TL;DR: My boot disk does not unlock from GRUB, but from a live disk, and chroot
ing into it and running mkinitcpio -P
and update-grub
did not help.
Background: I have updated all my LUKS headers to LUKS2 and the argon2id pbkdf, following this advice.
Afterwards, all LUKS devices unlock fine, both with their passphrases and their keyfiles. Including the boot disk, when unlocked from a live disk, but not when I try to boot into it. Must be GRUB, right?
On power on, it’s “Enter your passphrase…” => I do => “error: invalid passphrase” => “disk not found”.
The UUID of the disk is correct. The passphrase works from live system.
I unlocked the disk, chroot
ed into it and ran mkinitcpio -P
, then update-grub
. No change.
# mkinitcpio -P && update-grub
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '5.15.106-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [encrypt]
-> Running build hook: [openswap]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.23-1-MANJARO'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Detecting snapshots ...
Found snapshot: 2023-04-20 13:55:55 | timeshift-btrfs/snapshots/2023-04-20_13-55-55/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
<snip>
Found snapshot: 2023-02-22 15:08:43 | timeshift-btrfs/snapshots/2023-02-22_15-08-43/@ | ondemand hourly daily weekly monthly | fresh install autosnap before upgrade |
Found 50 snapshot(s)
Unmount /tmp/grub-btrfs.TA9NcKvavf .. Success
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
I can see the /boot/initramfs-*
that updated “just now”.
/etc/default/grub
seems ok.
GRUB_DEFAULT=0
GRUB_TIMEOUT=1
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="cryptdevice=UUID=553d95f9-e962-49ed-b6e7-bee7726a5ec1:luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 root=/dev/mapper/luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 resume=/dev/mapper/luks-13f9c137-c427-4be0-b567-33a209509780 udev.log_priority=3 nvme.noacpi=1 mem_sleep_default=deep"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
#GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
Check the UUIDS:
# blkid | grep LUKS
/dev/nvme0n1p3: UUID="13f9c137-c427-4be0-b567-33a209509780" TYPE="crypto_LUKS" PARTUUID="89d7b623-3e8a-d749-a3c7-3d65c9bb5149"
/dev/nvme0n1p2: UUID="553d95f9-e962-49ed-b6e7-bee7726a5ec1" TYPE="crypto_LUKS" PARTLABEL="root" PARTUUID="4bd28b0f-624a-574d-bc5d-eea402fcccdf"
( …5ec1 is encrypted root, …9780 is encrypted swap)
Relevant crypttab entries are:
# <name> <device> <password> <options>
# internal SSD
luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 UUID=553d95f9-e962-49ed-b6e7-bee7726a5ec1 /crypto_keyfile.bin luks
luks-13f9c137-c427-4be0-b567-33a209509780 UUID=13f9c137-c427-4be0-b567-33a209509780 /crypto_keyfile.bin luks
<snip>
Relevant fstab entries are:
# internal SSD
UUID=71A5-1BE9 /boot/efi vfat umask=0077,noatime 0 2
/dev/mapper/luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 / btrfs subvol=/@,discard=async,ssd,noatime 0 0
/dev/mapper/luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 /home btrfs subvol=/@home,discard=async,ssd,noatime 0 0
/dev/mapper/luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 /var/cache btrfs subvol=/@cache,discard=async,ssd,noatime 0 0
/dev/mapper/luks-553d95f9-e962-49ed-b6e7-bee7726a5ec1 /var/log btrfs subvol=/@log,discard=async,ssd,noatime 0 0
/dev/mapper/luks-13f9c137-c427-4be0-b567-33a209509780 swap swap noatime 0 0
tmpfs /tmp tmpfs noatime,mode=1777 0 0
And /etc/mkinitcpio.conf reads:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(usbhid xhci_hcd)
MODULES="crc32c-intel"
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES="/crypto_keyfile.bin"
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No RAID, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect modconf block filesystems fsck)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev modconf block filesystems fsck)
## This setup assembles a mdadm array with an encrypted root file system.
## Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
# HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
## This setup loads an lvm2 volume group.
# HOOKS=(base udev modconf block lvm2 filesystems fsck)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr and fsck hooks.
HOOKS="base udev autodetect modconf block keyboard keymap consolefont plymouth encrypt openswap resume filesystems"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
Now, I have header backups, but they are still LUKS1. Soooo close to bang my head against a wall…
