Wayland an X11 is installed on my machine with KDE Plasma.
When I use Wayland, then the session is not restored on login.
And I have some graphic failures with Wayland: pull down menues on Libreoffice do not work correctly.
I use Plasma with Wayland - and I very much prefer Wayland over X11 - other than the rare kwin restart - I have not noticed anything unpleasant.
I never liked the session restore - so I have no experience to share - but I vaguely recall a similar topic - but that is a very, very long time ago.
You specifically mention LibreOffice - I checked - the menus inside Calc - likely the only part I use - works fine.
You will have to be a lot more specific.
https://community.kde.org/Plasma/Wayland_Showstoppers
That’s a comprehensive list of current issues with KDE Plasma + Wayland. I recommend using X11 unless you have a specific need for something in Wayland. Many of those issues will never be fixed in Plasma 5, maybe by Plasma 6…
Thanks for the answers!
Where were the questions?
