Hi,
After upgrading my laptop to manjaro 21.0.5, it happened that my nvidia drivers were not being loaded successfully anymore. Also, the laptop fan goes crazy even though I’m not doing anything remarkable.
I’ve restored my system in Timeshift in hope that future versions would fix my problem. No luck. Yesterday I tried, again, updating to 21.0.7, but the same problem occurs.
Going through the logs I can see there is some problem related to 64-bit BAR or something, however I’m not sure if that’s the real problem:
dmesg output
[ 0.000000] microcode: microcode updated early to revision 0xde, date = 2020-05-25
[ 0.000000] Linux version 5.4.124-1-MANJARO (builduser@LEGION) (gcc version 11.1.0 (GCC)) #1 SMP PREEMPT Thu Jun 3 14:16:42 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64 root=UUID=ed1d3b79-471d-4c6a-befa-fb6abf947f17 rw rootflags=subvol=@ quiet resume=UUID=4d29a380-fa5f-4dec-8810-c727b65f9f93 udev.log_priority=3
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040400000-0x000000006d7aafff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006d7ab000-0x000000006d7abfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006d7ac000-0x000000006d7acfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006d7ad000-0x00000000773bdfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000773be000-0x00000000779c9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000779ca000-0x0000000077a46fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000077a47000-0x0000000077b4dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000077b4e000-0x000000007912ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079130000-0x00000000791fdfff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000791fe000-0x00000000791fefff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000791ff000-0x000000007f7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027e7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0x779e3000 ACPI=0x779e3000 SMBIOS=0xf0000 SMBIOS 3.0=0xf0020 ESRT=0x78e25018 MEMATTR=0x7335c018
[ 0.000000] SMBIOS 3.2.1 present.
[ 0.000000] DMI: Dell Inc. G3 3590/02RJ9R, BIOS 1.11.1 08/19/2020
[ 0.000000] tsc: Detected 2400.000 MHz processor
[ 0.002980] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.002981] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.002985] last_pfn = 0x27e800 max_arch_pfn = 0x400000000
[ 0.003012] MTRR default type: write-back
[ 0.003012] MTRR fixed ranges enabled:
[ 0.003013] 00000-9FFFF write-back
[ 0.003013] A0000-BFFFF uncachable
[ 0.003014] C0000-FFFFF write-protect
[ 0.003014] MTRR variable ranges enabled:
[ 0.003015] 0 base 00C0000000 mask 7FC0000000 uncachable
[ 0.003016] 1 base 007C000000 mask 7FFC000000 uncachable
[ 0.003016] 2 base 007B000000 mask 7FFF000000 uncachable
[ 0.003017] 3 base 00A0000000 mask 7FE0000000 uncachable
[ 0.003017] 4 base 0090000000 mask 7FF0000000 uncachable
[ 0.003018] 5 base 0080000000 mask 7FF0000000 write-combining
[ 0.003018] 6 disabled
[ 0.003018] 7 disabled
[ 0.003018] 8 disabled
[ 0.003019] 9 disabled
[ 0.003331] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.003494] last_pfn = 0x791ff max_arch_pfn = 0x400000000
[ 0.009047] esrt: Reserving ESRT space from 0x0000000078e25018 to 0x0000000078e25050.
[ 0.009053] check: Scanning 1 areas for low memory corruption
[ 0.009056] Using GB pages for direct mapping
[ 0.009371] Secure boot could not be determined
[ 0.009372] RAMDISK: [mem 0x3686b000-0x3742cfff]
[ 0.009375] ACPI: Early table checksum verification disabled
[ 0.009376] ACPI: RSDP 0x00000000779E3000 000024 (v02 DELL )
[ 0.009378] ACPI: XSDT 0x00000000779E30B8 0000F4 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009382] ACPI: FACP 0x0000000077A27638 000114 (v06 DELL CBX3 01072009 AMI 00010013)
[ 0.009385] ACPI: DSDT 0x00000000779E3240 0443F6 (v02 DELL CBX3 01072009 INTL 20160527)
[ 0.009386] ACPI: FACS 0x0000000077B4CC00 000040
[ 0.009387] ACPI: APIC 0x0000000077A27750 0000BC (v04 DELL CBX3 01072009 AMI 00010013)
[ 0.009389] ACPI: FPDT 0x0000000077A27810 000044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009390] ACPI: FIDT 0x0000000077A27858 00009C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009392] ACPI: MCFG 0x0000000077A278F8 00003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.009393] ACPI: SSDT 0x0000000077A27938 001B1C (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.009395] ACPI: BOOT 0x0000000077A29458 000028 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009396] ACPI: SSDT 0x0000000077A29480 0031C6 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.009398] ACPI: SSDT 0x0000000077A2C648 002875 (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.009399] ACPI: HPET 0x0000000077A2EEC0 000038 (v01 DELL\x CBX3 00000002 01000013)
[ 0.009401] ACPI: SSDT 0x0000000077A2EEF8 002C26 (v02 DELL\x CflH_Rvp 00001000 INTL 20160527)
[ 0.009402] ACPI: SSDT 0x0000000077A31B20 004176 (v02 INTEL xh_cfhd4 00000000 INTL 20160527)
[ 0.009404] ACPI: UEFI 0x0000000077A35C98 000042 (v01 DELL\x CBX3 00000002 01000013)
[ 0.009405] ACPI: LPIT 0x0000000077A35CE0 000094 (v01 DELL\x CBX3 00000002 01000013)
[ 0.009407] ACPI: SSDT 0x0000000077A35D78 000C2B (v02 DELL\x PtidDevc 00001000 INTL 20160527)
[ 0.009408] ACPI: SSDT 0x0000000077A369A8 0014E2 (v02 DELL\x TbtTypeC 00000000 INTL 20160527)
[ 0.009410] ACPI: DBGP 0x0000000077A37E90 000034 (v01 DELL\x CBX3 00000002 01000013)
[ 0.009411] ACPI: DBG2 0x0000000077A37EC8 000054 (v00 DELL\x CBX3 00000002 01000013)
[ 0.009413] ACPI: SSDT 0x0000000077A37F20 0007DD (v02 DELL\x UsbCTabl 00001000 INTL 20160527)
[ 0.009414] ACPI: SSDT 0x0000000077A38700 0047A3 (v02 DptfTa DptfTabl 00001000 INTL 20160527)
[ 0.009416] ACPI: DMAR 0x0000000077A3CEA8 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.009417] ACPI: SSDT 0x0000000077A3CF50 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.009418] ACPI: SSDT 0x0000000077A3D098 0000AE (v02 SgRef SgPeg 00001000 INTL 20160527)
[ 0.009420] ACPI: NHLT 0x0000000077A3D148 00189E (v00 INTEL EDK2 00000002 01000013)
[ 0.009422] ACPI: BGRT 0x0000000077A3E9E8 000038 (v00 01072009 AMI 00010013)
[ 0.009423] ACPI: SSDT 0x0000000077A3EA20 0024D2 (v01 OptRef OptTabl 00001000 INTL 20160527)
[ 0.009425] ACPI: Reserving FACP table memory at [mem 0x77a27638-0x77a2774b]
[ 0.009425] ACPI: Reserving DSDT table memory at [mem 0x779e3240-0x77a27635]
[ 0.009426] ACPI: Reserving FACS table memory at [mem 0x77b4cc00-0x77b4cc3f]
[ 0.009426] ACPI: Reserving APIC table memory at [mem 0x77a27750-0x77a2780b]
[ 0.009427] ACPI: Reserving FPDT table memory at [mem 0x77a27810-0x77a27853]
[ 0.009427] ACPI: Reserving FIDT table memory at [mem 0x77a27858-0x77a278f3]
[ 0.009427] ACPI: Reserving MCFG table memory at [mem 0x77a278f8-0x77a27933]
[ 0.009428] ACPI: Reserving SSDT table memory at [mem 0x77a27938-0x77a29453]
[ 0.009428] ACPI: Reserving BOOT table memory at [mem 0x77a29458-0x77a2947f]
[ 0.009429] ACPI: Reserving SSDT table memory at [mem 0x77a29480-0x77a2c645]
[ 0.009429] ACPI: Reserving SSDT table memory at [mem 0x77a2c648-0x77a2eebc]
[ 0.009430] ACPI: Reserving HPET table memory at [mem 0x77a2eec0-0x77a2eef7]
[ 0.009430] ACPI: Reserving SSDT table memory at [mem 0x77a2eef8-0x77a31b1d]
[ 0.009431] ACPI: Reserving SSDT table memory at [mem 0x77a31b20-0x77a35c95]
[ 0.009431] ACPI: Reserving UEFI table memory at [mem 0x77a35c98-0x77a35cd9]
[ 0.009432] ACPI: Reserving LPIT table memory at [mem 0x77a35ce0-0x77a35d73]
[ 0.009432] ACPI: Reserving SSDT table memory at [mem 0x77a35d78-0x77a369a2]
[ 0.009433] ACPI: Reserving SSDT table memory at [mem 0x77a369a8-0x77a37e89]
[ 0.009433] ACPI: Reserving DBGP table memory at [mem 0x77a37e90-0x77a37ec3]
[ 0.009434] ACPI: Reserving DBG2 table memory at [mem 0x77a37ec8-0x77a37f1b]
[ 0.009434] ACPI: Reserving SSDT table memory at [mem 0x77a37f20-0x77a386fc]
