Weird GUI behavior (window focus) in Plasma Manjaro since September
Since around September, I’ve been experiencing strange GUI issues in my Plasma environment on Manjaro (latest stable release) with a laptop that has a functional touch screen. The problems happen frequently — usually after using the system for a few hours — and fall into two main categories:
  1. Window becomes click-through.
    a. When I bring a window (Window A) to the front and place the mouse over it, the cursor shape changes according to the window behind it (Window B). Clicking in this situation interacts with Window B instead of Window A.
    b. I can temporarily fix this by locking and unlocking the system (Super + L).
  2. Automatic clicking at the top-left corner
    a. It feels like there are frequent automatic clicks at the top-left corner of the screen.
    b. When a window is maximized, it quickly becomes un-maximized, as if its title bar was double-clicked.
    c. When no window is maximized, the desktop’s top-left icon gets selected.
    d. Pressing the Super key opens the application menu, but it soon collapses automatically.
    e. The only way I’ve found to stop this is to restart the system.
journalctl logs:
10月 20 19:19:39 strawhat-v3 kernel: **Bluetooth: hci0: No support for \_PRR ACPI method**
10月 20 19:19:39 strawhat-v3 kernel: **i2c i2c-20: SMBus Timeout!**
10月 20 19:19:39 strawhat-v3 kernel: **i2c i2c-20: Failed reset at end of transaction (01)**
10月 20 19:19:39 strawhat-v3 kernel: **i2c i2c-20: Failed! (01)**
10月 20 19:19:40 strawhat-v3 bluetoothd\[778\]: **src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters**
10月 20 19:22:54 strawhat-v3 dbus-broker-launch\[773\]: **Activation request for 'org.bluez' failed.**
10月 20 19:22:54 strawhat-v3 dbus-broker-launch\[773\]: **Activation request for 'org.freedesktop.nm_dispatcher' failed.**
10月 20 19:22:54 strawhat-v3 systemd-coredump\[4873\]: **Failed to send coredump datagram: Broken pipe**
10月 20 19:22:55 strawhat-v3 dbus-broker-launch\[773\]: **Activation request for 'org.freedesktop.nm_dispatcher' failed.**
10月 20 19:22:55 strawhat-v3 kernel: **watchdog: watchdog0: watchdog did not stop!**
system info
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=532ca4eb-0598-4b2e-a1d8-0348c5a8fbd8 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Detachable System: Micro (HK) Tech product: V3 v: N/A
    serial: <superuser required>
  Mobo: Shenzhen Meigao Equipment model: HPPAC serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.05
    date: 04/10/2024
  ID-1: BATT charge: 39.8 Wh (98.5%) condition: 40.4/50.8 Wh (79.6%)
    volts: 12.97 min: 11.55 model: Standard SR Real Battery type: Li-ion
    serial: <filter> charging: status: charging cycles: 46
  Device-1: hid-0018:222A:550D.0003-battery model: PNP0C50:00 222A:550D
    serial: N/A charge: N/A status: N/A
  System RAM: total: 32 GiB available: 25.23 GiB used: 7.75 GiB (30.7%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
    part-no: H9JCNNNFA5MLYR-N6E serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8840U w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705208
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1333 min/max: 400/3301 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1333 2: 1333 3: 1333
    4: 1333 5: 1333 6: 1333 7: 1333 8: 1333 9: 1333 10: 1333 11: 1333 12: 1333
    13: 1333 14: 1333 15: 1333 16: 1333 bogomips: 105447
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] HawkPoint1 driver: amdgpu
    v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1 bus-ID: c4:00.0
    chip-ID: 1002:1900 class-ID: 0300 temp: 37.0 C
  Device-2: Sunplus Innovation Hy-Usb2.0-1 MIC driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 1bcf:2ce4
  Device-3: Kingcome USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 2b7e:c705
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0ad6 built: 2021 res:
    mode: 2560x1600 hz: 165 scale: 130% (1.3) to: 1969x1231 dpi: 216 gamma: 1.2
    chroma: red: x: 0.682 y: 0.322 green: x: 0.263 y: 0.690 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 301x188mm (11.85x7.4")
    diag: 355mm (14") ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
