Just to avoid you asking yourselves too much out of topic questions.
Also I had this issue very long time ago (I have Nvidia driver installed) but it’s been a long time since I do not have it, back then I tried to add the Nvidia modules to mkinitcpio but that didn’t help (you find as ‘solution’ on the internet to add them, or to remove them, both opposite actions), I had the shutdown hook in my mkinitcpio.conf file (but not anymore), I also reduced the stop timeout as a workaround, I’m not sure if I fixed it somehow at some point I can’t remember, but on my side I do not have this /oldroot blabla warning message (and hang for long time before shutdown) anymore.
I remember someone confirmed when uninstalling Nvidia drivers it was not doing it, so if you want to confirm it is because of Nvidia maybe try to use the open source driver for tests and try to see if it fixes it, then reinstall Nvidia drivers.
Also maybe all share your inxi -Fazy so maybe something relevant can be found in common. Here’s mine:
Kernel: 5.15.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6a81f472-9ea9-40f8-85f6-7925c4bbe742 ro quiet splash
usbhid.mousepoll=8 ipv6.disable=1 apparmor=1 security=apparmor
udev.log_priority=3 sysrq_always_enabled=1 nowatchdog
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F61 date: 07/13/2021
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L1: 384 KiB L2: 3 MiB L3: 32 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 86272
Speed: 2196 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2196 2: 2195 3: 2201 4: 2196 5: 2196 6: 2203 7: 2196 8: 2196 9: 2196
10: 2195 11: 2196 12: 2201
conditional, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 07:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1680x1050 s-dpi: 87 s-size: 490x321mm (19.3x12.6")
s-diag: 586mm (23.1")
Monitor-1: DVI-D-0 res: 1680x1050 dpi: 87 size: 490x320mm (19.3x12.6")
diag: 585mm (23")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.15.4-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.03 TiB used: 1.13 TiB (55.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR020 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
size: 447.14 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5001AALS-00E3A0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1D05
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDHP256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6RL scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.6 GiB (98.32%)
used: 799.05 GiB (87.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 9.1 MiB (3.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 256 MiB used: 0 KiB (0.0%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 6%
Processes: 278 Uptime: 2h 32m wakeups: 0 Memory: 15.63 GiB
used: 3.67 GiB (23.5%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1590 lib: 403 Shell: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.09
