I tried to install waydroid and after some tinkering managed launch it, however while trying to enable internet access broke something, not sure what…
waydroid-container.service starts just fine, but running
waydroid session start
makes it fail.
sudo waydroid container start
gives no output and no prompt until I do
sudo waydroid session start
in a second terminal wich then makes it spit
[09:50:02] waiting 10 seconds for container to start...
[09:50:03] waiting 9 seconds for container to start...
[09:50:04] waiting 8 seconds for container to start...
[09:50:05] waiting 7 seconds for container to start...
[09:50:06] waiting 6 seconds for container to start...
[09:50:07] waiting 5 seconds for container to start...
[09:50:08] waiting 4 seconds for container to start...
[09:50:09] waiting 3 seconds for container to start...
[09:50:10] waiting 2 seconds for container to start...
[09:50:11] waiting 1 seconds for container to start...
[09:50:12] ERROR: container failed to start
[09:50:12] See also: <https://github.com/waydroid>
Run 'waydroid log' for details.
Waydroid.log
(004841) [23:32:20] % mkdir -p /dev/binderfs
(004841) [23:32:20] % mount -t binder binder /dev/binderfs
(004841) [23:32:20] % ln -s /dev/binderfs/anbox-hwbinder /dev/binderfs/anbox-vndbinder /dev/binderfs/anbox-binder /dev/binderfs/features /dev/binderfs/vndbinder /dev/binderfs/hwbinder /dev/binderfs/binder /dev/binderfs/binder-control /dev/
(004841) [23:32:20] Save config: /var/lib/waydroid/waydroid.cfg
(004841) [23:32:20] % mkdir -p /var/lib/waydroid/cache_http
(004841) [23:32:20] Download https://sourceforge.net/projects/waydroid/files/images/system/lineage/waydroid_x86_64/lineage-17.1-20220316-VANILLA-waydroid_x86_64-system.zip/download
(004841) [23:38:48] Validating system image
(004841) [23:38:50] Extracting to /var/lib/waydroid/images
(004841) [23:39:03] Save config: /var/lib/waydroid/waydroid.cfg
(004841) [23:39:03] Download https://sourceforge.net/projects/waydroid/files/images/vendor/waydroid_x86_64/lineage-17.1-20220316-MAINLINE-waydroid_x86_64-vendor.zip/download
(004841) [23:39:45] Validating vendor image
(004841) [23:39:46] Extracting to /var/lib/waydroid/images
(004841) [23:39:48] Save config: /var/lib/waydroid/waydroid.cfg
(004841) [23:39:48] % lxc-info --version
4.0.0-devel
(004841) [23:39:48] % mkdir -p /var/lib/waydroid/lxc/waydroid
(004841) [23:39:48] % cp -fpr /usr/lib/waydroid/data/configs/config_2 /var/lib/waydroid/lxc/waydroid/config
(004841) [23:39:48] % sed -i s/LXCARCH/x86_64/ /var/lib/waydroid/lxc/waydroid/config
(004841) [23:39:48] % mv /var/lib/waydroid/config_nodes /var/lib/waydroid/lxc/waydroid
(005089) [23:43:54] % chmod 666 -R /dev/binder
(005089) [23:43:54] % chmod 666 -R /dev/vndbinder
(005089) [23:43:54] % chmod 666 -R /dev/hwbinder
(005089) [23:43:54] Container manager is waiting for session to load
(005101) [23:44:20] Save session config: /var/lib/waydroid/session.cfg
(005101) [23:44:20] UserMonitor service is not even started
(005101) [23:44:20] Clipboard service is not even started
(005089) [23:44:20] % /usr/lib/waydroid/data/scripts/waydroid-net.sh start
dnsmasq: failed to create listening socket for 192.168.250.1: Address already in use
Failed to setup waydroid-net.
