I bought a new USB webcam. It is branded Nabo WBF 2000. When connecting, journalctl writes this:
Jän 05 21:35:13 solveig kernel: usb 1-1: new high-speed USB device number 14 using xhci_hcd
Jän 05 21:35:13 solveig kernel: usb 1-1: New USB device found, idVendor=1d6c, idProduct=0103, bcdDevice= 0.10
Jän 05 21:35:13 solveig kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jän 05 21:35:13 solveig kernel: usb 1-1: Product: webcam
Jän 05 21:35:13 solveig kernel: usb 1-1: Manufacturer: SHENZHEN Fullhan
Jän 05 21:35:13 solveig kernel: usb 1-1: SerialNumber: 20200506
Jän 05 21:35:13 solveig kernel: uvcvideo: Found UVC 1.00 device webcam (1d6c:0103)
Jän 05 21:35:13 solveig kernel: input: webcam: Fullhan Webcam as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/input/input40
Jän 05 21:35:18 solveig kernel: usb 1-1: 3:1: cannot set freq 48000 to ep 0x89
Jän 05 21:35:28 solveig kernel: usb 1-1: 5:2: cannot get min/max values for control 2 (id 5)
Jän 05 21:35:28 solveig mtp-probe[2781]: checking bus 1, device 14: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
Jän 05 21:35:28 solveig mtp-probe[2781]: bus: 1, device: 14 was not an MTP device
Jän 05 21:35:29 solveig systemd-udevd[2821]: controlC1: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Jän 05 21:35:29 solveig mtp-probe[2840]: checking bus 1, device 14: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
Jän 05 21:35:29 solveig mtp-probe[2840]: bus: 1, device: 14 was not an MTP device
To me, this looks not ok, and trying with GUVCView justifies, that the webcam is somehow recognised, but it does not work. GUVCView takes ages to start when this camera is connected. Although it provides the model in the device list, by selecting GUVCView says (after a long time):
Guvcview error: Could not start a video stream in this device.
How can I make it work? Is it missing the USB id somewhere entered (sorry I am somewhat out-dated, I cannot remember where to add missing USB devices, because I am sure this camera uses a standard driver).