[ 0.009435] ACPI: Reserving SSDT table memory at [mem 0x77a38700-0x77a3cea2]
[ 0.009435] ACPI: Reserving DMAR table memory at [mem 0x77a3cea8-0x77a3cf4f]
[ 0.009435] ACPI: Reserving SSDT table memory at [mem 0x77a3cf50-0x77a3d093]
[ 0.009436] ACPI: Reserving SSDT table memory at [mem 0x77a3d098-0x77a3d145]
[ 0.009436] ACPI: Reserving NHLT table memory at [mem 0x77a3d148-0x77a3e9e5]
[ 0.009437] ACPI: Reserving BGRT table memory at [mem 0x77a3e9e8-0x77a3ea1f]
[ 0.009437] ACPI: Reserving SSDT table memory at [mem 0x77a3ea20-0x77a40ef1]
[ 0.009452] ACPI: Local APIC address 0xfee00000
[ 0.009715] No NUMA configuration found
[ 0.009716] Faking a node at [mem 0x0000000000000000-0x000000027e7fffff]
[ 0.009718] NODE_DATA(0) allocated [mem 0x27e7fc000-0x27e7fffff]
[ 0.009734] Zone ranges:
[ 0.009735] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.009736] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.009736] Normal [mem 0x0000000100000000-0x000000027e7fffff]
[ 0.009737] Device empty
[ 0.009737] Movable zone start for each node
[ 0.009738] Early memory node ranges
[ 0.009738] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.009739] node 0: [mem 0x000000000009f000-0x000000000009ffff]
[ 0.009739] node 0: [mem 0x0000000000100000-0x000000003fffffff]
[ 0.009740] node 0: [mem 0x0000000040400000-0x000000006d7aafff]
[ 0.009740] node 0: [mem 0x000000006d7ad000-0x00000000773bdfff]
[ 0.009740] node 0: [mem 0x00000000791fe000-0x00000000791fefff]
[ 0.009741] node 0: [mem 0x0000000100000000-0x000000027e7fffff]
[ 0.009930] Zeroed struct page in unavailable ranges: 43173 pages
[ 0.009931] Initmem setup node 0 [mem 0x0000000000001000-0x000000027e7fffff]
[ 0.009931] On node 0 totalpages: 2053979
[ 0.009932] DMA zone: 64 pages used for memmap
[ 0.009932] DMA zone: 23 pages reserved
[ 0.009933] DMA zone: 3998 pages, LIFO batch:0
[ 0.009966] DMA32 zone: 7551 pages used for memmap
[ 0.009967] DMA32 zone: 483261 pages, LIFO batch:63
[ 0.016301] Normal zone: 24480 pages used for memmap
[ 0.016301] Normal zone: 1566720 pages, LIFO batch:63
[ 0.029008] Reserving Intel graphics memory at [mem 0x7b800000-0x7f7fffff]
[ 0.029679] ACPI: PM-Timer IO Port: 0x1808
[ 0.029680] ACPI: Local APIC address 0xfee00000
[ 0.029684] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.029685] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.029685] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.029685] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.029686] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.029686] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.029686] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.029687] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.029752] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.029753] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.029754] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.029755] ACPI: IRQ0 used by override.
[ 0.029755] ACPI: IRQ9 used by override.
[ 0.029756] Using ACPI (MADT) for SMP configuration information
[ 0.029757] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.029762] e820: update [mem 0x72d91000-0x72e19fff] usable ==> reserved
[ 0.029768] TSC deadline timer available
[ 0.029768] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.029788] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.029789] PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.029790] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.029791] PM: Registered nosave memory: [mem 0x40000000-0x403fffff]
[ 0.029792] PM: Registered nosave memory: [mem 0x6d7ab000-0x6d7abfff]
[ 0.029792] PM: Registered nosave memory: [mem 0x6d7ac000-0x6d7acfff]
[ 0.029793] PM: Registered nosave memory: [mem 0x72d91000-0x72e19fff]
[ 0.029794] PM: Registered nosave memory: [mem 0x773be000-0x779c9fff]
[ 0.029795] PM: Registered nosave memory: [mem 0x779ca000-0x77a46fff]
[ 0.029795] PM: Registered nosave memory: [mem 0x77a47000-0x77b4dfff]
[ 0.029795] PM: Registered nosave memory: [mem 0x77b4e000-0x7912ffff]
[ 0.029796] PM: Registered nosave memory: [mem 0x79130000-0x791fdfff]
[ 0.029797] PM: Registered nosave memory: [mem 0x791ff000-0x7f7fffff]
[ 0.029797] PM: Registered nosave memory: [mem 0x7f800000-0xdfffffff]
[ 0.029797] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.029798] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.029798] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.029798] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.029799] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.029799] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.029799] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.029800] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.029800] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.029801] [mem 0x7f800000-0xdfffffff] available for PCI devices
[ 0.029802] Booting paravirtualized kernel on bare hardware
[ 0.029803] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.095902] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.096010] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u262144
[ 0.096014] pcpu-alloc: s184320 r8192 d28672 u262144 alloc=1*2097152
[ 0.096014] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.096027] Built 1 zonelists, mobility grouping on. Total pages: 2021861
[ 0.096028] Policy zone: Normal
[ 0.096029] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64 root=UUID=ed1d3b79-471d-4c6a-befa-fb6abf947f17 rw rootflags=subvol=@ quiet resume=UUID=4d29a380-fa5f-4dec-8810-c727b65f9f93 udev.log_priority=3
[ 0.096320] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.096470] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.096522] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.098560] Calgary: detecting Calgary via BIOS EBDA area
[ 0.098561] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.110451] Memory: 7915992K/8215916K available (12291K kernel code, 1331K rwdata, 4096K rodata, 1640K init, 3404K bss, 299924K reserved, 0K cma-reserved)
[ 0.110456] random: get_random_u64 called from __kmem_cache_create+0x3e/0x5f0 with crng_init=0
[ 0.110556] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.110566] Kernel/User page tables isolation: enabled
[ 0.110575] ftrace: allocating 37586 entries in 147 pages
[ 0.119667] rcu: Preemptible hierarchical RCU implementation.
[ 0.119668] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.119668] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.119669] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.119669] Tasks RCU enabled.
[ 0.119670] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.119670] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.121223] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[ 0.121817] Console: colour dummy device 80x25
[ 0.121820] printk: console [tty0] enabled
[ 0.121830] ACPI: Core revision 20190816
[ 0.122233] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.122376] APIC: Switch to symmetric I/O mode setup
[ 0.122377] DMAR: Host address width 39
[ 0.122378] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.122382] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.122382] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.122384] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.122385] DMAR: RMRR base: 0x00000077927000 end: 0x00000077946fff
[ 0.122385] DMAR: RMRR base: 0x0000007b000000 end: 0x0000007f7fffff
[ 0.122386] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.122387] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.122387] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.125448] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.125449] x2apic enabled
[ 0.125479] Switched APIC routing to cluster x2apic.
