I have done a fresh install of Manjaro KDE Plasma yesterday on my desktop with a intel g630 processor on an intel h61 motherboard. I am getting no sound through my headphones.
I have installed sof-firmware, checked alsamixer for mute option, installed pulseaudio, but still no sound.
I have also observed that i get no sound also with the live usb. Could this be a driver issue. the sound card is detected though default:0 HDA Intel PCH in alsamixer but no sound.
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e8bc41aa-abbe-47ed-86a9-179b005d068c rw quiet apparmor=1
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 07/19/2017
RAM: total: 3.8 GiB used: 2.69 GiB (70.8%)
Info: Dual Core model: Intel Pentium G630 bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB bogomips: 10778
Speed: 2646 MHz min/max: 1600/2700 MHz Core speeds (MHz): 1: 2195 2: 1671
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d fpu fxsr ht
ibpb ibrs lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl
nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tsc tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: Gigabyte driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: DVI-I-1 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
diag: 508mm (20")
OpenGL: renderer: NV117 v: 4.3 Mesa 21.2.5 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 40.26 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-1: / raw-size: 62.5 GiB size: 61.22 GiB (97.95%) used: 9.29 GiB (15.2%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: e8bc41aa-abbe-47ed-86a9-179b005d068c
ID-2: /home raw-size: 118.15 GiB size: 115.79 GiB (98.01%)
used: 30.97 GiB (26.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 9638fd33-0b77-45de-aa2c-9c72d883d59d
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: 70AA09D0AA0993AE
ID-2: /dev/sda2 maj-min: 8:2 size: 489.03 GiB fs: ntfs label: N/A
uuid: 3EE2D934E2D8F15F
ID-3: /dev/sda3 maj-min: 8:3 size: 261.74 GiB fs: ntfs label: Local Disk
uuid: 1EA01013A00FEFD7
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.3:3 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-2: 2-1.4:4 info: China Resource Semico Keyboard type: Keyboard,HID
power: 100mA chip-ID: 1a2c:2d23 class-ID: 0300
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 41.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 930
Processes: 171 Uptime: 3h 38m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1212 lib: 334
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.09
Any pointers would be much appreciated
