Ok, but then I stay with the Linux 61, so my system don’t go havoc on me.
Because I realy need my system up and running for me.
As long as you dont remove 6.1 you are free to test others.
Or just stay there if you like.
I’m not sure what the next LTS release will be, but 6.1 will be supported until 2027. ![]()
| Version | Maintainer | Released | Projected EOL |
| 6.1 | Greg Kroah-Hartman & Sasha Levin | 2022-12-11 | Dec, 2026 |
| 5.15 | Greg Kroah-Hartman & Sasha Levin | 2021-10-31 | Oct, 2026 |
| 5.10 | Greg Kroah-Hartman & Sasha Levin | 2020-12-13 | Dec, 2026 |
| 5.4 | Greg Kroah-Hartman & Sasha Levin | 2019-11-24 | Dec, 2025 |
| 4.19 | Greg Kroah-Hartman & Sasha Levin | 2018-10-22 | Dec, 2024 |
| 4.14 | Greg Kroah-Hartman & Sasha Levin | 2017-11-12 | Jan, 2024 |
sudo pacman -Syu
[sudo] password for philip:
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
And the system seems to be in working order for me now also.
Ohps. Another problem.
[community] repo no longer exists.
This is as simple as removing the entries from /etc/pacman.conf
But is probably indicative of pacnews being ignored.
You can print them all with:
pacdiff -o
$ pacdiff -o
/etc/clamav/clamd.conf.pacnew
/usr/share/icons/default/index.theme.pacnew
/etc/shells.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/pamac.conf.pacnew
/etc/lightdm/lightdm.conf.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/pacman.conf.pacnew
Right.
If you compared that one to your /etc/pacman.conf you will notice the difference is the [community] entries are removed.
But thats just the one … the rest need to be reviewed as well.
Take care - you do not want to blindly overwrite. The idea is to preserve your system particulars and merge in new standards.
For more information on pacnew/pacsave files:
https://wiki.archlinux.org/title/Pacman/Pacnew_and_Pacsave
If you want a GUI for handling them then there is manjaro-pacnew-checker in the repos.
…though I might mention this is of course different from the original title issue.
No problem ! Good to now that .
Linux is truly a fascinating system.
No wonder NASA uses it on the ISS.