(005089) [23:44:20] % mount /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(005089) [23:44:21] % mount -o remount,ro /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(005089) [23:44:21] % mount /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(005089) [23:44:21] % mount -o remount,ro /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(005089) [23:44:21] % mount -o bind /var/lib/waydroid/waydroid.prop /var/lib/waydroid/rootfs/vendor/waydroid.prop
(005089) [23:44:21] % mkdir -p /var/lib/waydroid/data
(005089) [23:44:21] % mount -o bind /home/telas/.local/share/waydroid/data /var/lib/waydroid/data
(005089) [23:44:21] % umount -l /sys/fs/cgroup/schedtune
umount: /sys/fs/cgroup/schedtune: no mount point specified.
(005089) [23:44:21] % chmod 777 -R /dev/ashmem
(005089) [23:44:21] % chmod 777 -R /dev/dri
(005089) [23:44:21] % chmod 777 -R /dev/fb0
(005089) [23:44:21] % lxc-start -P /var/lib/waydroid/lxc -F -n waydroid -- /init
(005089) [23:44:21] New background process: pid=5176, output=background
(005089) [23:44:21] waiting 10 seconds for container to start...
lxc-start: waydroid: network.c: netdev_configure_server_veth: 711 No such file or directory - Failed to attach "vethKoOw5b" to bridge "waydroid0", bridge interface doesn't exist
lxc-start: waydroid: network.c: lxc_create_network_priv: 3427 No such file or directory - Failed to create network device
lxc-start: waydroid: start.c: lxc_spawn: 1843 Failed to create the network
lxc-start: waydroid: start.c: __lxc_start: 2074 Failed to spawn container "waydroid"
lxc-start: waydroid: conf.c: run_buffer: 321 Script exited with status 126
lxc-start: waydroid: start.c: lxc_end: 988 Failed to run lxc.hook.post-stop for container "waydroid"
lxc-start: waydroid: tools/lxc_start.c: main: 306 The container failed to start
lxc-start: waydroid: tools/lxc_start.c: main: 311 Additional information can be obtained by setting the --logfile and --logpriority options
(005089) [23:44:22] waiting 9 seconds for container to start...
(005089) [23:44:23] waiting 8 seconds for container to start...
(005089) [23:44:24] waiting 7 seconds for container to start...
(005089) [23:44:25] waiting 6 seconds for container to start...
(005089) [23:44:26] waiting 5 seconds for container to start...
(005089) [23:44:27] waiting 4 seconds for container to start...
(005089) [23:44:28] waiting 3 seconds for container to start...
(005089) [23:44:29] waiting 2 seconds for container to start...
(005089) [23:44:30] waiting 1 seconds for container to start...
(005089) [23:44:31] ERROR: container failed to start
(005089) [23:44:31] See also: <https://github.com/waydroid>
(005089) [23:44:31] Traceback (most recent call last):
File "/usr/lib/waydroid/tools/__init__.py", line 69, in main
actions.container_manager.start(args)
File "/usr/lib/waydroid/tools/actions/container_manager.py", line 163, in start
raise OSError("container failed to start")
OSError: container failed to start
(005213) [23:44:31] UserMonitor service is not even started
(005213) [23:44:31] Clipboard service is not even started
(005101) [23:44:32] UserMonitor service is not even started
(005101) [23:44:32] Clipboard service is not even started
(005221) [23:45:18] % tail -n 60 -F /var/lib/waydroid/waydroid.log
(005221) [23:45:18] *** output passed to waydroid stdout, not to this log ***
(014429) [01:10:50] Starting waydroid session
(014429) [01:10:50] Save session config: /var/lib/waydroid/session.cfg
(014429) [01:10:50] UserMonitor service is not even started
(014429) [01:10:50] Clipboard service is not even started
(014472) [01:11:56] % chmod 666 -R /dev/binder
(014472) [01:11:56] % chmod 666 -R /dev/vndbinder
(014472) [01:11:56] % chmod 666 -R /dev/hwbinder
(014472) [01:11:56] Container manager is waiting for session to load
(014472) [01:11:56] % /usr/lib/waydroid/data/scripts/waydroid-net.sh start
(014472) [01:11:57] % umount /var/lib/waydroid/rootfs/vendor/waydroid.prop
(014472) [01:11:57] % mount /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(014472) [01:11:58] % mount -o remount,ro /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(014472) [01:11:58] % mount /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(014472) [01:11:58] % mount -o remount,ro /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(014472) [01:11:58] % mount -o bind /var/lib/waydroid/waydroid.prop /var/lib/waydroid/rootfs/vendor/waydroid.prop
(014472) [01:11:58] % umount -l /sys/fs/cgroup/schedtune
(014472) [01:11:58] % chmod 777 -R /dev/ashmem
(014472) [01:11:58] % chmod 777 -R /dev/dri
(014472) [01:11:58] % chmod 777 -R /dev/fb0
(014472) [01:11:58] % lxc-start -P /var/lib/waydroid/lxc -F -n waydroid -- /init
(014472) [01:11:58] New background process: pid=14553, output=background
(014472) [01:11:58] waiting 10 seconds for container to start...
