Warning: python-openstacksdk: unknown key
sudo pacman -Syyu         ✔
\\:: Synchronizing package databases...
 core        139.9 KiB   654 KiB/s 00:00 [#################################################################] 100%
 extra        8.3 MiB  27.6 MiB/s 00:00 [#################################################################] 100%
 multilib        140.0 KiB  1917 KiB/s 00:00 [#################################################################] 100%
warning: python-openstacksdk: unknown key 'python-keystevelGERrclient' in sync database
warning: python-openstacksdk: unknown key '%CHECKDEPEN15uzT0' in sync database
warning: python-openstacksdk: unknown key '%' in sync database
warning: python-openstacksdk: unknown key 'jC3w' in sync database
warning: python-openstacksdk: unknown key 'auth' in sync database
warning: python-openstacksdk: unknown key 'netifac' in sync database
warning: python-openstacksdk: unknown key 'os-SzWYice-typ' in sync database
warning: python-openstacksdk: unknown key 'X4hel9GUd' in sync database
error: could not parse package description file 'python-openstacksdk-3.3.0-2/desc' from db 'extra'
 there is nothing to do
    ~  sudo pacman -S python-openstacksdk         ✔
error: target not found: python-openstacksdk
I have tried removing extra and redownloading.
A command I found in another thread let me ignore it for a system update via pacman.
sudo find /var/lib/pacman/local/ -type f -name "desc" -exec sed -i '/^%INSTALLED_DB%$/,+2d' {} \;
Will this work as a long term resolution?
sudo rm -f /var/lib/pacman/sync/extra/python-openstacksdk-3.3.0-2/desc
sudo pacman -Sy
This is a new error for me.
Those keys look weird to me too. I know python-openstacksdk is legitimate, but those keys just have a trojany look to them lol.
