Hallo,
Will hier inventur durchführen, einer von beiden wird verschenkt
L350D
user@user-satellitel350d ~]$ inxi -F
Host: user-satellitel350d Kernel: 5.10.79-1-MANJARO x86_64 bits: 64
Desktop: Cinnamon 5.0.7 Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: Satellite L350D v: PSLE4E-001002GR
serial: <superuser required>
Mobo: TOSHIBA model: Portable PC serial: <superuser required> BIOS: Insyde
v: 1.80 date: 09/01/2009
ID-1: BAT0 charge: 28.2 Wh (100.0%) condition: 28.2/44.4 Wh (63.5%)
volts: 11.1 min: 11.1
Info: Dual Core model: AMD Athlon X2 QL-64 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed: 2100 MHz min/max: 1050/2100 MHz Core speeds (MHz): 1: 2100 2: 2100
Device-1: AMD RS780MC [Mobility Radeon HD 3100] driver: radeon v: kernel
Device-2: Chicony Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.21.1.1 driver: loaded: ati,radeon
unloaded: modesetting resolution: 1440x900~60Hz
OpenGL: renderer: AMD RS780 (DRM 2.50.0 / 5.10.79-1-MANJARO LLVM 13.0.0)
v: 3.3 Mesa 21.2.5
Device-1: AMD SBx00 Azalia driver: snd_hda_intel
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
IF: enp4s0 state: down mac: 00:1e:33:fd:b7:6e
Device-2: Realtek RTL8187B Wireless Adapter type: USB driver: rtl8187
IF: wlp0s18f2u6 state: up mac: 70:1a:04:4b:59:9d
Local Storage: total: 2.73 TiB used: 190.69 GiB (6.8%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
ID-2: /dev/sdb type: USB vendor: Western Digital
model: WD My Passport 2599 size: 1.82 TiB
ID-1: / size: 435.2 GiB used: 9.86 GiB (2.3%) fs: ext4 dev: /dev/sda4
System Temperatures: cpu: 75.8 C mobo: N/A
Processes: 186 Uptime: 1d 1h 11m Memory: 3.59 GiB used: 1.63 GiB (45.5%)
Shell: Bash inxi: 3.3.08
[user@user-satellitel350d ~]$
L500
[wladimir@wladimir-pc ~]$ inxi -F
Host: wladimir-pc Kernel: 5.4.134-1-MANJARO x86_64 bits: 64
Desktop: Cinnamon 5.0.5 Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: Satellite L500 v: PSLJ3E-00V01JGR
Mobo: TOSHIBA model: KSWAA v: 1.00 serial: <superuser required>
BIOS: TOSHIBA v: 1.40 date: 07/10/2009
ID-1: BAT1 charge: 43.7 Wh (93.8%) condition: 46.6/43.2 Wh (107.8%)
Info: Dual Core model: Intel Core2 Duo T6500 bits: 64 type: MCP cache:
L2: 2 MiB
Speed: 1310 MHz min/max: 1200/2100 MHz Core speeds (MHz): 1: 1310 2: 1398
Device-1: AMD RV730/M96 [Mobility Radeon HD 4650/5165] driver: radeon
v: kernel
Device-2: Chicony USB2.0 UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon
unloaded: modesetting s-res: 1366x768
OpenGL: renderer: AMD RV730 (DRM 2.50.0 / 5.4.134-1-MANJARO LLVM 12.0.1)
v: 3.3 Mesa 21.1.5
Device-1: Intel 82801I HD Audio driver: snd_hda_intel
Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
Sound Server-1: ALSA v: k5.4.134-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
IF: enp14s0 state: down mac: 00:23:5a:fc:34:c5
Device-2: Intel WiFi Link 5100 driver: iwlwifi
IF: wlp20s0 state: up mac: 00:1e:65:46:e5:b4
Local Storage: total: 111.79 GiB used: 22.66 GiB (20.3%)
ID-1: /dev/sda vendor: Hitachi model: HTS543212L9A300 size: 111.79 GiB
ID-1: / size: 26.62 GiB used: 16.04 GiB (60.3%) fs: ext4 dev: /dev/sda7
ID-2: /home size: 25.25 GiB used: 6.62 GiB (26.2%) fs: ext4 dev: /dev/sda9
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) dev: /dev/sda8
System Temperatures: cpu: 34.0 C mobo: N/A
Processes: 173 Uptime: 3m Memory: 3.81 GiB used: 902.3 MiB (23.1%)
Shell: Bash inxi: 3.3.06