    phoenix LLVM 20.1.8 DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:1900
    memory: 5.86 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: AMD
    Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:1900 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: c4:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: c4:00.5 chip-ID: 1022:15e2 class-ID: 0480
    bus-ID: c4:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Sunplus Innovation Hy-Usb2.0-1 MIC driver: uvcvideo type: USB
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  IF-ID-2: ztnfaeeezi state: unknown speed: 10000 Mbps duplex: full
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 737.45 GiB (77.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PGP41024Q-A0
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 25.9 C
    scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
    used: 737.45 GiB (78.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 532ca4eb-0598-4b2e-a1d8-0348c5a8fbd8
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 3FE0-C8AF
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-1:2 info: Sunplus Innovation Hy-Usb2.0-1 MIC type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:2ce4 class-ID: 0e02
    serial: <filter>
  Device-2: 1-2:3 info: Jing-Mold Enterprise USB Keyboard
    type: keyboard,mouse driver: hid-generic,hid-multitouch,usbhid interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 05af:326a class-ID: 0301
  Device-3: 1-3:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:6092 class-ID: ef00 serial: <filter>
  Device-4: 1-5:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Kingcome USB2.0 FHD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 2b7e:c705 class-ID: fe01
    serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 40.1 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): N/A
  Packages: 1971 pm: pacman pkgs: 1958 libs: 529 tools: pamac,yay pm: flatpak
    pkgs: 13
    1: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 449
  1: cpu: 400% command: ps pid: 20982 mem: 4.23 MiB (0.0%)
  2: cpu: 56.4% command: thunderbird pid: 3936 mem: 706.8 MiB (2.7%)
  3: cpu: 17.7% command: msedge pid: 19958 mem: 306.3 MiB (1.1%)
  4: cpu: 14.5% command: msedge pid: 2209 mem: 626.3 MiB (2.4%)
  5: cpu: 13.3% command: msedge pid: 9383 mem: 412.8 MiB (1.5%)
  Memory top: 5 of 449
  1: mem: 706.8 MiB (2.7%) command: thunderbird pid: 3936 cpu: 56.4%
  2: mem: 626.3 MiB (2.4%) command: msedge pid: 2209 cpu: 14.5%
  3: mem: 581.3 MiB (2.2%) command: plasmashell pid: 1433 cpu: 0.7%
  4: mem: 516.6 MiB (1.9%) command: msedge pid: 14149 cpu: 7.7%
  5: mem: 440.1 MiB (1.7%) command: kwin_wayland pid: 1188 cpu: 8.3%
  Processes: 449 Power: uptime: 41m states: freeze,mem,disk suspend: s2idle
    image: 10.07 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 14 Shell: Zsh v: 5.9
    default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.39
Mod Edit: Fixed formatting in “system info”
At least this one looks to be hardware related.
In case it’s linked to Plasma, you could create a new user and verify if the issue persists. if not, then the “normal” user could have some config issues. Also, you could try to clean the cache.
My thought as well. Maybe some screen cleaning spray got in?
I’d suggest disabling the touch-screen function via the settings — I don’t have a touch-screen myself so I can’t see what options are there, but I would assume this is possible.
Since this is my main PC for daily work, and the issue only happens after using it for a few hours, I will try disabling the touch screen first to see if the second issue still occurs.
Thanks for your suggestions, I’ll report back with the results.
Seems that after disabling the touch screen, everything works well. Maybe my touch screen is WASTED when accidentally dropped it on the ground in May this year. :sad:
… here we are, sorry for you.
If you actually need the touchscreen, hopefully a replacement won’t be too expensive (and hopefully will be as easy to swap as on my Lenovo T440, which also had a little accident — screen still worked but when I clipped the lid with my sleeve whilst sitting down, POOF — when I took the bezel off, the thing literally fell apart).