[ 0.134828] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.148993] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x22983777dd9, max_idle_ns: 440795300422 ns
[ 0.148996] Calibrating delay loop (skipped), value calculated using timer frequency.. 4801.00 BogoMIPS (lpj=8000000)
[ 0.148997] pid_max: default: 32768 minimum: 301
[ 0.151086] LSM: Security Framework initializing
[ 0.151089] Yama: becoming mindful.
[ 0.151111] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.151120] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.151127] *** VALIDATE tmpfs ***
[ 0.151213] *** VALIDATE proc ***
[ 0.151244] *** VALIDATE cgroup1 ***
[ 0.151245] *** VALIDATE cgroup2 ***
[ 0.151292] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.151307] process: using mwait in idle threads
[ 0.151308] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.151309] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.151311] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.151312] Spectre V2 : Mitigation: Full generic retpoline
[ 0.151312] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.151312] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.151313] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.151314] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.151314] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.151317] SRBDS: Mitigation: Microcode
[ 0.151318] MDS: Mitigation: Clear CPU buffers
[ 0.151527] Freeing SMP alternatives memory: 32K
[ 0.152397] smpboot: CPU0: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.152454] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.152458] ... version: 4
[ 0.152459] ... bit width: 48
[ 0.152459] ... generic registers: 4
[ 0.152459] ... value mask: 0000ffffffffffff
[ 0.152460] ... max period: 00007fffffffffff
[ 0.152460] ... fixed-purpose events: 3
[ 0.152460] ... event mask: 000000070000000f
[ 0.152489] rcu: Hierarchical SRCU implementation.
[ 0.153032] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.153081] smp: Bringing up secondary CPUs ...
[ 0.153147] x86: Booting SMP configuration:
[ 0.153147] .... node #0, CPUs: #1 #2 #3 #4
[ 0.157205] MDS CPU bug present and SMT on, data leak possible. See for more details.
[ 0.159022] #5 #6 #7
[ 0.159420] smp: Brought up 1 node, 8 CPUs
[ 0.159420] smpboot: Max logical packages: 1
[ 0.159420] smpboot: Total of 8 processors activated (38415.00 BogoMIPS)
[ 0.162568] devtmpfs: initialized
[ 0.162568] x86/mm: Memory block size: 128MB
[ 0.162796] PM: Registering ACPI NVS region [mem 0x6d7ab000-0x6d7abfff] (4096 bytes)
[ 0.162796] PM: Registering ACPI NVS region [mem 0x77a47000-0x77b4dfff] (1077248 bytes)
[ 0.162796] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.162796] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.162796] pinctrl core: initialized pinctrl subsystem
[ 0.162796] PM: RTC time: 19:20:14, date: 2021-06-25
[ 0.162796] NET: Registered protocol family 16
[ 0.162796] audit: initializing netlink subsys (disabled)
[ 0.162796] audit: type=2000 audit(1624648814.033:1): state=initialized audit_enabled=0 res=1
[ 0.162796] cpuidle: using governor ladder
[ 0.162796] cpuidle: using governor menu
[ 0.162796] Simple Boot Flag at 0x47 set to 0x80
[ 0.162796] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.162796] ACPI: bus type PCI registered
[ 0.162796] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.162796] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.162796] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.162796] PCI: Using configuration type 1 for base access
[ 0.162796] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.162831] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.162831] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.162831] ACPI: Added _OSI(Module Device)
[ 0.162831] ACPI: Added _OSI(Processor Device)
[ 0.162831] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.162831] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.162831] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.162831] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.162831] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.227524] ACPI: 13 ACPI AML tables successfully acquired and loaded
[ 0.236910] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.244147] ACPI: Dynamic OEM Table Load:
[ 0.244151] ACPI: SSDT 0xFFFF992F74295500 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.245450] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.246971] ACPI: Dynamic OEM Table Load:
[ 0.246974] ACPI: SSDT 0xFFFF992F74B0C000 000434 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.248369] ACPI: Dynamic OEM Table Load:
[ 0.248372] ACPI: SSDT 0xFFFF992F74B0F000 00053F (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.249817] ACPI: Dynamic OEM Table Load:
[ 0.249820] ACPI: SSDT 0xFFFF992F742C1600 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.251135] ACPI: Dynamic OEM Table Load:
[ 0.251139] ACPI: SSDT 0xFFFF992F74B09000 000724 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.252686] ACPI: Dynamic OEM Table Load:
[ 0.252690] ACPI: SSDT 0xFFFF992F74B0C800 0005FC (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.254142] ACPI: Dynamic OEM Table Load:
[ 0.254145] ACPI: SSDT 0xFFFF992F75019C00 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.255619] ACPI: Dynamic OEM Table Load:
[ 0.255622] ACPI: SSDT 0xFFFF992F74B5B000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.257516] ACPI: Dynamic OEM Table Load:
[ 0.257519] ACPI: SSDT 0xFFFF992F74304C00 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.261908] ACPI: EC: EC started
[ 0.261908] ACPI: EC: interrupt blocked
[ 0.269078] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as first EC
[ 0.269079] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.269080] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
[ 0.269080] ACPI: Interpreter enabled
[ 0.269111] ACPI: (supports S0 S3 S4 S5)
[ 0.269111] ACPI: Using IOAPIC for interrupt routing
[ 0.269139] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.270407] ACPI: Enabled 10 GPEs in block 00 to 7F
[ 0.273646] ACPI: Power Resource [PG00] (on)
[ 0.278129] ACPI: Power Resource [PXP] (off)
[ 0.280753] ACPI: Power Resource [WRST] (on)
[ 0.280990] ACPI: Power Resource [DRST] (on)
[ 0.282310] ACPI: Power Resource [PXP] (off)
[ 0.284962] ACPI: Power Resource [USBC] (on)
[ 0.285090] ACPI: Power Resource [PAUD] (on)
[ 0.287781] ACPI: Power Resource [V0PR] (on)
[ 0.288127] ACPI: Power Resource [V1PR] (on)
[ 0.288469] ACPI: Power Resource [V2PR] (on)
[ 0.291765] ACPI: Power Resource [PXTC] (on)
[ 0.292460] ACPI: Power Resource [PXTC] (off)
[ 0.294162] ACPI: Power Resource [WRST] (on)
[ 0.312007] ACPI: Power Resource [PIN] (off)
[ 0.312371] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.312376] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.315632] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[ 0.315632] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.316464] PCI host bridge to bus 0000:00
[ 0.316466] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.316466] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.316467] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.316468] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[ 0.316468] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[ 0.316469] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[ 0.316469] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[ 0.316470] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.316470] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.316471] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.316471] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.316472] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xdfffffff window]
[ 0.316473] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.316473] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.316480] pci 0000:00:00.0: [8086:3e10] type 00 class 0x060000
[ 0.316797] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.316831] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.317052] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[ 0.317059] pci 0000:00:02.0: reg 0x10: [mem 0xa4000000-0xa4ffffff 64bit]
[ 0.317063] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.317065] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.317077] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.317197] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.317205] pci 0000:00:04.0: reg 0x10: [mem 0xa5410000-0xa5417fff 64bit]
[ 0.317373] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.317381] pci 0000:00:08.0: reg 0x10: [mem 0xa5429000-0xa5429fff 64bit]
[ 0.317588] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.317629] pci 0000:00:12.0: reg 0x10: [mem 0xa5428000-0xa5428fff 64bit]
[ 0.317942] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.317985] pci 0000:00:14.0: reg 0x10: [mem 0xa5400000-0xa540ffff 64bit]
[ 0.318118] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.318498] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.318533] pci 0000:00:14.2: reg 0x10: [mem 0xa541e000-0xa541ffff 64bit]
[ 0.318550] pci 0000:00:14.2: reg 0x18: [mem 0xa5427000-0xa5427fff 64bit]
[ 0.318996] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[ 0.319800] pci 0000:00:15.0: reg 0x10: [mem 0xa5426000-0xa5426fff 64bit]
[ 0.320221] pci 0000:00:15.0: reg 0x18: [mem 0xa5425000-0xa5425fff 64bit]
[ 0.322745] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[ 0.323473] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.325927] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.325967] pci 0000:00:16.0: reg 0x10: [mem 0xa5423000-0xa5423fff 64bit]
[ 0.326082] pci 0000:00:16.0: PME# supported from D3hot
[ 0.326329] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[ 0.326365] pci 0000:00:17.0: reg 0x10: [mem 0xa541c000-0xa541dfff]
[ 0.326379] pci 0000:00:17.0: reg 0x14: [mem 0xa5422000-0xa54220ff]
[ 0.326393] pci 0000:00:17.0: reg 0x18: [io 0x5090-0x5097]
[ 0.326407] pci 0000:00:17.0: reg 0x1c: [io 0x5080-0x5083]
[ 0.326421] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ 0.326435] pci 0000:00:17.0: reg 0x24: [mem 0xa5421000-0xa54217ff]
[ 0.326515] pci 0000:00:17.0: PME# supported from D3hot
[ 0.326736] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.326987] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.327174] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[ 0.327363] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[ 0.327396] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[ 0.327583] pci 0000:00:1d.6: [8086:a336] type 01 class 0x060400
[ 0.327772] pci 0000:00:1d.6: PME# supported from D0 D3hot D3cold
[ 0.327803] pci 0000:00:1d.6: PTM enabled (root), 4ns granularity
