I’m seeing this oddly blinking on the splash screen since the fresh install. I’ve also tried switching kernel & everything neither it’s a downloaded splash screen bug.
https://giphy.com/gifs/5DsJmpX5S3NlfOZKZ4
Kernel: 5.14.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=261e3e34-3aa2-4cb0-85bb-1358fb778207 rw quiet udev.log_priority=3
acpi_backlight=native idle=nomwait processor.max_cstate=5
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUS Laptop X505ZA_X505ZA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X505ZA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X505ZA.313 date: 02/25/2020
ID-1: BAT0 charge: 22.3 Wh (95.7%) condition: 23.3/42.1 Wh (55.4%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 1041
RAM: total: 6.73 GiB used: 3.02 GiB (44.8%)
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 8101007 cache: L2: 2 MiB bogomips: 31952
Speed: 1549 MHz min/max: 1600/2000 MHz boost: disabled Core speeds (MHz):
1: 1549 2: 1504 3: 1609 4: 1369 5: 1564 6: 1260 7: 1403 8: 1449
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall
tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.1:3 chip-ID: 13d3:5a03 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.42.0
5.14.0-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.32 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 02:00.0
bus-ID: 3-2.2:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 48.45 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 82.12 GiB size: 80.28 GiB (97.76%) used: 48.41 GiB (60.3%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 261e3e34-3aa2-4cb0-85bb-1358fb778207
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 36.6 MiB (14.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 226E-201B
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 356.67 GiB fs: ntfs label: OS
uuid: DE1E71131E70E5C5
ID-3: /dev/sda5 maj-min: 8:5 size: 468.6 GiB fs: ntfs label: New Volume
uuid: 0402A78D02A78272
ID-4: /dev/sda7 maj-min: 8:7 size: 850 MiB fs: ntfs label: RECOVERY
uuid: A04AD8624AD8372E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 3-2.1:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Device-2: 3-2.2:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 71.6 C mobo: 71.0 C gpu: amdgpu temp: 71.0 C
Fan Speeds (RPM): cpu: 0
Processes: 276 Uptime: 3m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1149 lib: 298 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
