Hello Manjaro Community , I am Rajrup, yesterday i’ve downloaded apache and php php-apache, everything was ok , but i am facing some issues with the configuration
default configuration for httpd.conf document root and directory is
<Directory />
Options Indexes FollowSymLinks
AllowOverride none
Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "/srv/http"
<Directory "/srv/http">
# Possible values for the Options directive are "None", "All",
# or any combination of:
# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
# The Options directive is both complicated and important. Please see
# for more information.
# AllowOverride controls what directives may be placed in .htaccess files.
# It can be "All", "None", or any combination of the keywords:
# AllowOverride FileInfo AuthConfig Limit
AllowOverride All
# Controls who can get stuff from this server.
Require all granted
</Directory>
i want to change the default document root and Directory path to my home directory,
I tried my best possible to do that change but it is not working ,
It’s keeps saying me access denied , but when i run through that default directory everything is working ,
Now my question is what i am missing , how to set the default apache root path to home directory?
