The system hangs on after a while almost every time. When it is happened I can move the mouse pointer, and I can also switch to TTY with Ctrl-Alt-F5, cursor is blinking but the login prompt does not appear.
Other problems (maybe they are related): fans turn on at full only at processor temperatures close to 100 degrees. Sometimes wifi turns off endlessly. I updated BIOS a month ago, ACPI errors did not go away.
Error and warning messages of the last boot (LC_ALL=C journalctl --priority=warning…crit --no-pager --boot=-1):
Dec 13 14:36:56 boris-hp kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240322/psobject-220)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20240322/dswload2-326)
Dec 13 14:36:56 boris-hp kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 13 14:36:56 boris-hp kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 13 14:36:56 boris-hp kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Dec 13 14:36:56 boris-hp kernel: sdhci-pci 0000:05:00.0: PCIe Bus Error: severity=Correctable, type=Data Link Layer, (Transmitter ID)
Dec 13 14:36:56 boris-hp kernel: sdhci-pci 0000:05:00.0: device [17a0:9750] error status/mask=00001000/00002000
Dec 13 14:36:56 boris-hp kernel: sdhci-pci 0000:05:00.0: [12] Timeout
Dec 13 14:36:56 boris-hp kernel: EXT4-fs error (device nvme0n1p5): ext4_orphan_get:1421: comm mount: bad orphan inode 19136866
Dec 13 14:36:56 boris-hp kernel: ext4_test_bit(bit=353, block=76546064) = 0
Dec 13 14:36:56 boris-hp kernel: EXT4-fs error (device nvme0n1p5): ext4_orphan_get:1421: comm mount: bad orphan inode 19189758
Dec 13 14:36:56 boris-hp kernel: ext4_test_bit(bit=4093, block=76546070) = 0
Dec 13 14:36:56 boris-hp systemd-journald[356]: File /var/log/journal/7d98a6868355455fb63c66a865f00345/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 13 14:36:57 boris-hp kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Dec 13 14:36:57 boris-hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^PCI0.RP09.PEGP.GPFG], AE_NOT_FOUND (20240322/psargs-332)
Dec 13 14:36:57 boris-hp kernel: ACPI Error: Aborting method \_SB.WMID.STPS due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
Dec 13 14:36:57 boris-hp kernel: ACPI Error: Aborting method \HWMC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
Dec 13 14:36:57 boris-hp kernel: ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
Dec 13 14:36:57 boris-hp kernel: nvidia: loading out-of-tree module taints kernel.
Dec 13 14:36:57 boris-hp kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 13 14:36:57 boris-hp kernel: Disabling lock debugging due to kernel taint
Dec 13 14:36:57 boris-hp kernel: nvidia: module license taints kernel.
Dec 13 14:36:57 boris-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Dec 13 14:36:58 boris-hp kernel:
Dec 13 14:36:58 boris-hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.135 Thu Nov 14 00:09:29 UTC 2024
Dec 13 14:36:58 boris-hp kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support bap plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support bass plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support mcp plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support vcp plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support micp plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support ccp plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support csip plugin
Dec 13 14:36:58 boris-hp bluetoothd[591]: src/plugin.c:init_plugin() System does not support asha plugin
Dec 13 14:37:02 boris-hp kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20240322/nsarguments-61)
Dec 13 14:37:02 boris-hp kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
Dec 13 14:37:04 boris-hp dbus-broker-launch[583]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dec 13 14:37:04 boris-hp dbus-broker-launch[717]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 13 14:37:04 boris-hp dbus-broker-launch[717]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Dec 13 14:37:04 boris-hp dbus-broker-launch[717]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 13 14:37:09 boris-hp sddm-greeter-qt6[713]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Dec 13 14:37:09 boris-hp dbus-broker-launch[780]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 13 14:37:09 boris-hp dbus-broker-launch[780]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Dec 13 14:37:09 boris-hp dbus-broker-launch[780]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 13 14:37:10 boris-hp kernel: block nvme0n1: No UUID available providing old NGUID
Dec 13 14:37:10 boris-hp kded6[863]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Dec 13 14:37:10 boris-hp kded6[863]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Dec 13 14:37:10 boris-hp baloo_file[810]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.29'
Dec 13 14:37:10 boris-hp baloo_file[810]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.32'
Dec 13 14:37:10 boris-hp kded6[863]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp kconf_update[1025]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Dec 13 14:37:11 boris-hp org_kde_powerdevil[959]: Failed to create wl_display (Файл или каталог не существует)
Dec 13 14:37:11 boris-hp kded6[863]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Dec 13 14:37:11 boris-hp dbus-broker-launch[583]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Dec 13 14:37:11 boris-hp geoclue[1066]: Failed to connect to avahi service: Daemon not running
Dec 13 14:37:11 boris-hp kded6[863]: kscreen.kded: PowerDevil SuspendSession action not available!
