I can’t seem to configure my graphics drivers. Every configuration I try has issues. I already read a lot in the Arch Wiki and beginning to get a bit frustrated.
When I use Intel graphics only, the system is way too slow to work on it. Well, that was in the beginning when I had the Intel/PRIME drivers which were installed during the installation.
I then tried the Reverse PRIME mode (seems to be the same as NVidia only) which brings good results at first glance, but when I reboot I get an issue with the cursor. The are around it is smaller or blinking, which is quite annoying. I also have a multimonitor setup and the laptop screen is flickering at times. This is the xorg.conf from the Arch Wiki I am using. I added Full Composition Pipeline to get rid of the tearing.
Section "ServerLayout"
Identifier "layout"
Screen 0 "intel"
Inactive "nvidia"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "nvidia"
Option "metamodes" "DP-0.1: nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-0.2: nvidia-auto-select +2560+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Device "nvidia"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
I then tried the NVidia settings xorg.conf
file, which works well for the two external monitors, but then the laptop screen doesn’t work.
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 470.63.01
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL U2518D"
HorizSync 30.0 - 90.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro T1000"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0.2"
Option "metamodes" "DP-0.1: nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-0.2: nvidia-auto-select +2559+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
No I tried getting back to the Intel driver by deleting all xorg.conf file and when I boot the machine with external monitors, I get a black screen. When I boot it without the external monitors, it works.
I have been trying for days now. NVidia on Linux is horrible
