On low battery, I am getting a weird screen, Manjaro shows “Hibernating Soon” and then hibernates.
On plugging charger, I am getting weird glitchy screen.
https:// i.imgur .com/c8VddcW.jpeg
No other way except hard reboot.
PS:
I am unable to post screenshot/link.
Please review link, removing the spaces.
DE: GNOME 41.3
WM: Wayland
Kernel: 5.15.19-1-MANJARO
Version: Manjaro 21.2-pre
GPU Drivers: amdgpu
Hi @hackingguy, and welcome!
While I don’t know what caused, or causes the screen, I can point you in this direction:
The info specified here would be necessary to get assistance.
@hackingguy Can you share the specs of your monitor ?
I had something like this but it had nothing to do with Charging
It was with the monitor I had which I broke after fiddling with refresh rate
Hi @Unbeknownst
Its not a monitor, I am using Laptop.
Laptop Model: Acer Nitro 5 AN515-42G
Refresh Rate: 60.02 Hz
Resolution: 1920x1080
Integrated Graphics: AMD Vega 8 (Display Graphics)
Usually its fine, this only happens when battery gets died and I plug in to charging!
I am also using a secondary screen, both of them show same glitchy screen!
I know… I too use laptop but your laptop screen or Monitor also has some specs sheets…
Never mind… The problem I thought didn’t lied there
Have a good day
Sry I could not help you with that but yeah best of luck for fixing your monitor