Dec 13 14:37:11 boris-hp plasmashell[904]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Dec 13 14:37:11 boris-hp plasmashell[904]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 13 14:37:11 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Dec 13 14:37:11 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "auto_null"
Dec 13 14:37:11 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink"
Dec 13 14:37:11 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic2__source"
Dec 13 14:37:11 boris-hp org_kde_powerdevil[959]: org.kde.powerdevil: [DDCutilDetector]: Failed to initialize callback
Dec 13 14:37:11 boris-hp plasmashell[904]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x64e738c1a690
Dec 13 14:37:11 boris-hp plasmashell[904]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x64e738c1a690
Dec 13 14:37:11 boris-hp org_kde_powerdevil[959]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 13 14:37:12 boris-hp org_kde_powerdevil[959]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 13 14:37:12 boris-hp org_kde_powerdevil[959]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 13 14:37:12 boris-hp plasmashell[904]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 13 14:37:12 boris-hp kernel: warning: `birdtray' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Dec 13 14:37:12 boris-hp plasmashell[904]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Dec 13 14:37:12 boris-hp kded6[863]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Dec 13 14:37:12 boris-hp kdeconnectd[1181]: 2024-12-13T14:37:12 default: Error sending UDP packet: QAbstractSocket::NetworkError
Dec 13 14:37:12 boris-hp kdeconnectd[1181]: 2024-12-13T14:37:12 kdeconnect.core: Failed to open any MDNS client sockets
Dec 13 14:37:12 boris-hp kdeconnectd[1181]: 2024-12-13T14:37:12 kdeconnect.core: Failed to open any MDNS server sockets
Dec 13 14:37:13 boris-hp plasmashell[904]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 13 14:37:14 boris-hp dbus-broker-launch[583]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Dec 13 14:37:15 boris-hp kdeconnectd[1181]: 2024-12-13T14:37:15 kdeconnect.core: Failed to send mDNS query: Невозможно назначить запрошенный адрес
Dec 13 14:37:17 boris-hp telegram-desktop[1532]: QPainter::begin: Paint device returned engine == 0, type: 2
Dec 13 14:37:17 boris-hp telegram-desktop[1532]: QWidget::render: Cannot render with an inactive painter
Dec 13 14:37:18 boris-hp xdg-desktop-portal-kde[960]: qt.dbus.integration: QDBusConnection: couldn't handle call to CreateMonitor, no slot matched
Dec 13 14:37:18 boris-hp xdg-desktop-portal-kde[960]: qt.dbus.integration: Could not find slot InhibitPortal::CreateMonitor
Dec 13 14:37:18 boris-hp xdg-desktop-por[814]: A backend call failed: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
Dec 13 14:37:18 boris-hp xdg-desktop-por[814]: Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: No such object path '/org/freedesktop/portal/desktop/session/1_62/tdesktop2975955304'
Dec 13 14:37:18 boris-hp plasmashell[904]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 13 14:37:19 boris-hp telegram-desktop[1532]: qt.gui.imageio.jpeg: Corrupt JPEG data: premature end of data segment
Dec 13 14:37:23 boris-hp kernel: ------------[ cut here ]------------
Dec 13 14:37:23 boris-hp kernel: WARNING: CPU: 6 PID: 684 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
Dec 13 14:37:23 boris-hp kernel: Modules linked in: ccm uinput rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device qrtr cmac algif_hash algif_skcipher af_alg bnep pkcs8_key_parser nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) vfat fat snd_ctl_led snd_soc_skl_hda_dsp snd_soc_hdac_hdmi snd_soc_intel_hda_dsp_common nvidia(POE) snd_sof_probes snd_hda_codec_realtek intel_uncore_frequency snd_hda_codec_generic snd_soc_dmic intel_uncore_frequency_common snd_hda_scodec_component snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_cadence snd_sof_intel_hda_common snd_sof_intel_hda_mlink snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_generic_allocation soundwire_bus intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp snd_soc_skl coretemp snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match kvm snd_soc_acpi snd_soc_core rtw88_8822ce crct10dif_pclmul snd_compress crc32_pclmul snd_hda_codec_hdmi
