Hello Manjaro Community,
I’m relatively new to Linux and could use some guidance on how to tackle this issue. Your assistance would be greatly appreciated.
So I’ve recently encountered an issue with my screen brightness. Unfortunately, I can’t pinpoint what triggered it, as I only noticed it recently. I’ve scoured the forums and tried several solutions, but the problem persists.
The core problem is that my screen brightness remains fixed at a constant level, regardless of my attempts to adjust it.
Here’s what I’ve done so far:
I added the i915.enable_dpcd_backlight=0
boot parameter to GRUB_CMDLINE_LINUX_DEFAULT
in the /etc/default/grub
file. Afterward, I ran the following command: sudo update-grub
and rebooted my system. However, this didn’t resolve the issue.
I also attempted using the acpi_backlight=video
option, which brought back the brightness control interface when I used the function keys (F5 and F6). Furthermore, when I ran the brightnessctl
command, it reported a change in brightness levels, as shown below::
Device 'acpi_video0' of class 'backlight':
Current brightness: 1 (7%)
Max brightness: 15
This is an improvement from the previous state, where brightnessctl
would show no change and the brightness control interface wouldn’t show up when using the function keys. However, despite these indications of adjustments, there is no observable change in screen brightness and it remains excessively bright as before… (I also tried the same with vendor and native)
If it helps to with the issue, I’ve read that ThinkPad laptops, such as my ThinkPad X13, typically utilize ACPI for screen brightness control.
Edit; Additional info
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=cbfd4763-2607-4b8c-ab5f-d49265f317d1 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 acpi_backlight=video
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: LENOVO product: 20XHCTO1WW v: ThinkPad X13 Gen 2a
Mobo: LENOVO model: 20XHCTO1WW serial: <superuser required> UEFI: LENOVO
v: R1NET56W (1.26) date: 02/21/2023
ID-1: BAT0 charge: 45.4 Wh (83.6%) condition: 54.3/54.7 Wh (99.3%)
power: 15.9 W volts: 16.4 min: 15.4 model: Sunwoda 5B10W51820 type: Li-poly
serial: <filter> status: discharging cycles: 22
System RAM: total: 16 GiB note: est. available: 14.46 GiB
used: 3.49 GiB (24.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 PRO 5650U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1519 high: 2389 min/max: 1600/4288 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1450
3: 1444 4: 1445 5: 2389 6: 1429 7: 1360 8: 1449 9: 1737 10: 1366 11: 1371
12: 1397 bogomips: 55092
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: N/A alternate: amdgpu arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.0 chip-ID: 1002:1638
class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 04f2:b70f
Display: wayland server: X.Org v: 23.2.1 with: Xwayland v: 23.2.1
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: Unknown-1 mapped: None-1 res: 1920x1200 hz: 60 dpi: 96
size: 508x317mm (20x12.48") modes: 1920x1200
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 14.12 GiB unified: yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:3
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 42.84 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA1T0TFK
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 7003V5LN temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 42.84 GiB (4.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: cbfd4763-2607-4b8c-ab5f-d49265f317d1
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D6D6-314E
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: Chicony Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b70f class-ID: 0e02
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
Device-2: 5-4:3 info: Foxconn / Hon Hai MediaTek Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 3 rev: 2.1
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2500 fan-2: 2500
Processes: 302 Uptime: 49m wakeups: 36510 Init: systemd v: 254
Packages: 2732 pm: pacman pkgs: 1366 libs: 384
tools: gnome-software,pamac,yay pm: rpm pkgs: N/A note: see --rpm tools: dnf
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.30