[ 0.328001] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[ 0.328289] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040100
[ 0.328366] pci 0000:00:1f.3: reg 0x10: [mem 0xa5418000-0xa541bfff 64bit]
[ 0.328439] pci 0000:00:1f.3: reg 0x20: [mem 0xa5200000-0xa52fffff 64bit]
[ 0.328590] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.329235] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.329398] pci 0000:00:1f.4: reg 0x10: [mem 0xa5420000-0xa54200ff 64bit]
[ 0.329587] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.329925] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.329951] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.330183] pci 0000:01:00.0: [10de:1c91] type 00 class 0x030000
[ 0.330205] pci 0000:01:00.0: reg 0x10: [mem 0xa2000000-0xa2ffffff]
[ 0.330217] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.330230] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ 0.330236] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.330243] pci 0000:01:00.0: reg 0x30: [mem 0xa3000000-0xa307ffff pref]
[ 0.330331] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8 GT/s x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
[ 0.330421] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
[ 0.330440] pci 0000:01:00.1: reg 0x10: [mem 0xa3080000-0xa3083fff]
[ 0.330608] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.330609] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.330611] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa30fffff]
[ 0.330713] pci 0000:00:1d.0: PCI bridge to [bus 02]
[ 0.330841] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.330883] pci 0000:03:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.330918] pci 0000:03:00.0: reg 0x18: [mem 0xa5304000-0xa5304fff 64bit]
[ 0.330940] pci 0000:03:00.0: reg 0x20: [mem 0xa5300000-0xa5303fff 64bit]
[ 0.331084] pci 0000:03:00.0: supports D1 D2
[ 0.331085] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.331272] pci 0000:00:1d.5: PCI bridge to [bus 03]
[ 0.331276] pci 0000:00:1d.5: bridge window [io 0x3000-0x3fff]
[ 0.331281] pci 0000:00:1d.5: bridge window [mem 0xa5300000-0xa53fffff]
[ 0.331752] pci 0000:04:00.0: [168c:0042] type 00 class 0x028000
[ 0.332211] pci 0000:04:00.0: reg 0x10: [mem 0xa5000000-0xa51fffff 64bit]
[ 0.334032] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 0.335664] pci 0000:00:1d.6: PCI bridge to [bus 04]
[ 0.335673] pci 0000:00:1d.6: bridge window [mem 0xa5000000-0xa51fffff]
[ 0.338216] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.338285] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[ 0.338352] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.338419] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.338486] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.338553] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.338620] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.338686] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.355687] ACPI: EC: interrupt unblocked
[ 0.355704] ACPI: EC: event unblocked
[ 0.355716] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.355716] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions and events
[ 0.355783] iommu: Default domain type: Translated
[ 0.355792] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.355792] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.355928] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.355929] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.355929] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.355930] vgaarb: loaded
[ 0.356008] ACPI: bus type USB registered
[ 0.356014] usbcore: registered new interface driver usbfs
[ 0.356017] usbcore: registered new interface driver hub
[ 0.356021] usbcore: registered new device driver usb
[ 0.356033] pps_core: LinuxPPS API ver. 1 registered
[ 0.356034] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.356035] PTP clock support registered
[ 0.356039] EDAC MC: Ver: 3.0.0
[ 0.356959] Registered efivars operations
[ 0.356959] PCI: Using ACPI for IRQ routing
[ 0.444878] PCI: pci_cache_line_size set to 64 bytes
[ 0.445422] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.445423] e820: reserve RAM buffer [mem 0x6d7ab000-0x6fffffff]
[ 0.445424] e820: reserve RAM buffer [mem 0x72d91000-0x73ffffff]
[ 0.445424] e820: reserve RAM buffer [mem 0x773be000-0x77ffffff]
[ 0.445425] e820: reserve RAM buffer [mem 0x791ff000-0x7bffffff]
[ 0.445425] e820: reserve RAM buffer [mem 0x27e800000-0x27fffffff]
[ 0.445478] NetLabel: Initializing
[ 0.445478] NetLabel: domain hash size = 128
[ 0.445478] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.445486] NetLabel: unlabeled traffic allowed by default
[ 0.446011] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.446013] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.448105] clocksource: Switched to clocksource tsc-early
[ 0.452435] *** VALIDATE bpf ***
[ 0.452470] VFS: Disk quotas dquot_6.6.0
[ 0.452479] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.452496] *** VALIDATE ramfs ***
[ 0.452497] *** VALIDATE hugetlbfs ***
[ 0.452525] pnp: PnP ACPI init
[ 0.452612] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[ 0.452615] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.452791] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.452792] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.452794] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.452889] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.452890] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.453026] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.453036] pnp 00:04: Plug and Play ACPI device, IDs DLL0949 PNP0f13 (active)
[ 0.453215] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.453215] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.453216] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.453217] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.453218] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.453218] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.453219] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.453220] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.453222] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.453410] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.453411] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.453412] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.453412] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.453413] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.453414] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.453415] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.453417] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.453668] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.453670] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.454598] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.460170] pnp: PnP ACPI: found 9 devices
[ 0.460878] thermal_sys: Registered thermal governor 'fair_share'
[ 0.460879] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.460879] thermal_sys: Registered thermal governor 'step_wise'
[ 0.460880] thermal_sys: Registered thermal governor 'user_space'
[ 0.460880] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.465402] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.465421] pci 0000:00:1d.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.465422] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.465423] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[ 0.465429] pci 0000:00:1d.0: BAR 14: assigned [mem 0x7f800000-0x7f9fffff]
[ 0.465434] pci 0000:00:1d.0: BAR 15: assigned [mem 0x7fa00000-0x7fbfffff 64bit pref]
[ 0.465438] pci 0000:00:15.1: BAR 0: assigned [mem 0x7fc00000-0x7fc00fff 64bit]
[ 0.465707] pci 0000:00:1d.0: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.465709] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.465710] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.465711] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa30fffff]
[ 0.465714] pci 0000:00:1d.0: PCI bridge to [bus 02]
[ 0.465722] pci 0000:00:1d.0: bridge window [io 0x6000-0x6fff]
[ 0.465728] pci 0000:00:1d.0: bridge window [mem 0x7f800000-0x7f9fffff]
[ 0.465733] pci 0000:00:1d.0: bridge window [mem 0x7fa00000-0x7fbfffff 64bit pref]
[ 0.465741] pci 0000:00:1d.5: PCI bridge to [bus 03]
[ 0.465743] pci 0000:00:1d.5: bridge window [io 0x3000-0x3fff]
[ 0.465750] pci 0000:00:1d.5: bridge window [mem 0xa5300000-0xa53fffff]
[ 0.465762] pci 0000:00:1d.6: PCI bridge to [bus 04]
[ 0.465769] pci 0000:00:1d.6: bridge window [mem 0xa5000000-0xa51fffff]
[ 0.465782] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.465783] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.465783] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.465784] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[ 0.465785] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[ 0.465785] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[ 0.465786] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[ 0.465786] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[ 0.465787] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[ 0.465787] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[ 0.465788] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[ 0.465789] pci_bus 0000:00: resource 15 [mem 0x7f800000-0xdfffffff window]
[ 0.465789] pci_bus 0000:00: resource 16 [mem 0xfc800000-0xfe7fffff window]
[ 0.465790] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.465790] pci_bus 0000:01: resource 1 [mem 0x90000000-0xa30fffff]
[ 0.465791] pci_bus 0000:02: resource 0 [io 0x6000-0x6fff]
[ 0.465792] pci_bus 0000:02: resource 1 [mem 0x7f800000-0x7f9fffff]
[ 0.465793] pci_bus 0000:02: resource 2 [mem 0x7fa00000-0x7fbfffff 64bit pref]
[ 0.465793] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.465794] pci_bus 0000:03: resource 1 [mem 0xa5300000-0xa53fffff]
[ 0.465794] pci_bus 0000:04: resource 1 [mem 0xa5000000-0xa51fffff]
[ 0.465942] NET: Registered protocol family 2
[ 0.465996] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.466571] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.466597] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.466682] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.466725] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.466746] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.466760] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.466806] NET: Registered protocol family 1
[ 0.466809] NET: Registered protocol family 44
[ 0.466816] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.467184] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.467385] PCI: CLS 64 bytes, default 64
[ 0.467407] Trying to unpack rootfs image as initramfs...