Dec 13 14:37:23 boris-hp kernel: rtw88_8822c ac97_bus polyval_clmulni polyval_generic snd_pcm_dmaengine ghash_clmulni_intel rtw88_pci sha512_ssse3 snd_hda_intel rtw88_core sha256_ssse3 sha1_ssse3 snd_intel_dspcfg hid_multitouch aesni_intel btusb gf128mul snd_intel_sdw_acpi uvcvideo mac80211 crypto_simd btrtl 8250_dw videobuf2_vmalloc iTCO_wdt cryptd snd_hda_codec processor_thermal_device_pci_legacy btintel rapl processor_thermal_device ee1004 uvc intel_pmc_bxt btbcm iTCO_vendor_support libarc4 btmtk videobuf2_memops snd_hda_core processor_thermal_wt_hint intel_rapl_msr hp_wmi intel_cstate mei_pxp mei_hdcp joydev snd_hwdep mousedev intel_uncore bluetooth videobuf2_v4l2 processor_thermal_rfim platform_profile cfg80211 spi_nor sparse_keymap videodev snd_pcm mtd wmi_bmof processor_thermal_rapl i2c_i801 pcspkr i2c_smbus intel_rapl_common r8169 videobuf2_common i2c_mux intel_lpss_pci ucsi_acpi processor_thermal_wt_req realtek typec_ucsi snd_timer processor_thermal_power_floor intel_lpss mdio_devres mei_me snd typec processor_thermal_mbox
Dec 13 14:37:23 boris-hp kernel: libphy mei rfkill mc idma64 roles soundcore drm_ttm_helper intel_soc_dts_iosf intel_pch_thermal i2c_hid_acpi i2c_hid intel_pmc_core hp_accel lis3lv02d pinctrl_cannonlake intel_vsec int3403_thermal pmt_telemetry int3400_thermal int340x_thermal_zone pmt_class acpi_thermal_rel acpi_pad acpi_tad wireless_hotkey hid_uclogic mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid i915 serio_raw atkbd libps2 i2c_algo_bit sdhci_pci drm_buddy vivaldi_fmap mxm_wmi nvme ttm cqhci sdhci intel_gtt nvme_core crc32c_intel spi_intel_pci drm_display_helper mmc_core spi_intel xhci_pci nvme_auth cec xhci_pci_renesas i8042 video serio wmi
Dec 13 14:37:23 boris-hp kernel: CPU: 6 UID: 0 PID: 684 Comm: nv_queue Tainted: P OE 6.11.10-2-MANJARO #1 81b5a47829db45f170f020709a1698bf4c3683be
Dec 13 14:37:23 boris-hp kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Dec 13 14:37:23 boris-hp kernel: Hardware name: HP HP Pavilion Gaming Laptop 16-a0xxx/87AE, BIOS F.30 07/22/2024
Dec 13 14:37:23 boris-hp kernel: RIP: 0010:follow_pte+0x1de/0x200
Dec 13 14:37:23 boris-hp kernel: Code: cc cc cc 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 42 f1 ff ff 48 8b 35 5b ae 5f 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
Dec 13 14:37:23 boris-hp kernel: RSP: 0018:ffffa55b414afb60 EFLAGS: 00010246
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797cc772f000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797cc772f000 RDI: ffff91fa4baa6e60
Dec 13 14:37:23 boris-hp kernel: RBP: ffffa55b414afbe0 R08: ffffa55b414afd38 R09: 0000000000000000
Dec 13 14:37:23 boris-hp kernel: R10: 0000000000000001 R11: 0000000000000003 R12: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: R13: ffffa55b414afb98 R14: ffff91fa4d083c80 R15: 0000000000000000
Dec 13 14:37:23 boris-hp kernel: FS: 0000000000000000(0000) GS:ffff91fdd0700000(0000) knlGS:0000000000000000
Dec 13 14:37:23 boris-hp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Dec 13 14:37:23 boris-hp kernel: CR2: 000075a41c052020 CR3: 00000001093a4001 CR4: 00000000007706f0
Dec 13 14:37:23 boris-hp kernel: PKRU: 55555554
Dec 13 14:37:23 boris-hp kernel: Call Trace:
Dec 13 14:37:23 boris-hp kernel: <TASK>
Dec 13 14:37:23 boris-hp kernel: ? follow_pte+0x1de/0x200
Dec 13 14:37:23 boris-hp kernel: ? __warn.cold+0x8e/0xe8
Dec 13 14:37:23 boris-hp kernel: ? report_bug+0xff/0x140
Dec 13 14:37:23 boris-hp kernel: ? handle_bug+0x58/0x90
Dec 13 14:37:23 boris-hp kernel: ? exc_invalid_op+0x17/0x70
Dec 13 14:37:23 boris-hp kernel: ? asm_exc_invalid_op+0x1a/0x20
Dec 13 14:37:23 boris-hp kernel: follow_phys+0x49/0x110
Dec 13 14:37:23 boris-hp kernel: untrack_pfn+0x55/0x120
Dec 13 14:37:23 boris-hp kernel: unmap_single_vma+0xa6/0xe0
Dec 13 14:37:23 boris-hp kernel: zap_page_range_single+0x122/0x1d0
