Dulbi
January 2, 2021, 4:58pm
#1
I have got some warning every time I made a update : warning: config /etc/pacman.conf line 19: unknown option ‘SyncFirst’
the line in question :
SyncFirst = manjaro-system manjaro-keyring manjaro-arm-keyring archlinux-keyring archlinuxarm-keyring
Do I have to comment it ?
For info :
pacman 5.2.2-3
pacman-mirrors 4.19.1-1
pamac-cli 10.0.3-1
pamac-common 10.0.3-1
pamac-gtk 10.0.3-1
Graham
January 2, 2021, 6:02pm
#2
Hi Dulbi
Mine is not commented, so I’m guessing that the problem is one of the packages. On mine the entries are the same except that I do not have the two ‘arm’ keyring entries. I presume you are using the ARM edition?
Dulbi
January 2, 2021, 6:38pm
#3
Yes I use the ARM edition. I guess it came with checkrebuild from rebuild-detector due to python 3.9 upgrade.
Dulbi
January 2, 2021, 7:28pm
#4
I’ve checked a little and I guess it’s pacconf (from pacutils) which sends that warning when it opens /etc/pacman.conf.
Can you test “pacconf --repo-list” please ?
Graham
January 2, 2021, 7:40pm
#5
Mine is:
core
extra
community
multilib
Dulbi
January 3, 2021, 5:21pm
#6
thanks that’s what should be.
I’m still looking for the cause
Wondering why this is not installed by default on Manjaro ?
Instead you have to install pacutils which is in the arch community repo to get it.
