This warning is shown every time I start my computer.
More info:
$ sudo aa-status
apparmor module is loaded.
23 profiles are loaded.
22 profiles are in enforce mode.
/usr/lib/snapd/snap-confine
/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
/var/lib/snapd/snap/core/10823/usr/lib/snapd/snap-confine
/var/lib/snapd/snap/core/10823/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
dovecot-script-login
lsb_release
nvidia_modprobe
nvidia_modprobe//kmod
php-fpm
snap-update-ns.core
snap-update-ns.discord
snap-update-ns.skype
snap-update-ns.slack
snap-update-ns.zoom-client
snap.core.hook.configure
snap.discord.discord
snap.discord.hook.configure
snap.skype.hook.configure
snap.skype.skype
snap.zoom-client.hook.configure
snap.zoom-client.zoom-client
torbrowser_tor
1 profiles are in complain mode.
snap.slack.slack
0 profiles are in kill mode.
0 profiles are in unconfined mode.
14 processes have profiles defined.
8 processes are in enforce mode.
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (1616) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2133) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2137) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2151) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2360) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2372) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2412) snap.skype.skype
/var/lib/snapd/snap/skype/164/usr/share/skypeforlinux/skypeforlinux (2692) snap.skype.skype
6 processes are in complain mode.
/var/lib/snapd/snap/slack/37/usr/lib/slack/slack (5515) snap.slack.slack
/var/lib/snapd/snap/slack/37/usr/lib/slack/slack (5541) snap.slack.slack
/var/lib/snapd/snap/slack/37/usr/lib/slack/slack (5542) snap.slack.slack
/var/lib/snapd/snap/slack/37/usr/lib/slack/slack (5585) snap.slack.slack
/var/lib/snapd/snap/slack/37/usr/lib/slack/slack (5588) snap.slack.slack
/var/lib/snapd/snap/slack/37/usr/lib/slack/slack (5661) snap.slack.slack
0 processes are unconfined but have a profile defined.
0 processes are in mixed mode.
0 processes are in kill mode.
$ systemctl status apparmor
● apparmor.service - Load AppArmor profiles
Loaded: loaded (/usr/lib/systemd/system/apparmor.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sun 2021-02-21 01:24:41 CET; 19min ago
Process: 242 ExecStart=/lib/apparmor/apparmor.systemd reload (code=exited, status=1/FAILURE)
Main PID: 242 (code=exited, status=1/FAILURE)
févr. 21 01:24:39 MyPC apparmor.systemd[242]: Restarting AppArmor
févr. 21 01:24:39 MyPC apparmor.systemd[242]: Reloading AppArmor profiles
févr. 21 01:24:40 MyPC apparmor.systemd[269]: profile has merged rule with conflicting x modifiers
févr. 21 01:24:40 MyPC apparmor.systemd[269]: ERREUR lors du traitement Regex du profil torbrowser_firefox, le chargement a ?chou?
févr. 21 01:24:41 MyPC apparmor.systemd[386]: profile has merged rule with conflicting x modifiers
févr. 21 01:24:41 MyPC apparmor.systemd[386]: ERREUR lors du traitement Regex du profil torbrowser_firefox, le chargement a ?chou?
févr. 21 01:24:41 MyPC apparmor.systemd[242]: Error: At least one profile failed to load
févr. 21 01:24:41 MyPC systemd[1]: apparmor.service: Main process exited, code=exited, status=1/FAILURE
févr. 21 01:24:41 MyPC systemd[1]: apparmor.service: Failed with result 'exit-code'.
févr. 21 01:24:41 MyPC systemd[1]: Failed to start Load AppArmor profiles.
Translation for the one French sentence: ERROR during the Regex operation of the torbrowser_firefox profile, loading failed.
Can someone explain why this happens, and hopefully solve the issue?