lxc-start: waydroid: network.c: netdev_configure_server_veth: 711 No such file or directory - Failed to attach "veth9dlEua" to bridge "waydroid0", bridge interface doesn't exist
(014472) [01:11:59] waiting 9 seconds for container to start...
(014472) [01:12:00] waiting 8 seconds for container to start...
(014472) [01:12:01] waiting 7 seconds for container to start...
(014472) [01:12:02] waiting 6 seconds for container to start...
(014472) [01:12:03] waiting 5 seconds for container to start...
(014472) [01:12:04] waiting 4 seconds for container to start...
(014472) [01:12:05] waiting 3 seconds for container to start...
(014472) [01:12:06] waiting 2 seconds for container to start...
(014472) [01:12:07] waiting 1 seconds for container to start...
(014472) [01:12:08] ERROR: container failed to start
(014472) [01:12:08] See also: <https://github.com/waydroid>
(014472) [01:12:08] Traceback (most recent call last):
(014584) [01:12:09] UserMonitor service is not even started
(014584) [01:12:09] Clipboard service is not even started
(014429) [01:12:09] UserMonitor service is not even started
(014429) [01:12:09] Clipboard service is not even started
(000582) [08:44:05] % mkdir -p /dev/binderfs
(000582) [08:44:05] % mount -t binder binder /dev/binderfs
(000582) [08:44:05] % ln -s /dev/binderfs/anbox-hwbinder /dev/binderfs/anbox-vndbinder /dev/binderfs/anbox-binder /dev/binderfs/features /dev/binderfs/vndbinder /dev/binderfs/hwbinder /dev/binderfs/binder /dev/binderfs/binder-control /dev/
(000582) [08:44:05] % chmod 666 -R /dev/binder
(000582) [08:44:05] % chmod 666 -R /dev/vndbinder
(000582) [08:44:05] % chmod 666 -R /dev/hwbinder
(000582) [08:44:05] Container manager is waiting for session to load
(001485) [08:47:19] ERROR: Action "init" needs root access
(001485) [08:47:19] See also: <https://github.com/waydroid>
(001485) [08:47:19] Traceback (most recent call last):
File "/usr/lib/waydroid/tools/__init__.py", line 53, in main
actionNeedRoot(args.action)
File "/usr/lib/waydroid/tools/__init__.py", line 18, in actionNeedRoot
raise RuntimeError(
RuntimeError: Action "init" needs root access
(001487) [08:47:34] Save config: /var/lib/waydroid/waydroid.cfg
(001487) [08:47:34] % lxc-info --version
4.0.0-devel
(001487) [08:47:34] % mkdir -p /var/lib/waydroid/lxc/waydroid
(001487) [08:47:34] % cp -fpr /usr/lib/waydroid/data/configs/config_2 /var/lib/waydroid/lxc/waydroid/config
(001487) [08:47:34] % sed -i s/LXCARCH/x86_64/ /var/lib/waydroid/lxc/waydroid/config
(001487) [08:47:34] % mv /var/lib/waydroid/config_nodes /var/lib/waydroid/lxc/waydroid
(001495) [08:47:54] Save session config: /var/lib/waydroid/session.cfg
(001495) [08:47:54] UserMonitor service is not even started
(001495) [08:47:54] Clipboard service is not even started
(000582) [08:47:54] % /usr/lib/waydroid/data/scripts/waydroid-net.sh start
(000582) [08:47:55] % mount /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(000582) [08:47:56] % mount -o remount,ro /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(000582) [08:47:56] % mount /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(000582) [08:47:56] % mount -o remount,ro /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(000582) [08:47:56] % mount -o bind /var/lib/waydroid/waydroid.prop /var/lib/waydroid/rootfs/vendor/waydroid.prop
(000582) [08:47:56] % mount -o bind /home/telas/.local/share/waydroid/data /var/lib/waydroid/data
(000582) [08:47:56] % umount -l /sys/fs/cgroup/schedtune
(000582) [08:47:56] % chmod 777 -R /dev/ashmem
(000582) [08:47:56] % chmod 777 -R /dev/dri
(000582) [08:47:56] % chmod 777 -R /dev/fb0
(000582) [08:47:56] % lxc-start -P /var/lib/waydroid/lxc -F -n waydroid -- /init
(000582) [08:47:56] New background process: pid=1582, output=background
(000582) [08:47:56] waiting 10 seconds for container to start...
