported kernel:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
sudo mhwd-kernel -i linux515
Then reboot into 5.15 (Press Esc during boot to get into grub menu and boot with 5.15
Double check your running kernel is not 5.14
then remove it:
uname -r
sudo mhwd-kernel -r linux514
Oke thank… I got it