Dec 13 14:37:23 boris-hp kernel: unmap_mapping_range+0x116/0x140
Dec 13 14:37:23 boris-hp kernel: ? __pfx__main_loop+0x10/0x10 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 14:37:23 boris-hp kernel: nv_revoke_gpu_mappings+0x67/0xb0 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 14:37:23 boris-hp kernel: _nv000709rm+0x35/0x100 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 14:37:23 boris-hp kernel: rm_execute_work_item+0xea/0x130 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 14:37:23 boris-hp kernel: os_execute_work_item+0x5e/0x80 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 14:37:23 boris-hp kernel: _main_loop+0x95/0x150 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 14:37:23 boris-hp kernel: kthread+0xcf/0x100
Dec 13 14:37:23 boris-hp kernel: ? __pfx_kthread+0x10/0x10
Dec 13 14:37:23 boris-hp kernel: ret_from_fork+0x31/0x50
Dec 13 14:37:23 boris-hp kernel: ret_from_fork_asm+0x1a/0x30
Dec 13 14:37:23 boris-hp kernel: </TASK>
Dec 13 14:37:23 boris-hp kernel: ---[ end trace 0000000000000000 ]---
Dec 13 14:37:23 boris-hp kernel: CPU: 6 UID: 0 PID: 684 Comm: nv_queue Tainted: P W OE 6.11.10-2-MANJARO #1 81b5a47829db45f170f020709a1698bf4c3683be
Dec 13 14:37:23 boris-hp kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797cda705000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797cda705000 RDI: ffff91fa4b66f958
Dec 13 14:37:23 boris-hp kernel: R10: ffff91fa4004fe68 R11: 0000000000000000 R12: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797ccc559000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797ccc559000 RDI: ffff91fa4b66fc38
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797cda706000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797cda706000 RDI: ffff91fa4b66fac8
Dec 13 14:37:23 boris-hp kernel: R10: 000000000040003a R11: 0000000000000000 R12: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797cdaaf9000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797cdaaf9000 RDI: ffff91fa4b66f000
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797ccfc8a000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797ccfc8a000 RDI: ffff91fa4baa6450
Dec 13 14:37:23 boris-hp kernel: R10: 000000000040002c R11: 0000000000000000 R12: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797cdaafb000 RCX: ffffa55b414afba0
Dec 13 14:37:23 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797cdaafb000 RDI: ffff91fa4baa6000
Dec 13 14:37:23 boris-hp kernel: R10: 000000000040003f R11: 0000000000000000 R12: ffffa55b414afba0
Dec 13 14:37:33 boris-hp kglobalacceld[806]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
Dec 13 14:37:35 boris-hp plasmashell[904]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 13 14:39:59 boris-hp kglobalacceld[806]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
Dec 13 14:45:08 boris-hp plasmashell[904]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 13 15:04:58 boris-hp telegram-desktop[1532]: qt.gui.imageio.jpeg: Corrupt JPEG data: premature end of data segment
Dec 13 15:05:55 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 15:05:55 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 15:05:55 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Dec 13 15:12:53 boris-hp kioworker[6131]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 13 15:12:53 boris-hp kioworker[6131]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 13 15:12:58 boris-hp kioworker[6201]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 13 15:12:58 boris-hp kioworker[6201]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 13 15:13:24 boris-hp kioworker[6231]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 13 15:13:24 boris-hp kioworker[6231]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 13 15:16:47 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 32894, resource id: 21034409, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 15:25:02 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 64089, resource id: 21046919, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 15:35:49 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 