after one of the last Stable updates ( the small one that included the new version of gdm ) I restarted and after seeing display output during early boot, I got stranded in a black screen without a cursor.
After trying several different things I switched my desktops GPU, an AMD RX550, with a different GPU an AMD 5700XT. With the 5700 I was able to boot into Manjaro without problems, switching them back resulted in the issue I just described before.
In the end it turned out that I can use my RX550 only if I apply the amdgpu.dc=0 parameter to GRUB_CMDLINE_LINUX_DEFAULT.
I was however unable to find out why I do need that now all of a sudden and what exactly it does.
If anyone can point me in the right direction or give an explanation I would be grateful!
I did not switch kernels and neither updated it at first. I updated exactly two packages gdm and another one. After a reboot I was seeing the black screen. After I booted with the working 5700 I did another update that provided new versions of the 5.8 and 5.4 kernels. While I am running the 5.8 kernel I also tested that the same issue persists in kernel 5.4,
Edit: Since I saw the 5.9 Kernel is out I installed and tried that one, the problem unfortunately persists.
Does seem a bit unlikely to me why such an ancient bug should haunt me now. Also people there describe systems freezing, but my computer runs just fine only outputting no signal. When I start without amdgpu.dc=0, I can still ssh into my machine.
VGA cable? What do you mean? I do not have a vga port!
