Weird Update Thing
During sudo pacman -Syu I get the following:
Many lines later of the same stuff as below:
error: could not read db 'extra' (Damaged tar archive)
warning: lua-sec: unknown key 'luase//wikl' in sync database
warning: lua-sec: unknown key '%PACKAGER%Ddaurnimato </daurnimatoe@archlinux.org>' in sync database
…thousands of more lines of the same.
It hasn’t yet downloaded or done anything, it just tries to read the databases, I suppose. Pamac did the same thing (presumably, difficult to say since it doesn’t show output during boot) for some minutes as the system booted up just prior to writing this.
Oh, now it stopped writing text and asks me a question I don’t know the answer to:
:: The following package cannot be upgraded due to unresolvable dependencies:
      lib32-libjpeg-turbo
Is the package a standard package that cannot be upgraded because of the corrupt tar archive and the extra db problem above, or can I just skip this and solve any issues regarding that package later?
The last thing I installed on the system was mkdocs from official (IIRC). I don’t think I installed anything else recently.
And what does this bit about the error: could not read db 'extra' (Damaged tar archive) mean exactly? The extra database seem to be a db file of some sort (unknown to me what it is), but pacman complains about a tar archive. What goes on with that? Is it an installed package archive of some sort that is corrupt? Or what?
Any ideas how to solve this? I’ll leave the pacman Terminal prompt open for now, so if there are any answers regarding that, I might go further then.
If you need any other info, let me know. I don’t know what would be beneficial for any problem solving at this time.
Thanks.
Hi, a bit of system info would help e.g. inxi -zv8. :wink:
Having checked re. lib32-libjpeg-turbo, I don’t think this in itself is a system-critical package:
pamac search lib32-libjpeg-turbo
lib32-libjpeg-turbo  3.1.0-1 [Installed]                                                              multilib
    JPEG image codec with accelerated baseline compression and decompression                                                       multilib
… and
pacman -Qii lib32-libjpeg-turbo
Version         : 3.1.0-1
Description     : JPEG image codec with accelerated baseline compression and decompression
Architecture    : x86_64
URL             : https://libjpeg-turbo.org/
Licenses        : BSD-3-Clause  IJG
Groups          : None
Provides        : libjpeg.so=8-32  libturbojpeg.so=0-32
Depends On      : lib32-glibc  libjpeg-turbo=3.1.0
Optional Deps   : None
Required By     : lib32-gdk-pixbuf2  lib32-libtiff
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 1481.52 KiB
Packager        : Antonio Rojas <arojas@archlinux.org>
Build Date      : Thu 26 Dec 2024 09:17:23 GMT
Install Date    : Tue 04 Feb 2025 12:50:07 GMT
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
Backup Files    : None
Extended Data   : pkgtype=pkg
But going down the rabbit hole, it looks like there are a number of "sub-"dependencies of these.
I found this on the Forum from a couple of years back, it should help:
sudo pacman-mirrors --api --protocol http && sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
… I wouldn’t normally recommend the second y with pacman but it won’t hurt in this case.
Thanks. Just some questions before I try yy: what do I do with the currently running upgrade session? Bail out now? (usually not recommended, I’ve read) Or wait until I get the question whether to continue with actually upgrade everything? And, what should I do with any following “can’t upgrade”? Answer “no” to everything, or “yes”?
Here’s inxi:
$ inxi -zv8
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=f290e441-0fef-4f6b-9fb8-63927be335fc rw quiet apparmor=1
    security=apparmor resume=UUID=12615ef3-e1cd-4601-b201-f5b428b9c8c2
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop Mobo: Acer model: Aspire XC-605 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: P11-B0
    date: 07/07/2014
  System RAM: total: 8 GiB available: 7.7 GiB used: 2.28 GiB (29.7%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: curr: 2 min: 1.35 max: 2 width (bits): data: 64
    total: 64 manufacturer: Hynix/Hyundai part-no: HMT451U6BFR8A-PB
    serial: <filter>
  Device-2: DIMM2 type: DDR3 detail: synchronous size: 4 GiB
    serial: <filter>
  Info: model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell gen: core 4
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3392 min/max: 800/3400 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 3392 2: 3392 3: 3392 4: 3392 bogomips: 25554
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Caicos XT [Radeon HD 7470/8470 /
    R5 235/310 OEM] vendor: PC Partner / Sapphire driver: radeon v: kernel
    alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
    built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports:
    active: HDMI-A-1 empty: DVI-I-1 bus-ID: 01:00.0 chip-ID: 1002:6778
    class-ID: 0300 temp: 40.5 C
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 model: Dell U2312HM serial: <filter>
    built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
