x11 works fine but when I switch to wayland on the login screen it either freezes up after entering the login details or when it does get past the login screen, everything works great except that the entire bottom menu bar/task bar is completely missing.
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=281760b5-544a-4dc9-b2ea-e41ca29ea9e9 rw quiet
cryptdevice=UUID=7262977c-d0cc-4daa-a444-725f2fc63224:luks-7262977c-d0cc-4daa-a444-725f2fc63224
root=/dev/mapper/luks-7262977c-d0cc-4daa-a444-725f2fc63224 apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.80
date: 12/25/2019
RAM: total: 15.57 GiB used: 3.53 GiB (22.7%)
RAM Report:
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xEC
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2640 high: 4796 min/max: 800/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1111
4: 4159 5: 2878 6: 2535 7: 4796 8: 4043 bogomips: 57616
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
STIBP: disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1
bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: nouveau display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer VG270 serial: <filter>
built: 2018 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: NV134 v: 4.3 Mesa 21.3.8 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v6: <filter> virtual: stable-privacy scope: link
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
bus-ID: 1-7:2 chip-ID: 8087:0a2b class-ID: e001
Device-1: luks-7262977c-d0cc-4daa-a444-725f2fc63224 maj-min: 254:0
type: LUKS dm: dm-0 size: 465.46 GiB
Components:
p-1: sdb2 maj-min: 8:18 size: 465.46 GiB
Local Storage: total: 1.36 TiB used: 88.29 GiB (6.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB model: SSK SSK Storage
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0209 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 88.29 GiB (19.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-7262977c-d0cc-4daa-a444-725f2fc63224 label: N/A
uuid: 281760b5-544a-4dc9-b2ea-e41ca29ea9e9
used: 440 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: D91E-3253
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 931.5 GiB fs: ntfs label: HDD
uuid: 0682C08F82C08521
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-7:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-9:3 info: Kingston HyperX Alloy Core RGB type: Keyboard
power: 500mA chip-ID: 0951:16dd class-ID: 0301
Device-3: 1-10:4 info: MosArt Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4102 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Device-1: 2-6:2 info: JMicron / USA JMS567 SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 896mA chip-ID: 152d:0562 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 27.8 C pch: 45.0 C mobo: N/A gpu: nouveau
temp: 39.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1247
Processes: 277 Uptime: 8m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1261 pacman: 1243 lib: 336
flatpak: 11 snap: 7 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.15
