Weird font rendering on KDE Appeareance System Settings
Hi!! :grinning:
Today I've noticed that I have some weird font rendering only on KDE Appearance System Settings:
It's the same issue as this:
I don't have any special setting, only the one that is suggested in the Manjaro Wiki.
Curious, but this only happens on my desktop PC, my laptop it's not affected.
That's my inxi:
Summary
[albert@RYZTorre ~]$ inxi -Fxzc0
  Host: RYZTorre Kernel: 5.6.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: KDE Plasma 5.18.5 Distro: Manjaro Linux
  Type: Desktop System: Gigabyte product: B450M S2H v: N/A serial: <filter>
  Mobo: Gigabyte model: B450M S2H v: x.x serial: <filter> UEFI: American Megatrends
  v: F41 date: 07/22/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
  charge: 55% (should be ignored) status: Discharging
  Device-2: hidpp_battery_1 model: Logitech M585/M590 Multi-Device Mouse
  charge: 100% (should be ignored) status: Discharging
  Topology: Quad Core model: AMD Ryzen 3 1200 bits: 64 type: MCP arch: Zen rev: 1
  L2 cache: 2048 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 24757
  Speed: 2545 MHz min/max: 1550/3100 MHz Core speeds (MHz): 1: 2545 2: 2929 3: 2282
  4: 2256
  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ZOTAC driver: nvidia v: 440.82
  bus ID: 09:00.0
  Display: x11 server: X.Org 1.20.8 driver: nvidia tty: N/A
  OpenGL: renderer: GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82 direct render: Yes
  Device-1: NVIDIA GP108 High Definition Audio vendor: ZOTAC driver: snd_hda_intel
  v: kernel bus ID: 09:00.1
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
  bus ID: 0b:00.3
  Sound Server: ALSA v: k5.6.12-1-MANJARO
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
  driver: r8169 v: kernel port: f000 bus ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 931.52 GiB used: 424.12 GiB (45.5%)
  ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST500LM030-1RK17D size: 465.76 GiB
  ID-1: / size: 19.56 GiB used: 13.45 GiB (68.7%) fs: ext4 dev: /dev/sda7
  ID-2: /home size: 356.91 GiB used: 142.24 GiB (39.9%) fs: ext4 dev: /dev/sda8
  ID-3: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
  System Temperatures: cpu: 31.8 C mobo: N/A gpu: nvidia temp: 40 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
  Processes: 278 Uptime: 31m Memory: 15.65 GiB used: 3.96 GiB (25.3%) Init: systemd
  Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16 inxi: 3.0.37
I have no idea how could I fix this...
:grinning:
Hello, try this
On testing is no longer an issue by the way ... so it should be soon on stable too.
Your fix works!! :clap: :clap: :clap:
However, I'm going to revert your change because if this it's not anymore an issue on Testing I prefer to wait for the next Stable update.
Thank you very much!! :grinning: :grinning:
The thing is, i'm on testing but now i can't quite be sure if was my edit or the update that had the edit and kept it fixed ... muahahaha
It's your edit. I've tried :smiley:
