Hi Everyone,
thanks for all the valuable info and support that can be found here in the forum.
Actually, I’m not seeking help now but would like to share a solution for my problem that I could just resolve.
After the latest update all of a sudden my webcam image turned into kind of grayscale/ strange color, strange saturation, etc. I was checking several forums, long threads, but nothing really seemed to work. I was struggling to solve the issue.
Eventually, I installed guvcview , then I ran ls /dev/video* to get my camera id and after this, I applied the guvcview -d /dev/video command so in the GUI settings tab I could restore to hardware defaults and the colors immediately came back, everything okay.
I’m sharing this solution because others might also have this problem that actually was so simple to solve… after I found the right solution
Hi @d0rk4, and welcome!
Thank you for sharing! Please see Tutorial Content Creation Guide And edit your post accordingly.
Thank you!
However, could you do me a favour and:
- edit your question by pressing the 3 dots and the pencil icon
- make it into a real question
- cut and paste the solution into a reply to your own question
- click the 3 dots below your own answer to mark a solution like this:
so that the next person that has the exact same problem you just had will benefit from your post as your question will now be in the “solved” status.
(After reading the content tutorial guide, please?)