15:35:49 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 15:35:49 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Dec 13 16:05:43 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 16:05:43 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 16:05:43 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Dec 13 16:06:12 boris-hp plasmashell[904]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 13 16:06:13 boris-hp plasmashell[904]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 13 16:06:28 boris-hp plasmashell[904]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 13 16:11:55 boris-hp kded6[863]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Dec 13 16:11:58 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink"
Dec 13 16:11:58 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic1__source"
Dec 13 16:11:58 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Dec 13 16:11:58 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Dec 13 16:11:58 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink"
Dec 13 16:11:58 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic1__source"
Dec 13 16:11:58 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "auto_null"
Dec 13 16:11:58 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Dec 13 16:30:34 boris-hp kernel: i2c_hid_acpi i2c-ELAN072E:00: i2c_hid_get_input: incomplete report (14/3583)
Dec 13 16:30:34 boris-hp kernel: i2c_hid_acpi i2c-ELAN072E:00: i2c_hid_get_input: incomplete report (14/65280)
Dec 13 16:30:34 boris-hp pipewire[955]: pw.node: (auto_null-55) graph xrun not-triggered (0 suppressed)
Dec 13 16:30:34 boris-hp pipewire[955]: pw.node: (auto_null-55) xrun state:0x750c1b7d5008 pending:1/2 s:5706265904427 a:5706265966448 f:5706265971306 waiting:62021 process:4858 status:triggered
Dec 13 16:30:34 boris-hp pipewire[955]: pw.node: (Firefox-88) xrun state:0x750c19ef0008 pending:0/1 s:5709175237813 a:5709175312563 f:5706265961386 waiting:74750 process:18446744070800200439 status:awake
Dec 13 16:30:34 boris-hp dbus-broker[587]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.47.
Dec 13 16:30:35 boris-hp kdeconnectd[1181]: 2024-12-13T16:30:35 default: Error sending UDP packet: QAbstractSocket::NetworkError
Dec 13 16:30:35 boris-hp kdeconnectd[1181]: 2024-12-13T16:30:35 kdeconnect.core: Failed to open any MDNS client sockets
Dec 13 16:30:35 boris-hp kdeconnectd[1181]: 2024-12-13T16:30:35 kdeconnect.core: Failed to open any MDNS server sockets
Dec 13 16:30:35 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "auto_null"
Dec 13 16:30:35 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Dec 13 16:30:35 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink"
Dec 13 16:30:35 boris-hp kded6[863]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic2__source"
Dec 13 16:30:35 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Dec 13 16:30:35 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Dec 13 16:30:35 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink"
Dec 13 16:30:35 boris-hp plasmashell[904]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic1__source"
Dec 13 16:30:39 boris-hp kded6[863]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Dec 13 16:30:39 boris-hp plasmashell[904]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Dec 13 16:30:42 boris-hp kdeconnectd[1181]: 2024-12-13T16:30:42 kdeconnect.core: Failed to send mDNS query: Невозможно назначить запрошенный адрес
Dec 13 16:30:47 boris-hp telegram-desktop[1532]: qt.gui.imageio.jpeg: Corrupt JPEG data: premature end of data segment
Dec 13 16:30:56 boris-hp kernel: ------------[ cut here ]------------
Dec 13 16:30:56 boris-hp kernel: WARNING: CPU: 5 PID: 684 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
