Webdav freezing hanging
Hi,
I am facing an issue with webdav accessing a nextcloud remote folder.
After several files downloaded or viewed in Image viewer, the connecting seem to hang. Sometimes it comes back to service, but in most times not. I could wait for hours, but no luck.
I tested the access to the same nextcloud folder from another Laptop, but this Laptop does not have the issues. It is working with all files in the folder.
Where could I start looking to get closer to the issue?
Or is someone else facing the same behaviour and has a solution?
Thanx in advance
Support info:
CPU: 6-core AMD Ryzen 5 5500U with Radeon Graphics (-MT MCP-)
speed/min/max: 1397/400/4056 MHz Kernel: 6.6.75-2-MANJARO x86_64 Up: 3h 45m
Mem: 5.36/13.47 GiB (39.8%) Storage: 476.94 GiB (88.8% used) Procs: 369
Shell: Bash inxi: 3.3.37
gvfs Version 1.56.1-2