[ 0.553198] Freeing initrd memory: 12040K
[ 0.572364] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.572369] software IO TLB: mapped [mem 0x6ed91000-0x72d91000] (64MB)
[ 0.572466] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.572566] check: Scanning for low memory corruption every 60 seconds
[ 0.572895] Initialise system trusted keyrings
[ 0.572908] Key type blacklist registered
[ 0.572947] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.574064] zbud: loaded
[ 0.577261] Key type asymmetric registered
[ 0.577262] Asymmetric key parser 'x509' registered
[ 0.577268] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.577289] io scheduler mq-deadline registered
[ 0.577290] io scheduler kyber registered
[ 0.577307] io scheduler bfq registered
[ 0.581521] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 0.686841] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[ 0.686880] pcieport 0000:00:1d.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 0.687295] pcieport 0000:00:1d.5: PME: Signaling with IRQ 124
[ 0.687366] pcieport 0000:00:1d.5: AER: enabled with IRQ 124
[ 0.687421] pcieport 0000:00:1d.5: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.687792] pcieport 0000:00:1d.6: PME: Signaling with IRQ 125
[ 0.687858] pcieport 0000:00:1d.6: AER: enabled with IRQ 125
[ 0.687907] pcieport 0000:00:1d.6: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.688033] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.688117] efifb: probing for efifb
[ 0.688131] efifb: showing boot graphics
[ 0.689075] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[ 0.689077] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.689077] efifb: scrolling: redraw
[ 0.689078] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.689114] fbcon: Deferring console take-over
[ 0.689115] fb0: EFI VGA frame buffer device
[ 0.689121] intel_idle: MWAIT substates: 0x11142120
[ 0.689122] intel_idle: v0.4.1 model 0x9E
[ 0.689522] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.689624] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.695739] ACPI: Lid Switch [LID0]
[ 0.695777] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.699024] ACPI: Power Button [PBTN]
[ 0.699053] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.699068] ACPI: Sleep Button [SBTN]
[ 0.702265] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.702266] ACPI: Thermal Zone [THM] (25 C)
[ 0.702546] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.703288] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.703288] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.704196] usbcore: registered new interface driver usbserial_generic
[ 0.704199] usbserial: USB Serial support registered for generic
[ 0.704236] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.705311] rtc_cmos rtc_cmos: registered as rtc0
[ 0.705321] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.705375] intel_pstate: Intel P-state driver initializing
[ 0.705424] intel_pstate: Disabling energy efficiency optimization
[ 0.705970] intel_pstate: HWP enabled
[ 0.706105] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.706161] intel_pmc_core INT33A1:00: initialized
[ 0.706211] drop_monitor: Initializing network drop monitor service
[ 0.706354] NET: Registered protocol family 10
[ 0.711837] Segment Routing with IPv6
[ 0.711857] NET: Registered protocol family 17
[ 0.712527] RAS: Correctable Errors collector initialized.
[ 0.712600] microcode: sig=0x906ea, pf=0x20, revision=0xde
[ 0.712868] microcode: Microcode Update Driver: v2.2.
[ 0.712871] IPI shorthand broadcast: enabled
[ 0.712878] sched_clock: Marking stable (705522634, 7342123)->(719453753, -6588996)
[ 0.713053] registered taskstats version 1
[ 0.713059] Loading compiled-in X.509 certificates
[ 0.716242] Loaded X.509 cert 'Build time autogenerated kernel key: 3c4346de4ef277ce1b6a837b25841358452bfbe8'
[ 0.716280] zswap: loaded using pool lzo/zbud
[ 0.716569] Key type ._fscrypt registered
[ 0.716570] Key type .fscrypt registered
[ 0.722137] Key type big_key registered
[ 0.725243] PM: Magic number: 9:167:345
[ 0.725256] tty tty62: hash matches
[ 0.725598] rtc_cmos rtc_cmos: setting system clock to 2021-06-25T19:20:15 UTC (1624648815)
[ 0.726906] Freeing unused decrypted memory: 2040K
[ 0.727263] Freeing unused kernel image memory: 1640K
[ 0.756039] Write protecting the kernel read-only data: 18432k
[ 0.757090] Freeing unused kernel image memory: 2008K
[ 0.777750] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.777752] x86/mm: Checking user space page tables
[ 0.793356] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.793358] Run /init as init process
[ 0.949238] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.950890] i8042: Warning: Keylock active
[ 0.952399] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.952431] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.958246] SCSI subsystem initialized
[ 0.958444] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.958449] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.959559] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 0.959566] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.959754] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 0.959754] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.959756] usb usb1: Product: xHCI Host Controller
[ 0.959757] usb usb1: Manufacturer: Linux 5.4.124-1-MANJARO xhci-hcd
[ 0.959757] usb usb1: SerialNumber: 0000:00:14.0
[ 0.959849] hub 1-0:1.0: USB hub found
[ 0.959887] hub 1-0:1.0: 16 ports detected
[ 0.962589] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.962591] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.962593] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.962623] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 0.962623] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.962624] usb usb2: Product: xHCI Host Controller
[ 0.962625] usb usb2: Manufacturer: Linux 5.4.124-1-MANJARO xhci-hcd
[ 0.962625] usb usb2: SerialNumber: 0000:00:14.0
[ 0.962714] hub 2-0:1.0: USB hub found
[ 0.962739] hub 2-0:1.0: 8 ports detected
[ 0.963329] libata version 3.00 loaded.
