Hi friendly people. I’m writing this from a Manjaro Plasma live USB.
After I changed my kernel, something happened and my install won’t boot anymore.
I’m assuming that the kernel GRUB’s pointing to doesn’t exist.
I’ve chrooted in, remade the GRUB config and updated GRUB, but that didn’t fix it.
I tried reinstalling a more stable kernel (4.19), but that isn’t working, with a pacman error message.
[manjaro@manjaro ~]$ uname -a
Linux manjaro 5.8.16-2-MANJARO #1 SMP PREEMPT Mon Oct 19 11:33:03 UTC 2020 x86_64 GNU/Linux
[manjaro@manjaro ~]$ manjaro-chroot /mnt /bin/bash
[manjaro /]# uname -a
[manjaro /]# mhwd-kernel -li
Currently running: 5.8.16-2-MANJARO (linux58)
* linux54
[manjaro /]# mhwd-kernel -i linux419
core [###] 100%
extra [###] 100%
community [###] 100%
multilib [###] 100%
error: no targets specified (use -h for help)
[manjaro /]#
The laptop boots to a black screen. The screen where the GRUB choices would be is black and doesn’t show the installed theme (although it does seem to wait the specified 10 seconds to begin booting according to the laptop). After that it just hangs there blankly.
GRUB’s menu is here again, but now my Windows partition is missing from the list, and booting to the Manjaro install returns ‘no irq handler for vector’ five or six times and then hangs again.
Alternately, could reinstalling Manjaro be a faster choice to be able to work again? If so, do you know of a non-destructive way I could just reinstall the system and have my files, programs and preferences remain there? (the old system was Manj. 20 Plasma if that helps at all)
Well, if you have /home on a separate partition, then you can reinstall without formatting /home. If not, then I hope you have backups.
The good news is that the live USB contains timeshift, so you can use that for making a backup to another drive. Or, you could copy over your files manually, of course.
Specifying --efi-directory=/boot/efi and the related flags doesn’t help it either.
Since the partition can be mounted I think I’ll copy what I need and reinstall it, taking note to backup regularly this time and be a bit less careless when changing the kernel.
Oh and thanks for your help, this is likely one of the nicest experiences I’ve had on a public forum.
