Hello.
After a recent update to KDE Plasma 5.21, I decided to try running a wayland session.
After installing the plasma-wayland-session package, I logged into the SDDM, selected the wayland session, and logged in. After that, a black screen was displayed for a few seconds, and then the SDDM login window re-opened. In logs ~/. local/share/sddm/wayland-session.log:
wayland-session.log
No backend specified through command line argument, trying auto resolution
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5079:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5081:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5083:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5087:47: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5101:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5103:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:45: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5110:46: this compose sequence is a duplicate of another; skipping line
Compositor crashed, respawning
startplasmacompositor: Shutting down...
startplasmacompositor: Done.
If I log in to the X session and try to run command “kwin_wayland --xwayland” in the terminal, the result will be as follows:
kwin_wayland logs
kf.globalaccel.kglobalacceld: Failed to register service org.kde.kglobalaccel
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics 630 (CFL GT2)
OpenGL version string: 4.6 (Core Profile) Mesa 20.3.4
OpenGL shading language version string: 4.60
Driver: Intel
GPU class: Unknown
OpenGL version: 4.6
GLSL version: 4.60
Mesa version: 20.3.4
Linux kernel version: 5.11.1
Requires strict binding: no
GLSL shaders: yes
Texture NPOT support: yes
Virtual Machine: no
kwin_core: eglPostSubBufferNV not supported, have to enable buffer preservation - which breaks v-sync and performance
Filter multi-plane format 961959257
Filter multi-plane format 825316697
Filter multi-plane format 842093913
Filter multi-plane format 909202777
Filter multi-plane format 875713881
Filter multi-plane format 961893977
Filter multi-plane format 825316953
Filter multi-plane format 842094169
Filter multi-plane format 909203033
Filter multi-plane format 875714137
Filter multi-plane format 842094158
Filter multi-plane format 909203022
kwin_core: Failed to update gamma ramp for output KWin::X11WindowedOutput(0x55e7013289d0)
_XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Unsupported maximum keycode 569, clipping.
> X11 cannot support keycodes above 255.
Errors from xkbcomp are not fatal to the X server
QObject::connect(KWin::LibInput::Connection, QObject): invalid nullptr parameter
Can anyone suggest what might be the reason for this behavior?