Dec 13 16:30:56 boris-hp kernel: Modules linked in: ccm uinput rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device qrtr cmac algif_hash algif_skcipher af_alg bnep pkcs8_key_parser nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) vfat fat snd_ctl_led snd_soc_skl_hda_dsp snd_soc_hdac_hdmi snd_soc_intel_hda_dsp_common nvidia(POE) snd_sof_probes snd_hda_codec_realtek intel_uncore_frequency snd_hda_codec_generic snd_soc_dmic intel_uncore_frequency_common snd_hda_scodec_component snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_cadence snd_sof_intel_hda_common snd_sof_intel_hda_mlink snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_generic_allocation soundwire_bus intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp snd_soc_skl coretemp snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match kvm snd_soc_acpi snd_soc_core rtw88_8822ce crct10dif_pclmul snd_compress crc32_pclmul snd_hda_codec_hdmi
Dec 13 16:30:56 boris-hp kernel: rtw88_8822c ac97_bus polyval_clmulni polyval_generic snd_pcm_dmaengine ghash_clmulni_intel rtw88_pci sha512_ssse3 snd_hda_intel rtw88_core sha256_ssse3 sha1_ssse3 snd_intel_dspcfg hid_multitouch aesni_intel btusb gf128mul snd_intel_sdw_acpi uvcvideo mac80211 crypto_simd btrtl 8250_dw videobuf2_vmalloc iTCO_wdt cryptd snd_hda_codec processor_thermal_device_pci_legacy btintel rapl processor_thermal_device ee1004 uvc intel_pmc_bxt btbcm iTCO_vendor_support libarc4 btmtk videobuf2_memops snd_hda_core processor_thermal_wt_hint intel_rapl_msr hp_wmi intel_cstate mei_pxp mei_hdcp joydev snd_hwdep mousedev intel_uncore bluetooth videobuf2_v4l2 processor_thermal_rfim platform_profile cfg80211 spi_nor sparse_keymap videodev snd_pcm mtd wmi_bmof processor_thermal_rapl i2c_i801 pcspkr i2c_smbus intel_rapl_common r8169 videobuf2_common i2c_mux intel_lpss_pci ucsi_acpi processor_thermal_wt_req realtek typec_ucsi snd_timer processor_thermal_power_floor intel_lpss mdio_devres mei_me snd typec processor_thermal_mbox
Dec 13 16:30:56 boris-hp kernel: libphy mei rfkill mc idma64 roles soundcore drm_ttm_helper intel_soc_dts_iosf intel_pch_thermal i2c_hid_acpi i2c_hid intel_pmc_core hp_accel lis3lv02d pinctrl_cannonlake intel_vsec int3403_thermal pmt_telemetry int3400_thermal int340x_thermal_zone pmt_class acpi_thermal_rel acpi_pad acpi_tad wireless_hotkey hid_uclogic mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid i915 serio_raw atkbd libps2 i2c_algo_bit sdhci_pci drm_buddy vivaldi_fmap mxm_wmi nvme ttm cqhci sdhci intel_gtt nvme_core crc32c_intel spi_intel_pci drm_display_helper mmc_core spi_intel xhci_pci nvme_auth cec xhci_pci_renesas i8042 video serio wmi
Dec 13 16:30:56 boris-hp kernel: CPU: 5 UID: 0 PID: 684 Comm: nv_queue Tainted: P W OE 6.11.10-2-MANJARO #1 81b5a47829db45f170f020709a1698bf4c3683be
Dec 13 16:30:56 boris-hp kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Dec 13 16:30:56 boris-hp kernel: Hardware name: HP HP Pavilion Gaming Laptop 16-a0xxx/87AE, BIOS F.30 07/22/2024
Dec 13 16:30:56 boris-hp kernel: RIP: 0010:follow_pte+0x1de/0x200
Dec 13 16:30:56 boris-hp kernel: Code: cc cc cc 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 42 f1 ff ff 48 8b 35 5b ae 5f 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
Dec 13 16:30:56 boris-hp kernel: RSP: 0018:ffffa55b414afb60 EFLAGS: 00010246
Dec 13 16:30:56 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797ccfcbb000 RCX: ffffa55b414afba0
Dec 13 16:30:56 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797ccfcbb000 RDI: ffff91fa576ba958
Dec 13 16:30:56 boris-hp kernel: RBP: ffffa55b414afbe0 R08: ffffa55b414afd38 R09: 0000000000000000
Dec 13 16:30:56 boris-hp kernel: R10: 0000000000000001 R11: 0000000000000003 R12: ffffa55b414afba0
Dec 13 16:30:56 boris-hp kernel: R13: ffffa55b414afb98 R14: ffff91fa4d083c80 R15: 0000000000000000
Dec 13 16:30:56 boris-hp kernel: FS: 0000000000000000(0000) GS:ffff91fdd0680000(0000) knlGS:0000000000000000
Dec 13 16:30:56 boris-hp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Dec 13 16:30:56 boris-hp kernel: CR2: 00007c8636785968 CR3: 00000002839be002 CR4: 00000000007706f0
Dec 13 16:30:56 boris-hp kernel: PKRU: 55555554
Dec 13 16:30:56 boris-hp kernel: Call Trace:
Dec 13 16:30:56 boris-hp kernel: <TASK>
Dec 13 16:30:56 boris-hp kernel: ? follow_pte+0x1de/0x200
Dec 13 16:30:56 boris-hp kernel: ? __warn.cold+0x8e/0xe8
Dec 13 16:30:56 boris-hp kernel: ? report_bug+0xff/0x140
Dec 13 16:30:56 boris-hp kernel: ? handle_bug+0x58/0x90