lxc-start: waydroid: network.c: netdev_configure_server_veth: 711 No such file or directory - Failed to attach "vethzRFWrQ" to bridge "waydroid0", bridge interface doesn't exist
(000582) [08:47:57] waiting 9 seconds for container to start...
(000582) [08:47:58] waiting 8 seconds for container to start...
(000582) [08:47:59] waiting 7 seconds for container to start...
(000582) [08:48:00] waiting 6 seconds for container to start...
(000582) [08:48:01] waiting 5 seconds for container to start...
(000582) [08:48:02] waiting 4 seconds for container to start...
(000582) [08:48:03] waiting 3 seconds for container to start...
(000582) [08:48:04] waiting 2 seconds for container to start...
(000582) [08:48:05] waiting 1 seconds for container to start...
(000582) [08:48:06] ERROR: container failed to start
(000582) [08:48:06] See also: <https://github.com/waydroid>
(000582) [08:48:07] Traceback (most recent call last):
(001613) [08:48:07] UserMonitor service is not even started
(001613) [08:48:07] Clipboard service is not even started
(001495) [08:48:07] UserMonitor service is not even started
(001495) [08:48:07] Clipboard service is not even started
(001618) [08:48:29] % tail -n 60 -F /var/lib/waydroid/waydroid.log
(001618) [08:48:29] *** output passed to waydroid stdout, not to this log ***
(001630) [08:49:20] % tail -n 60 -F /var/lib/waydroid/waydroid.log
(001630) [08:49:20] *** output passed to waydroid stdout, not to this log ***
(003046) [09:07:20] % tail -n 60 -F /var/lib/waydroid/waydroid.log
(003046) [09:07:20] *** output passed to waydroid stdout, not to this log ***
(003166) [09:09:40] % chmod 666 -R /dev/binder
(003166) [09:09:40] % chmod 666 -R /dev/vndbinder
(003166) [09:09:40] % chmod 666 -R /dev/hwbinder
(003166) [09:09:40] Container manager is waiting for session to load
(003222) [09:10:44] % chmod 666 -R /dev/binder
(003222) [09:10:44] % chmod 666 -R /dev/vndbinder
(003222) [09:10:44] % chmod 666 -R /dev/hwbinder
(003222) [09:10:44] Container manager is waiting for session to load
(003234) [09:11:02] % chmod 666 -R /dev/binder
(003234) [09:11:02] % chmod 666 -R /dev/vndbinder
(003234) [09:11:02] % chmod 666 -R /dev/hwbinder
(003234) [09:11:02] Container manager is waiting for session to load
(003456) [09:16:50] Starting waydroid session
(003456) [09:16:50] Save session config: /var/lib/waydroid/session.cfg
(003456) [09:16:50] UserMonitor service is not even started
(003456) [09:16:50] Clipboard service is not even started
(003234) [09:16:50] % /usr/lib/waydroid/data/scripts/waydroid-net.sh start
(003222) [09:16:50] % /usr/lib/waydroid/data/scripts/waydroid-net.sh start
dnsmasq: failed to create listening socket for 192.168.250.1: Cannot assign requested address
iptables: Bad rule (does a matching rule exist in that chain?).
iptables: No chain/target/match by that name.