[ 0.965984] ahci 0000:00:17.0: version 3.0
[ 0.966279] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[ 0.966954] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.979386] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.979388] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems deso sadm sds apst
[ 0.979848] scsi host0: ahci
[ 0.979910] ata1: SATA max UDMA/133 abar m2048@0xa5421000 port 0xa5421100 irq 127
[ 1.212432] usb 1-2: new low-speed USB device number 2 using xhci_hcd
[ 1.296779] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.297280] ata1.00: ATA-10: KINGSTON SA400S37480G, SBFKB1C3, max UDMA/133
[ 1.297283] ata1.00: 937703088 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.297865] ata1.00: configured for UDMA/133
[ 1.298124] scsi 0:0:0:0: Direct-Access ATA KINGSTON SA400S3 B1C3 PQ: 0 ANSI: 5
[ 1.305601] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 1.305634] sd 0:0:0:0: [sda] Write Protect is off
[ 1.305640] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.305712] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.349134] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9
[ 1.350885] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.361929] usb 1-2: New USB device found, idVendor=093a, idProduct=2500, bcdDevice= 1.00
[ 1.361930] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.361931] usb 1-2: Product: USB OPTICAL MOUSE
[ 1.361932] usb 1-2: Manufacturer: PIXART
[ 1.366991] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.371731] usbcore: registered new interface driver usbhid
[ 1.371732] usbhid: USB HID core driver
[ 1.372983] input: PIXART USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:093A:2500.0001/input/input5
[ 1.373062] hid-generic 0003:093A:2500.0001: input,hidraw0: USB HID v1.10 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:00:14.0-2/input0
[ 1.485676] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[ 1.502369] raid6: avx2x4 gen() 21653 MB/s
[ 1.527099] random: fast init done
[ 1.558996] raid6: avx2x4 xor() 24719 MB/s
[ 1.595772] tsc: Refined TSC clocksource calibration: 2400.062 MHz
[ 1.595775] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22987232e16, max_idle_ns: 440795311914 ns
[ 1.615667] raid6: avx2x2 gen() 32096 MB/s
[ 1.615668] clocksource: Switched to clocksource tsc
[ 1.661052] usb 1-5: New USB device found, idVendor=0bda, idProduct=5521, bcdDevice=85.11
[ 1.661054] usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.661055] usb 1-5: Product: Integrated_Webcam_HD
[ 1.661056] usb 1-5: Manufacturer: CNFHH46P2964100A25C0
[ 1.661057] usb 1-5: SerialNumber: 200901010001
[ 1.672334] raid6: avx2x2 xor() 22686 MB/s
[ 1.729046] raid6: avx2x1 gen() 29669 MB/s
[ 1.785664] usb 1-14: new full-speed USB device number 4 using xhci_hcd
[ 1.785671] raid6: avx2x1 xor() 21332 MB/s
[ 1.842339] raid6: sse2x4 gen() 17118 MB/s
[ 1.899030] raid6: sse2x4 xor() 10694 MB/s
[ 1.955698] raid6: sse2x2 gen() 14835 MB/s
[ 1.983399] usb 1-14: New USB device found, idVendor=0cf3, idProduct=e009, bcdDevice= 0.01
[ 1.983400] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.012369] raid6: sse2x2 xor() 9879 MB/s
[ 2.069031] raid6: sse2x1 gen() 13280 MB/s
[ 2.125703] raid6: sse2x1 xor() 7250 MB/s
[ 2.125704] raid6: using algorithm avx2x2 gen() 32096 MB/s
[ 2.125704] raid6: .... xor() 22686 MB/s, rmw enabled
[ 2.125705] raid6: using avx2x2 recovery algorithm
[ 2.126533] xor: automatically using best checksumming function avx
[ 2.150462] Btrfs loaded, crc32c=crc32c-intel
[ 2.150978] BTRFS: device fsid ed1d3b79-471d-4c6a-befa-fb6abf947f17 devid 1 transid 139985 /dev/sda8
[ 2.169631] BTRFS info (device sda8): disk space caching is enabled
[ 2.169632] BTRFS info (device sda8): has skinny extents
[ 2.173083] BTRFS info (device sda8): bdev /dev/sda8 errs: wr 4, rd 0, flush 0, corrupt 0, gen 0
[ 2.201349] BTRFS info (device sda8): enabling ssd optimizations
[ 2.485684] systemd[1]: RTC configured in localtime, applying delta of -180 minutes to system time.
[ 2.538132] cgroup2: Unknown parameter 'memory_recursiveprot'
[ 2.543364] systemd[1]: systemd 248.3-3-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.559433] systemd[1]: Detected architecture x86-64.
[ 2.560134] systemd[1]: Hostname set to <arno-pc>.
[ 2.710184] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 2.827772] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.828791] systemd[1]: Created slice system-getty.slice.
[ 2.828981] systemd[1]: Created slice system-modprobe.slice.
[ 2.829174] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.829319] systemd[1]: Created slice User and Session Slice.
[ 2.829393] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.829431] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.829666] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.829698] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.829709] systemd[1]: Reached target Login Prompts.
[ 2.829727] systemd[1]: Reached target Paths.
[ 2.829738] systemd[1]: Reached target Remote File Systems.
[ 2.829748] systemd[1]: Reached target Slices.
[ 2.829771] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 2.829826] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.829902] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.830506] systemd[1]: Listening on Process Core Dump Socket.
[ 2.830611] systemd[1]: Listening on Journal Audit Socket.
[ 2.830682] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.830751] systemd[1]: Listening on Journal Socket.
[ 2.831148] systemd[1]: Listening on udev Control Socket.
[ 2.831206] systemd[1]: Listening on udev Kernel Socket.
[ 2.831724] systemd[1]: Mounting Huge Pages File System...
[ 2.832230] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.832762] systemd[1]: Mounting Kernel Debug File System...
[ 2.833276] systemd[1]: Mounting Kernel Trace File System...
[ 2.833885] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 2.834338] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.834897] systemd[1]: Starting Load Kernel Module configfs...
[ 2.835540] systemd[1]: Starting Load Kernel Module drm...
[ 2.836081] systemd[1]: Starting Load Kernel Module fuse...
[ 2.836468] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 2.836507] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.836603] random: lvm: uninitialized urandom read (4 bytes read)
[ 2.837306] systemd[1]: Starting Load Kernel Modules...
[ 2.837770] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.837811] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 2.838250] systemd[1]: Starting Coldplug All udev Devices...
[ 2.839131] systemd[1]: Mounted Huge Pages File System.
[ 2.839202] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.839271] systemd[1]: Mounted Kernel Debug File System.
[ 2.839332] systemd[1]: Mounted Kernel Trace File System.
[ 2.839508] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 2.839702] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.839811] systemd[1]: Finished Load Kernel Module configfs.
[ 2.839969] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.840103] systemd[1]: Finished Load Kernel Module drm.
[ 2.840661] systemd[1]: Mounting Kernel Configuration File System...
[ 2.842722] BTRFS info (device sda8): enabling auto defrag
[ 2.842724] BTRFS info (device sda8): turning on discard
[ 2.842726] BTRFS info (device sda8): use lzo compression, level 0
[ 2.842726] BTRFS info (device sda8): disk space caching is enabled
[ 2.843232] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.843334] systemd[1]: Mounted Kernel Configuration File System.
[ 2.843418] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 2.847400] fuse: init (API version 7.31)
[ 2.847417] *** VALIDATE fuse ***
[ 2.847418] *** VALIDATE fuse ***
[ 2.904575] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 2.905518] systemd[1]: Starting Load/Save Random Seed...
[ 2.905627] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 2.906636] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.907198] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.907421] systemd[1]: Finished Load Kernel Module fuse.
[ 2.909419] systemd[1]: Mounting FUSE Control File System...
[ 2.912657] systemd[1]: Mounted FUSE Control File System.
[ 2.934863] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.937263] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 2.939627] systemd[1]: Starting Journal Service...
[ 2.941513] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.968896] systemd[1]: Finished Coldplug All udev Devices.
[ 2.968933] audit: type=1130 audit(1624659617.740:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.983310] systemd[1]: Started Journal Service.
[ 2.983368] audit: type=1130 audit(1624659617.756:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.988114] systemd-journald[297]: Received client request to flush runtime journal.
[ 3.094153] nvidia: loading out-of-tree module taints kernel.
[ 3.094159] nvidia: module license 'NVIDIA' taints kernel.
[ 3.094159] Disabling lock debugging due to kernel taint
[ 3.095477] audit: type=1130 audit(1624659617.866:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.105525] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 3.106591] random: crng init done
[ 3.114279] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 3.116751] nvidia 0000:01:00.0: Refused to change power state, currently in D3
[ 3.116857] NVRM: This is a 64-bit BAR mapped above 4GB by the system
NVRM: BIOS or the Linux kernel, but the PCI bridge
NVRM: immediately upstream of this GPU does not define
NVRM: a matching prefetchable memory window.