Dec 13 16:30:56 boris-hp kernel: ? exc_invalid_op+0x17/0x70
Dec 13 16:30:56 boris-hp kernel: ? asm_exc_invalid_op+0x1a/0x20
Dec 13 16:30:56 boris-hp kernel: follow_phys+0x49/0x110
Dec 13 16:30:56 boris-hp kernel: untrack_pfn+0x55/0x120
Dec 13 16:30:56 boris-hp kernel: unmap_single_vma+0xa6/0xe0
Dec 13 16:30:56 boris-hp kernel: zap_page_range_single+0x122/0x1d0
Dec 13 16:30:56 boris-hp kernel: unmap_mapping_range+0x116/0x140
Dec 13 16:30:56 boris-hp kernel: ? __pfx__main_loop+0x10/0x10 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 16:30:56 boris-hp kernel: nv_revoke_gpu_mappings+0x67/0xb0 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 16:30:56 boris-hp kernel: _nv000709rm+0x35/0x100 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 16:30:56 boris-hp kernel: rm_execute_work_item+0xea/0x130 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 16:30:56 boris-hp kernel: os_execute_work_item+0x5e/0x80 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 16:30:56 boris-hp kernel: _main_loop+0x95/0x150 [nvidia f0695b3dc5b58997c41a22057a1dd7cd89ad88fd]
Dec 13 16:30:56 boris-hp kernel: kthread+0xcf/0x100
Dec 13 16:30:56 boris-hp kernel: ? __pfx_kthread+0x10/0x10
Dec 13 16:30:56 boris-hp kernel: ret_from_fork+0x31/0x50
Dec 13 16:30:56 boris-hp kernel: ret_from_fork_asm+0x1a/0x30
Dec 13 16:30:56 boris-hp kernel: </TASK>
Dec 13 16:30:56 boris-hp kernel: ---[ end trace 0000000000000000 ]---
Dec 13 16:30:56 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797ccc559000 RCX: ffffa55b414afba0
Dec 13 16:30:56 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797ccc559000 RDI: ffff91fd335f8b80
Dec 13 16:30:56 boris-hp kernel: R10: 0000000000400029 R11: 0000000000000003 R12: ffffa55b414afba0
Dec 13 16:30:56 boris-hp kernel: RAX: 0000000000000000 RBX: 0000797ccfcbc000 RCX: ffffa55b414afba0
Dec 13 16:30:56 boris-hp kernel: RDX: ffffa55b414afb98 RSI: 0000797ccfcbc000 RDI: ffff91fa525ae170
Dec 13 16:30:56 boris-hp kernel: R10: 0000000000400028 R11: 0000000000000003 R12: ffffa55b414afba0
Dec 13 16:31:04 boris-hp kglobalacceld[806]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
Dec 13 16:31:25 boris-hp plasmashell[904]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 13 16:41:02 boris-hp plasmashell[904]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 13 16:59:54 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 16:59:54 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 16:59:54 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Dec 13 17:10:12 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 2623, resource id: 21194259, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 17:29:48 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 17:29:48 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 17:29:48 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Dec 13 17:38:04 boris-hp kglobalacceld[806]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
Dec 13 17:38:05 boris-hp kglobalacceld[806]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
Dec 13 17:40:36 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 8889, resource id: 21277404, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 17:40:41 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 13655, resource id: 21277836, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 17:41:33 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 57108, resource id: 21281493, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 17:57:57 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 37146, resource id: 21321440, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 17:58:48 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 5584, resource id: 21323513, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 17:59:42 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 17:59:42 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 17:59:42 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Dec 13 18:05:48 boris-hp kwin_x11[864]: kwin_core: XCB error: 152 (BadDamage), sequence: 58529, resource id: 21341408, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 18:20:54 boris-hp telegram-desktop[1532]: QTextCursor::setPosition: Position '-1' out of range
