Hello. I’m stuck at the Xfce login prompt (I enter my password, the screen goes black for a moment, then it’s back to the login screen). I think my installing qemu might have caused this; afterwards I couldn’t boot into Manjaro or Windows.
I tried using a terminal at login (Ctrl Alt F2) to no result. Any ideas or suggestions welcome.
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_220 quiet systemd.show_status=1
splash apparmor=1 security=apparmor driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20AUS02U00 v: ThinkPad L540
Mobo: LENOVO model: 20AUS02U00 serial: <superuser required> UEFI: LENOVO
v: J4ET62WW(1.62) date: 04/16/2014
ID-1: BAT0 charge: 44.1 Wh (98.0%) condition: 45.0/47.5 Wh (94.8%)
volts: 12.1 min: 10.8 model: SMP 45N1163 type: Li-ion serial: <filter>
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 7.66 GiB used: 3.33 GiB (43.4%)
Info: model: Intel Core i5-4300M bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2740 high: 2778 min/max: 800/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2736 2: 2778 3: 2695
4: 2751 bogomips: 20760
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x26ec built: 2012 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Ethernet I217-V vendor: Lenovo driver: e1000e v: kernel
port: 5080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
IF: enp0s25 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:088f
class-ID: 0280
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 3-11:5 chip-ID: 8087:07da class-ID: e001
Local Storage: total: 946.13 GiB used: 385.61 GiB (40.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: HDD HTS547550A9E384
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 1.5 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: D70F scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 14.61 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: MQ01UBD050
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: HDD
rpm: 5400 serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ8E2 rev: 1.00
dev-links: cdrom
ID-1: /mnt raw-size: 196.14 GiB size: 192.01 GiB (97.89%)
used: 61.88 GiB (32.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: a376f3a3-cdea-4abf-96f4-4bc8a6b4527f
ID-2: /mnt/boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 25.3 MiB (26.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: B8D7-6269
ID-3: /mnt/mnt raw-size: 433.76 GiB size: 425.88 GiB (98.18%)
used: 323.04 GiB (75.9%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
label: linuxconsole uuid: 0d19a8fd-2c3a-4818-9d00-5ea9752c3c21
ID-4: /mnt/mnt/data raw-size: 120 GiB size: 120 GiB (100.00%)
used: 683.7 MiB (0.6%) fs: ntfs dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 70878173517C71C2
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 149.01 GiB fs: ext4 label: N/A
uuid: 99d693b8-100e-4b55-91a7-3e72ef9a82e0
ID-3: /dev/sda5 maj-min: 8:5 size: 505 MiB fs: ntfs label: N/A
uuid: 6012B0DF12B0BAFC
ID-4: /dev/sdb1 maj-min: 8:17 size: 3.51 GiB fs: iso9660
ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 4A53-5D40
ID-6: /dev/sdc1 maj-min: 8:33 size: 32 GiB fs: vfat label: RECOVERY
uuid: 9841-38BD
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 3-3:3 info: SanDisk Ultra type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA chip-ID: 0781:5581
class-ID: 0806 serial: <filter>
Device-3: 3-6:4 info: Toshiba America External Disk USB 3.0
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 0480:a007 class-ID: 0806 serial: <filter>
Device-4: 3-11:5 info: Intel Centrino Bluetooth Wireless Transceiver
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 227 Uptime: 1h 0m wakeups: 8 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1146 libs: 318 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