[ 3.116858] NVRM: This may be due to a known Linux kernel bug. Please
NVRM: see the README section on 64-bit BARs for additional
NVRM: information.
[ 3.116862] nvidia: probe of 0000:01:00.0 failed with error -1
[ 3.116878] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 3.116879] NVRM: None of the NVIDIA devices were initialized.
[ 3.119131] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 3.170491] ACPI: AC Adapter [AC] (on-line)
[ 3.223747] input: Intel HID events as /devices/platform/INT33D5:00/input/input6
[ 3.224410] intel-hid INT33D5:00: platform supports 5 button array
[ 3.224429] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input7
[ 3.226065] wmi_bus wmi_bus-PNP0C14:04: WQBC data block query control method not found
[ 3.276945] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 3.281231] Linux agpgart interface v0.103
[ 3.353558] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 3.358758] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[ 3.365959] intel_rapl_common: Found RAPL domain package
[ 3.365960] intel_rapl_common: Found RAPL domain dram
[ 3.366048] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 3.417314] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 3.417885] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 3.418103] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 3.429233] i2c_hid i2c-DELL0949:00: i2c-DELL0949:00 supply vdd not found, using dummy regulator
[ 3.429245] i2c_hid i2c-DELL0949:00: i2c-DELL0949:00 supply vddl not found, using dummy regulator
[ 3.467882] audit: type=1130 audit(1624659618.240:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.491350] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491350] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491351] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491352] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491353] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491354] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491354] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491355] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491356] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.491357] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 3.497342] mce: CPU4: Core temperature/speed normal
[ 3.497343] mce: CPU7: Package temperature/speed normal
[ 3.497344] mce: CPU0: Core temperature/speed normal
[ 3.497345] mce: CPU5: Package temperature/speed normal
[ 3.497345] mce: CPU6: Package temperature/speed normal
[ 3.497346] mce: CPU2: Package temperature/speed normal
[ 3.497346] mce: CPU1: Package temperature/speed normal
[ 3.497347] mce: CPU3: Package temperature/speed normal
[ 3.497348] mce: CPU0: Package temperature/speed normal
[ 3.497348] mce: CPU4: Package temperature/speed normal
[ 3.576566] input: DELL0949:00 04F3:30CB Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0949:00/0018:04F3:30CB.0002/input/input8
[ 3.576642] input: DELL0949:00 04F3:30CB Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0949:00/0018:04F3:30CB.0002/input/input9
[ 3.576717] hid-generic 0018:04F3:30CB.0002: input,hidraw1: I2C HID v1.00 Mouse [DELL0949:00 04F3:30CB] on i2c-DELL0949:00
[ 3.621555] audit: type=1130 audit(1624659618.393:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.626633] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 3.626912] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 3.626976] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 3.627228] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[ 3.627229] fb0: switching to inteldrmfb from EFI VGA
[ 3.627265] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 3.627643] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 3.628291] NVRM: This is a 64-bit BAR mapped above 4GB by the system
[ 3.628291] NVRM: This may be due to a known Linux kernel bug. Please
NVRM: information.
[ 3.628293] nvidia: probe of 0000:01:00.0 failed with error -1
[ 3.628304] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 3.628304] NVRM: None of the NVIDIA devices were initialized.
[ 3.628651] nvidia-nvlink: Unregistered the Nvlink Core, major device number 239
[ 3.629464] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.629465] [drm] Driver supports precise vblank timestamp query.
[ 3.630766] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 3.636012] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 3.645682] Adding 2097148k swap on /dev/sda7. Priority:-2 extents:1 across:2097148k SSDscFS
[ 3.669077] i915 0000:00:02.0: Failed to program MOCS registers; expect performance issues.
[ 3.670196] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[ 3.674865] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 3.675291] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
[ 3.675416] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 3.675432] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1b/LNXVIDEO:01/input/input13
[ 3.682315] fbcon: i915drmfb (fb0) is primary device
[ 3.682316] fbcon: Deferring console take-over
[ 3.682317] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 3.735039] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 3.737976] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.743522] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 3.744154] audit: type=1130 audit(1624659618.516:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.744593] NVRM: This is a 64-bit BAR mapped above 4GB by the system
[ 3.744593] NVRM: This may be due to a known Linux kernel bug. Please
NVRM: information.
[ 3.744597] nvidia: probe of 0000:01:00.0 failed with error -1
[ 3.744606] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 3.744606] NVRM: None of the NVIDIA devices were initialized.
[ 3.744708] nvidia-nvlink: Unregistered the Nvlink Core, major device number 239
[ 3.747233] audit: type=1130 audit(1624659618.520:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.748296] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 3.749069] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 3.749070] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.749071] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.749071] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.749072] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.749072] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.752619] audit: type=1130 audit(1624659618.526:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.756993] cryptd: max_cpu_qlen set to 1000
[ 3.768308] libphy: r8169: probed
[ 3.768739] r8169 0000:03:00.0 eth0: RTL8168h/8111h, e4:54:e8:25:87:5e, XID 541, IRQ 131
[ 3.768741] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 3.809479] AVX2 version of gcm_enc/dec engaged.
[ 3.809481] AES CTR mode by8 optimization enabled
[ 3.875436] audit: type=1130 audit(1624659618.646:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-01E0\x2dC840 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.881678] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[ 3.881964] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.887670] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.948125] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3254: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 3.948127] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.948128] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 3.948129] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.948130] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.948131] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 3.948132] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1b
[ 3.960065] input: Dell WMI hotkeys as /devices/platform/PNP0C14:04/wmi_bus/wmi_bus-PNP0C14:04/PNP0C14:04-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input15
[ 4.016020] intel_rapl_common: Found RAPL domain package
[ 4.016021] intel_rapl_common: Found RAPL domain core
[ 4.016022] intel_rapl_common: Found RAPL domain uncore
[ 4.016024] intel_rapl_common: Found RAPL domain dram
[ 4.057720] iTCO_vendor_support: vendor-support=0
[ 4.064783] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 4.066216] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 4.071072] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 4.071164] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.073878] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 4.076174] NVRM: This is a 64-bit BAR mapped above 4GB by the system
[ 4.076175] NVRM: This may be due to a known Linux kernel bug. Please
NVRM: information.
[ 4.076178] nvidia: probe of 0000:01:00.0 failed with error -1
[ 4.076187] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 4.076187] NVRM: None of the NVIDIA devices were initialized.
