Wayland-protocols become orphan
I noticed recently that wayland-protocols become orphan.
After much searching still cannot be sure if it is secure to remove it.
Any advice would be appreciated.
thanks
A quick look into dependencies will reveal that wayland-protocols is required by gst-plugins-bad-libs that is required by gtk4. Where did you notice that orphan?
You can also take a look at the project page wayland / wayland-protocols · GitLab
A package might become orphan if becomes unnecessary, hence will be removed from repository, or becomes deprecated, but as stated in the gitlab
So, what replaces it?
Thanks @bogdancovaciu for your reply
I check once in a wile for orphans running the comand:
pamac list -o
there I got it in the list.
I checked also the “Required by” list at https://archlinux.org/packages/extra/any/wayland-protocols/ but nothing reminds me of something I uninstalled recently.
@bogdancovaciu I similarly removed wayland-protocols when it was orphaned from my KDE Wayland laptop a long time ago, and no ill effects that I can tell.
I just checked in Pamac and don’t see the dependencies that you list. And I do have qtk4 installed. It seems that the dependency is provided by wayland itself now, but I’m not sure how to confirm that using Pamac or Pacman.
And I don’t have plasma-wayland-protocols installed either. Would either package add or extend wayland functionality or be useful in any way?
You can check with:
pamac info wayland-protocols
see on my end i get this:
Version               : 1.31-1
Description           : Specifications of extended Wayland protocols
URL                   : https://wayland.freedesktop.org/
Licenses              : MIT
Repository            : extra
Installed Size        : 509,4 kB
Groups                : --
Depends On            : --
Optional Dependencies : --
Required By           : gst-plugins-bad-libs
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Sébastien Luttringer <seblu@seblu.net>
Build Date            : Vi 02 dec 2022 09:37:41 +0200
Install Date          : Du 04 dec 2022 09:23:34 +0200
Install Reason        : Installed as a dependency for another package
Validated By          : Signature
Backup files          : --
See the Requiref by so then i check:
pamac info gst-plugins-bad-libs
And i get:
Version               : 1.22.1-2
Description           : Multimedia graph framework - bad
URL                   : https://gstreamer.freedesktop.org/
Licenses              : LGPL
Repository            : extra
Installed Size        : 10,8 MB
Groups                : --
Depends On            : gst-plugins-base-libs=1.22.1 orc libdrm libx11 libgudev libusb libxkbcommon-x11 libva libnice vulkan-icd-loader wayland wayland-protocols
Required By           : gst-plugins-bad gtk4 nvidia-vaapi-driver-git webkit2gtk webkit2gtk-4.1
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Antonio Rojas <arojas@archlinux.org>
Build Date            : Mi 08 mar 2023 21:03:36 +0200
Install Date          : Vi 10 mar 2023 09:18:03 +0200
Backup files          : --
And again i check the Required by and i can conclude if i want that or not, remove it is is not relevant for my install … etc.
Also i prefer to “investigate” this way because i can know if was installed or not as as a dependency for another package.
Most of the time, nothing is installed by mistake on my end.
Hmmm… I don’t have the any Required By:
Version               : 1.31-1
Licenses              : MIT
Repository            : extra
Installed Size        : 509.4 kB
Groups                : --
Depends On            : --
Provides              : --
Replaces              : --
Conflicts With        : --
Build Date            : Fri 02 Dec 2022 02:37:41 AM EST
Validated By          : MD5 Sum  SHA-256 Sum  Signature
but I do here:
Version               : 1.22.0-3
Licenses              : LGPL
Repository            : extra
Installed Size        : 10.8 MB
Groups                : --
Depends On            : gst-plugins-base-libs=1.22.0 orc libdrm libx11 libgudev libusb libxkbcommon-x11 libva libnice vulkan-icd-loader wayland
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date            : Sun 29 Jan 2023 06:32:22 AM EST
Install Date          : Fri 03 Feb 2023 07:06:29 PM EST
Backup files          : --
This is an older version … does your package database need refreshing?
Packages shows
stable 1.22.0-3
testing 1.22.1-2
unstable 1.22.1-2
So, when stable branch gets the new version, wayland-protocols will no longer be orphaned, if gst-plugins-bad-libs is installed?
Running pactree to find the top packages depending on gst-plugins-bad-libs, so I can now decide if keep wayland-protocols or not.
In my case, they are cheese and flatpak. I do not use any of those so I can even uninstall them.
Thanks @bogdancovaciu @CarlLaFong @mishmosh for you help :smiley: :+1:
pactree -r gst-plugins-bad-libs
├─gst-plugins-bad
│ ├─cheese
│ └─gnome-video-effects
│   └─cheese
├─gtk4
│ ├─gnome-desktop-4
│ │ └─xdg-desktop-portal-gnome
│ │     └─flatpak
│ └─libadwaita
└─libcheese
  └─cheese
Good eye regarding the version number. I’m really curious now when the next snap to Stable occurs if wayland-protocols will be installed as a required dependency. Interesting stuff!
