If i start update-grub, i get a warning maybe from osprober
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
My Install ist on an nvme. The names of the partitions start with nvme0n1p1 …
Should i ignore this ?
Yes, iirc this is a result of some thing or another and does not result in a failure to boot or probe.
what is “some thing or another” ??? any further explanation ? eat it or leave it ???
This seems to happen often with very new NVMe models – “too new” to be recognised by the system – as @Hanzel suggests, it will likely work as expected, regardless.
Details when searching the forum:
