What happened to the Kernels tab in Settings
Settings no longer has a tab to view/select kernels. Looked elsewhere can’t find any such thing anymore.
Hi @kwe,
If I have it correctly, it is because the kernel control screen for Manjaro needs to be ported/updated/changed to work with Qt6.
You can still use Manjaro settings manager to manage kernels, if you prefer a GUI:
https://i.imgur.com/d5NMOob.png
That is correct - kcm items based on qt5 does not work with qt6.
You can access Manjaro Settings Manager using the app launcher
