My CPU is reaching 70% usage whilst idle. I looked at HTOP and wayland appears to be using up to 50% of that.
Does anyone have any suggestions as to what may have caused this and how to fix it? this wasn’t an issue a couple of weeks ago.
Can you post some hardware info inxi -Fza
Yes, sorry. wasnt really sure what logs would be helpful in this situation, but let me know if there are any others I should be providing
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=3dbd5efc-d3d1-4379-a733-f0c1a89e6059 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 0904 date: 09/14/2018
Info: model: Intel Core i3-8350K bits: 64 type: MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 32013
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 550.107.02
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: N/A failed: nvidia gpu: nvidia
display-ID: 0
Monitor-1: HDMI-A-1 res: 2752x1152 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia wayland: drv: swrast x11: drv: swrast
inactive: gbm,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 18.1.8 256 bits)
device-ID: ffffffff:ffffffff memory: 30.53 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 550.107.02
device-ID: 10de:1b81 surfaces: xcb,xlib,wayland
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF-ID-1: br-1494bb5b81e2 state: down mac: <filter>
IF-ID-2: br-50b69e2fbee8 state: down mac: <filter>
IF-ID-3: br-81b83e4653ad state: down mac: <filter>
IF-ID-4: br-96f2b79ea0e8 state: down mac: <filter>
IF-ID-5: br-c9e28a90d36f state: down mac: <filter>
IF-ID-6: docker0 state: down mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Local Storage: total: 22.74 TiB used: 10.91 TiB (48.0%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST22000NT001-3LS101
size: 20.01 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EURX-63T0FY0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80
ID-1: / raw-size: 833.56 GiB size: 819.4 GiB (98.30%)
used: 232.31 GiB (28.4%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 38.2 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.26 GiB used: 6.11 GiB (19.5%)
Processes: 218 Power: uptime: 4h 58m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1240 libs: 346 tools: pamac pm: flatpak pkgs: 0
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
running-in: konsole inxi: 3.3.35
This is not a very powerful processcor.
Its an i3-8350K 4 cores 4ghz. Its a couple years old and its not the top of the range but I wouldnt say its that poor performance wise? This also hasnt been an issue until a couple days ago, so im not sure its a hardware issue
This is an EOL kernel, install&switch to another one and remove it after rebooting.
I switched to 6.6.46-1 and it seems to be working alot better, Thanks
