Hello
Today i encountered a strange issue about install/uninstall softwares, which could not be addressed by Google. Before i show you what it is, please let me introduce my env:
$uname -a
Linux myhost 5.4.169-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:08:59 UTC 2021 x86_64 GNU/Linux
it runs under VirtualBox6.1
And one day ago i upgraded by command sudo pacman -Syu
, then i run sudo pacman -Sc
to remove pacman cache packages, clean system by BleachBit.
Then i found dbeaver
is lost, Im sure i never uninstall it.
I reinstalled it with sudo pacman -S dbeaver
, it showed:
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [#######################################] 100%
(1/1) checking package integrity [#######################################] 100%
(1/1) loading package files [#######################################] 100%
(1/1) checking for file conflicts [#######################################] 100%
(1/1) checking available disk space [#######################################] 100%
(1/1) reinstalling dbeaver [#######################################] 100%
ldconfig: File /usr/lib/libdruntime-ldc-shared.so.2.0.98 is empty, not checked.
ldconfig: File /usr/lib/libphobos2-ldc-debug-shared.so.2.0.98 is empty, not checked.
ldconfig: File /usr/lib/libdruntime-ldc-shared.so is empty, not checked.
ldconfig: File /usr/lib/libdruntime-ldc-debug-shared.so.2.0.98 is empty, not checked.
ldconfig: File /usr/lib/libphobos2-ldc-debug-shared.so is empty, not checked.
ldconfig: File /usr/lib/libdruntime-ldc-shared.so.98 is empty, not checked.
ldconfig: File /usr/lib/libdruntime-ldc-debug-shared.so is empty, not checked.
ldconfig: File /usr/lib/libphobos2-ldc-debug-shared.so.98 is empty, not checked.
ldconfig: File /usr/lib/libdruntime-ldc-debug-shared.so.98 is empty, not checked.
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating the DBeaver bundles.info database...
(3/4) Updating icon theme caches...
(4/4) Updating the desktop file MIME type cache...
I checked it by sudo pacman -Qi dbeaver
error: could not open file /var/lib/pacman/local/liblphobos-3:1.28.0-3/desc: No such file or directory
Version : 21.3.2-1
Description : Free universal SQL Client for developers and database administrators (community edition)
Architecture : x86_64
URL : https://dbeaver.io/
Licenses : Apache
Groups : None
Provides : None
Depends On : java-runtime>=11 gtk3 gtk-update-icon-cache libsecret
Optional Deps : dbeaver-plugin-office: export data in Microsoft Office Excel format
dbeaver-plugin-svg-format: save diagrams in SVG format
Required By : None
Optional For : None
Conflicts With : dbeaver-plugin-sshj-lib
Replaces : dbeaver-plugin-sshj-lib
Installed Size : 72.50 MiB
Packager : Fabio Castelli (Muflone) <muflone@archlinux.org>
Build Date : จ. 27 ธ.ค. 2564, 04:57:42
Install Date : ศ. 7 ม.ค. 2565, 22:14:07
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
I checked the directory:
$ ls /var/lib/pacman/local/liblphobos-3:1.28.0-3
mtree
Anyone know what happened? Thanks in advance.