[ 4.077088] nvidia-nvlink: Unregistered the Nvlink Core, major device number 239
[ 4.156785] input: DELL0949:00 04F3:30CB Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0949:00/0018:04F3:30CB.0002/input/input16
[ 4.156861] input: DELL0949:00 04F3:30CB Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0949:00/0018:04F3:30CB.0002/input/input17
[ 4.156978] hid-multitouch 0018:04F3:30CB.0002: input,hidraw1: I2C HID v1.00 Mouse [DELL0949:00 04F3:30CB] on i2c-DELL0949:00
[ 4.240393] mousedev: PS/2 mouse device common for all mice
[ 4.279143] EXT4-fs (sda9): mounted filesystem with ordered data mode. Opts: discard
[ 4.290721] ath10k_pci 0000:04:00.0: enabling device (0000 -> 0002)
[ 4.294306] ath10k_pci 0000:04:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 4.308549] proc: Bad value for 'hidepid'
[ 4.308627] proc: Bad value for 'hidepid'
[ 4.488385] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input14
[ 4.525019] proc: Bad value for 'hidepid'
[ 4.577120] ath10k_pci 0000:04:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 1028:1810
[ 4.577126] ath10k_pci 0000:04:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 4.578441] ath10k_pci 0000:04:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[ 4.650761] ath10k_pci 0000:04:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 4.727262] ath10k_pci 0000:04:00.0: unsupported HTC service id: 1536
[ 4.739744] proc: Bad value for 'hidepid'
[ 4.745492] ath10k_pci 0000:04:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 4.766427] Bluetooth: Core ver 2.22
[ 4.766447] NET: Registered protocol family 31
[ 4.766448] Bluetooth: HCI device and connection manager initialized
[ 4.766450] Bluetooth: HCI socket layer initialized
[ 4.766451] Bluetooth: L2CAP socket layer initialized
[ 4.766453] Bluetooth: SCO socket layer initialized
[ 4.767151] mc: Linux media interface: v0.10
[ 4.791515] videodev: Linux video capture interface: v2.00
[ 4.819101] ath: EEPROM regdomain: 0x6c
[ 4.819102] ath: EEPROM indicates we should expect a direct regpair map
[ 4.819103] ath: Country alpha2 being used: 00
[ 4.819103] ath: Regpair used: 0x6c
[ 4.821544] ath10k_pci 0000:04:00.0 wlp4s0: renamed from wlan0
[ 4.885466] Generic FE-GE Realtek PHY r8169-300:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[ 4.902654] usbcore: registered new interface driver btusb
[ 4.940735] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.940736] Bluetooth: BNEP filters: protocol multicast
[ 4.940739] Bluetooth: BNEP socket layer initialized
[ 4.943720] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0bda:5521)
[ 4.949781] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input19
[ 4.949890] usbcore: registered new interface driver uvcvideo
[ 4.949891] USB Video Class driver (1.1.1)
[ 4.990302] r8169 0000:03:00.0 enp3s0: Link is Down
[ 5.008924] NET: Registered protocol family 38
[ 5.173647] kauditd_printk_skb: 44 callbacks suppressed
[ 5.173648] audit: type=1130 audit(1624659619.946:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.220694] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 5.220750] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 5.220799] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 5.220851] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 5.221804] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 5.221862] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 5.295479] audit: type=1130 audit(1624659620.066:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.042680] audit: type=1100 audit(1624659621.816:57): pid=996 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7.042779] audit: type=1101 audit(1624659621.816:58): pid=996 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7.044108] audit: type=1103 audit(1624659621.816:59): pid=996 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7.072009] audit: type=1130 audit(1624659621.843:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.083665] audit: type=1101 audit(1624659621.856:61): pid=998 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.083730] audit: type=1103 audit(1624659621.856:62): pid=998 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 7.083804] audit: type=1006 audit(1624659621.856:63): pid=998 uid=0 old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=1 res=1
[ 7.085610] audit: type=1105 audit(1624659621.856:64): pid=998 uid=0 auid=970 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.868254] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 7.868407] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control off
[ 9.729480] [UFW BLOCK] IN=enp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:dd93:fb61:174f:ffee DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=73 TC=0 HOPLIMIT=255 FLOWLBL=622799 PROTO=UDP SPT=5355 DPT=5355 LEN=33
[ 9.849772] [UFW BLOCK] IN=enp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:dd93:fb61:174f:ffee DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=73 TC=0 HOPLIMIT=255 FLOWLBL=622799 PROTO=UDP SPT=5355 DPT=5355 LEN=33
[ 10.299956] [UFW BLOCK] IN=enp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:dd93:fb61:174f:ffee DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=73 TC=0 HOPLIMIT=255 FLOWLBL=622799 PROTO=UDP SPT=5355 DPT=5355 LEN=33
[ 12.231884] [UFW BLOCK] IN=enp3s0 OUT= MAC= SRC=192.168.1.2 DST=224.0.0.252 LEN=53 TOS=0x00 PREC=0x00 TTL=255 ID=51086 PROTO=UDP SPT=5355 DPT=5355 LEN=33
[ 12.309317] kauditd_printk_skb: 5 callbacks suppressed
[ 12.309318] audit: type=1100 audit(1624659627.083:70): pid=1050 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="arno" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 12.310435] audit: type=1101 audit(1624659627.083:71): pid=1050 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="arno" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 12.310700] audit: type=1103 audit(1624659627.083:72): pid=1050 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="arno" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 12.310767] audit: type=1006 audit(1624659627.083:73): pid=1050 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 12.323892] audit: type=1130 audit(1624659627.096:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.328280] audit: type=1101 audit(1624659627.100:75): pid=1052 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="arno" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.328282] audit: type=1103 audit(1624659627.100:76): pid=1052 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="arno" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 12.328341] audit: type=1006 audit(1624659627.100:77): pid=1052 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 12.329248] audit: type=1105 audit(1624659627.103:78): pid=1052 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="arno" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.332820] [UFW BLOCK] IN=enp3s0 OUT= MAC= SRC=192.168.1.2 DST=224.0.0.252 LEN=53 TOS=0x00 PREC=0x00 TTL=255 ID=51095 PROTO=UDP SPT=5355 DPT=5355 LEN=33
[ 12.408836] audit: type=1130 audit(1624659627.180:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.582791] [UFW BLOCK] IN=enp3s0 OUT= MAC= SRC=192.168.1.2 DST=224.0.0.252 LEN=53 TOS=0x00 PREC=0x00 TTL=255 ID=51109 PROTO=UDP SPT=5355 DPT=5355 LEN=33
[ 13.984006] Bluetooth: RFCOMM TTY layer initialized
[ 13.984023] Bluetooth: RFCOMM socket layer initialized
[ 13.984032] Bluetooth: RFCOMM ver 1.11
[ 18.989077] kauditd_printk_skb: 5 callbacks suppressed
[ 18.989078] audit: type=1701 audit(1624659633.763:85): auid=1000 uid=1000 gid=1000 ses=2 pid=1179 comm=5468726561642028706F6F6C656429 exe="/usr/lib/baloo_file" sig=11 res=1
[ 19.007881] audit: type=1130 audit(1624659633.780:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1376-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.147278] audit: type=1131 audit(1624659633.920:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1376-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.599146] audit: type=1131 audit(1624659637.373:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.605075] audit: type=1131 audit(1624659637.376:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.976396] audit: type=1131 audit(1624659627.101:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.177341] audit: type=1100 audit(1624659631.301:91): pid=1455 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="arno" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 39.178361] audit: type=1101 audit(1624659631.301:92): pid=1455 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="arno" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 39.178522] audit: type=1110 audit(1624659631.301:93): pid=1455 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 39.179911] audit: type=1105 audit(1624659631.304:94): pid=1455 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Things I’ve tried, with no success:
- Reinstalling the nvidia drivers through mhwd;
- Booting up using acpi_osi=‘Windows 2019’;
- Booting up using acpi_osi=! acpi_osi=‘Windows 2019’;
I’m not very good at troubleshooting so, I’m stuck.
I would appreciate if someone could help me.
Arno.
My System Info
System: Host: arno-pc Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: G3 3590 v: N/A serial: <superuser required>
Mobo: Dell model: 02RJ9R v: A00 serial: <superuser required> UEFI: Dell v: 1.11.1 date: 08/19/2020
Battery: ID-1: BAT0 charge: 45.2 Wh (100.0%) condition: 45.2/51.0 Wh (88.6%)
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP cache: L2: 8 MiB
Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 901 3: 900 4: 900 5: 900 6: 900 7: 899 8: 900
Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] driver: N/A
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: XOrg 1.20.11 driver: loaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.2
Audio: Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: e4:54:e8:25:87:5e
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter driver: ath10k_pci
IF: wlp4s0 state: down mac: 0a:f5:2a:a6:f0:ea
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 447.13 GiB used: 67.48 GiB (15.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
Partition: ID-1: / size: 124.63 GiB used: 46.82 GiB (37.6%) fs: btrfs dev: /dev/sda8
ID-2: /boot/efi size: 511 MiB used: 652 KiB (0.1%) fs: vfat dev: /dev/sda6
ID-3: /home size: 78.24 GiB used: 20.66 GiB (26.4%) fs: ext4 dev: /dev/sda9
Swap: ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) dev: /dev/sda7
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
Info: Processes: 229 Uptime: 25m Memory: 7.61 GiB used: 3.04 GiB (40.0%) Shell: Zsh inxi: 3.3.04