    chroma: red: x: 0.639 y: 0.333 green: x: 0.310 y: 0.627 blue: x: 0.153
    y: 0.071 white: x: 0.314 y: 0.329 size: 510x287mm (20.08x11.3")
    diag: 585mm (23") ratio: 16:9 modes: 1920x1080, 1280x1024, 1152x864,
    1024x768, 800x600, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 x11: drv: r600
    inactive: wayland
  API: OpenGL v: 4.5 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD CAICOS (DRM 2.50.0 / 6.6.65-1-MANJARO LLVM
    18.1.8) device-ID: 1002:6778 memory: 1.95 GiB unified: no
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 8 Series/C220 Series High Definition Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Caicos HDMI Audio [Radeon HD
    6450 / 7450/8450/8490 OEM R5 230/235/235X OEM]
    vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa98 class-ID: 0403
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Local Storage: total: 931.51 GiB used: 798.21 GiB (85.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-21M2NA0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GHC0N rev: 1.00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 798.21 GiB (88.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: f290e441-0fef-4f6b-9fb8-63927be335fc
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 19F7-7B5E
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 12615ef3-e1cd-4601-b201-f5b428b9c8c2
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 3-1:2 info: Areson Corp 2.4G Wireless Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 25a7:fa10 class-ID: 0301
  Device-2: 3-4:3 info: Holtek USB Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a0cd class-ID: 0300
  Device-3: 3-8:4 info: Realtek 3-in-1 (SD/SDHC/SDXC) Card Reader
    type: mass storage driver: ums-realtek interfaces: 1 rev: 2.0
    chip-ID: 0bda:0153 class-ID: 0806 serial: <filter>
  Device-4: 3-9:5 info: Wacom CTL-470 [Bamboo Connect] type: mouse,HID
    driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 056a:00dd class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 61.0 C pch: 46.0 C mobo: N/A gpu: radeon
    temp: 40.5 C
  Fan Speeds (rpm): N/A
  Packages: 2367 pm: pacman pkgs: 2361 libs: 483 tools: pamac pm: flatpak
    pkgs: 6
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://manjaro.ynh.ovh/stable/$repo/$arch
    3: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 204
  1: cpu: 99.7% command: pamac-checkupdates pid: 15350 mem: 50.6 MiB (0.6%)
  2: cpu: 6.8% command: pacman pid: 3577 mem: 43.8 MiB (0.5%)
  3: cpu: 5.0% command: kwin_x11 pid: 1334 mem: 185.6 MiB (2.3%)
  4: cpu: 4.2% command: firefox pid: 2806 mem: 486.5 MiB (6.1%)
  5: cpu: 3.7% command: Xorg pid: 1172 mem: 85.0 MiB (1.0%)
  Memory top: 5 of 204
  1: mem: 486.5 MiB (6.1%) command: firefox pid: 2806 cpu: 4.2%
  2: mem: 380.1 MiB (4.8%) command: plasmashell pid: 1350 cpu: 2.8%
  3: mem: 300.1 MiB (3.8%) command: firefox pid: 2940 cpu: 0.3%
  4: mem: 266.9 MiB (3.3%) command: firefox pid: 3001 cpu: 3.2%
  5: mem: 185.6 MiB (2.3%) command: kwin_x11 pid: 1334 cpu: 5.0%
  Processes: 204 Power: uptime: 2h 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
If installation hasn’t started, you should be able to quit with CTRL + C.
If it is already installing (which doesn’t appear to be the case here), be sure to have a USB stick on hand with the Manjaro installer on it, since the upgrade process, once started, will first remove (at least pointers to) the old kernels, etc. which will require chroot-ing into the system to fix the kernel(s) and GRUB,
First check for sufficient disk space df -h / and then re-run the updates.
Note: I’d always have that USB stick on hand in any case! :wink:
It does look like there should be enough space judging by the inxi results, but is getting rather full!
I was on the first step of the update, not having reached the final question yet. Okay, I’ll try yy now. If I don’t return with a verdict, you know the reason. ; )
Edit:
Yes, I am in the process of cleaning old stuff up. But it takes time, I don’t want to just cram everything onto some external drive in an unordered state, because I know I will never get around to cleaning it up. ; )
Okay, I’m back. Got one issue as a result from running the upgrade in a tty.
Everything went on as it should, but there was an unknown error:
" (4/40) Reloading user manager configuration..."
That went on for “ages” and then:
See "systemctl user1000@.service" and "journalctl -xeu user@1000.service"
error: command failed to execute correctly
From journalctl:
dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
I am not entirely sure this it at the exact time of the upgrade, since I logged in to test things, but it seems to me there is a service running for showing some kind of splash screen, really…?
Anyway, the system seems to run fine. The icon for the available upgrades (that red thing with an exclamation point, or gray check box, depending on what is available) is missing. This seems to have become the norm after upgrades these days. Was the same the last time also, but a reboot solved that.
Edit:
Yes, same with that red “upgrade’s available” thing this time also, rebooting made it come back. Also, it wasn’t an exclamation point. It was an i. I turned it up side down in my mind. ; )
