So I just did a fresh install, updated kernel most recent non-experimental version, installed the latest lts as a backup. On hardware configuration I installed video mods setting and the other driver (I forgot what its called.) I don’t think I did anything else. Rebooted now stuck on /dev/sda2 clean.
This is my 5th attempt at installing the system I want but I can’t seem to figure out how to troubleshoot this. I looked online and none of the current instructions seem to help. Mind if someone walks me through this? I can log into tty2 and have ethernet cable attached.
(Update) forgot to mention, I have not used pamac to update my packages. This is on a thinkpad T560. Also grub menu does not show up during boot. Boot method is UEFI only, CSM disabled. Installed manjaro via USB live boot (which is still available to use). I’ll keep adding info as I think of what could be relevant. I found how to use journalctl -b but not sure how to send this log to you all as I can only use a tablet atm
SOLVED: it was indeed those other two video drivers I had installed, so the solution was tty (ctrl + alt F2) login to root. Use mhwd -li to look at the drivers installed (im assuming that is only video drivers? Someone correct me if I’m wrong). I removed all the ones I had added including video-linux, reinstalled video-linux (mhwd -i pci video-linux) rebooted and no problem
Errr not sure how to mark as solved lol