(003234) [09:16:50] % umount /var/lib/waydroid/rootfs/vendor/waydroid.prop
Cannot find device "waydroid0"
(003222) [09:16:50] % umount /var/lib/waydroid/rootfs
(003222) [09:16:50] % mount /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
umount: /var/lib/waydroid/rootfs: not mounted.
(003234) [09:16:50] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(003234) [09:16:50] NOTE: The failed command's output is above the ^^^ line in the log file: /var/lib/waydroid/waydroid.log
(003234) [09:16:50] ERROR: Command failed: % umount /var/lib/waydroid/rootfs
(003234) [09:16:50] See also: <https://github.com/waydroid>
(003222) [09:16:50] % mount -o remount,ro /var/lib/waydroid/images/system.img /var/lib/waydroid/rootfs
(003234) [09:16:50] Traceback (most recent call last):
File "/usr/lib/waydroid/tools/actions/container_manager.py", line 132, in start
helpers.images.mount_rootfs(args, cfg["waydroid"]["images_path"])
File "/usr/lib/waydroid/tools/helpers/images.py", line 90, in mount_rootfs
helpers.mount.mount(args, images_dir + "/system.img",
File "/usr/lib/waydroid/tools/helpers/mount.py", line 118, in mount
umount_all(args, destination)
File "/usr/lib/waydroid/tools/helpers/mount.py", line 106, in umount_all
tools.helpers.run.user(args, ["umount", mountpoint])
File "/usr/lib/waydroid/tools/helpers/run.py", line 58, in user
return tools.helpers.run_core.core(args, msg, cmd, working_dir, output,
File "/usr/lib/waydroid/tools/helpers/run_core.py", line 343, in core
check_return_code(args, code, log_message)
File "/usr/lib/waydroid/tools/helpers/run_core.py", line 219, in check_return_code
raise RuntimeError("Command failed: " + log_message)
RuntimeError: Command failed: % umount /var/lib/waydroid/rootfs
(003222) [09:16:51] % mount /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(003222) [09:16:51] % mount -o remount,ro /var/lib/waydroid/images/vendor.img /var/lib/waydroid/rootfs/vendor
(003222) [09:16:51] % mount -o bind /var/lib/waydroid/waydroid.prop /var/lib/waydroid/rootfs/vendor/waydroid.prop
(003222) [09:16:51] % umount -l /sys/fs/cgroup/schedtune
(003222) [09:16:51] % chmod 777 -R /dev/ashmem
(003222) [09:16:51] % chmod 777 -R /dev/dri
(003222) [09:16:51] % chmod 777 -R /dev/fb0
(003222) [09:16:51] % lxc-start -P /var/lib/waydroid/lxc -F -n waydroid -- /init
(003222) [09:16:51] New background process: pid=3594, output=background
lxc-start: waydroid: network.c: netdev_configure_server_veth: 711 No such file or directory - Failed to attach "vethfS4MA7" to bridge "waydroid0", bridge interface doesn't exist
(003222) [09:16:51] waiting 10 seconds for container to start...
(003222) [09:16:52] waiting 9 seconds for container to start...
(003222) [09:16:53] waiting 8 seconds for container to start...
(003222) [09:16:54] waiting 7 seconds for container to start...
(003222) [09:16:55] waiting 6 seconds for container to start...
(003222) [09:16:56] waiting 5 seconds for container to start...
(003222) [09:16:57] waiting 4 seconds for container to start...
(003222) [09:16:58] waiting 3 seconds for container to start...
(003222) [09:16:59] waiting 2 seconds for container to start...
(003222) [09:17:00] waiting 1 seconds for container to start...
(003222) [09:17:01] ERROR: container failed to start
(003222) [09:17:01] See also: <https://github.com/waydroid>
(003222) [09:17:01] Traceback (most recent call last):
(003627) [09:17:01] UserMonitor service is not even started
(003627) [09:17:01] Clipboard service is not even started
(003456) [09:17:02] UserMonitor service is not even started
(003456) [09:17:02] Clipboard service is not even started