Dec 13 18:21:55 boris-hp pipewire[955]: pw.node: (alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink-75) graph xrun not-triggered (0 suppressed)
Dec 13 18:21:55 boris-hp pipewire[955]: pw.node: (alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink-75) xrun state:0x750c19ef2008 pending:1/1 s:11960364943264 a:11960364947478 f:11960364953573 waiting:4214 process:6095 status:triggered
Dec 13 18:29:36 boris-hp kernel: ACPI Error: No handler for Region [CMS0] (000000001abb2408) [SystemCMOS] (20240322/evregion-131)
Dec 13 18:29:36 boris-hp kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20240322/exfldio-261)
Dec 13 18:29:36 boris-hp kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20240322/psparse-529)
Fragments of another boot logs (for brevity):
Dec 11 11:20:49 boris-hp kernel: i915 0000:00:02.0: [drm] Resetting rcs0 for preemption time out
Dec 11 11:20:49 boris-hp kernel: i915 0000:00:02.0: [drm] *ERROR* GT0: rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
Dec 11 11:20:49 boris-hp kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffa, in QSGRenderThread [36937]
Dec 11 11:21:04 boris-hp kernel: BUG: kernel NULL pointer dereference, address: 0000000000000280
Dec 11 11:21:04 boris-hp kernel: #PF: supervisor read access in kernel mode
Dec 11 11:21:04 boris-hp kernel: #PF: error_code(0x0000) - not-present page
Dec 11 11:21:04 boris-hp kernel: PGD 0 P4D 0
Dec 11 11:21:04 boris-hp kernel: Oops: Oops: 0000 [#1] PREEMPT SMP NOPTI
Dec 11 11:21:04 boris-hp kernel: CPU: 4 UID: 0 PID: 183 Comm: kworker/4:1H Tainted: P W OE 6.11.10-2-MANJARO #1 81b5a47829db45f170f020709a1698bf4c3683be
Dec 11 11:21:04 boris-hp kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Dec 11 11:21:04 boris-hp kernel: Hardware name: HP HP Pavilion Gaming Laptop 16-a0xxx/87AE, BIOS F.30 07/22/2024
Dec 11 11:21:04 boris-hp kernel: Workqueue: events_highpri heartbeat [i915]
Dec 11 11:21:04 boris-hp kernel: RIP: 0010:__i915_gpu_coredump.cold+0x17/0x41 [i915]
Dec 11 11:21:04 boris-hp kernel: Code: e8 6a 65 27 da 48 83 ce ff bf 10 00 00 00 e8 5c 65 27 da 48 8b 44 24 28 48 8b 54 24 20 4c 8b 40 28 48 8b 48 20 49 8b 44 24 08 <44> 0f b7 8a 80 02 00>
Dec 11 11:21:04 boris-hp kernel: RSP: 0018:ffffa115006efc78 EFLAGS: 00010286
Dec 11 11:21:04 boris-hp kernel: RAX: ffff958dc13c8028 RBX: ffff958deea69800 RCX: 0000000000000211
Dec 11 11:21:04 boris-hp kernel: RDX: 0000000000000000 RSI: ffff958ea77b4000 RDI: ffff958dc6404f80
Dec 11 11:21:04 boris-hp kernel: RBP: 0000000000000000 R08: 0000000000000144 R09: 00000000ffffffff
Dec 11 11:21:04 boris-hp kernel: R10: 0000000000000000 R11: 000000000000e164 R12: ffff958dc13cc000
Dec 11 11:21:04 boris-hp kernel: R13: ffff958ed5e37000 R14: 0000000000000000 R15: ffff958df2160000
Dec 11 11:21:04 boris-hp kernel: FS: 0000000000000000(0000) GS:ffff959150600000(0000) knlGS:0000000000000000
Dec 11 11:21:04 boris-hp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Dec 11 11:21:04 boris-hp kernel: CR2: 0000000000000280 CR3: 0000000163c22005 CR4: 00000000007706f0
Dec 11 11:21:04 boris-hp kernel: PKRU: 55555554
Dec 11 11:21:04 boris-hp kernel: Call Trace:
Dec 11 11:21:04 boris-hp kernel: <TASK>
Dec 11 11:21:04 boris-hp kernel: ? __die_body.cold+0x19/0x27
Dec 11 11:21:04 boris-hp kernel: ? page_fault_oops+0x15a/0x2d0
Dec 11 11:21:04 boris-hp kernel: ? intel_gt_mcr_lock+0x39/0x110 [i915 9d1d972c8947cc2f202fabae6a125b3ff5e70b95]
Dec 11 11:21:04 boris-hp kernel: ? exc_page_fault+0x81/0x190
Dec 11 11:21:04 boris-hp kernel: ? asm_exc_page_fault+0x26/0x30
Dec 11 11:21:04 boris-hp kernel: ? __i915_gpu_coredump.cold+0x17/0x41 [i915 9d1d972c8947cc2f202fabae6a125b3ff5e70b95]
Dec 11 11:21:04 boris-hp kernel: ? __i915_gpu_coredump+0x206/0x7d0 [i915 9d1d972c8947cc2f202fabae6a125b3ff5e70b95]
Dec 11 11:21:04 boris-hp kernel: i915_capture_error_state+0x61/0xb0 [i915 9d1d972c8947cc2f202fabae6a125b3ff5e70b95]
Dec 11 11:21:04 boris-hp kernel: intel_gt_handle_error+0x3b8/0x3d0 [i915 9d1d972c8947cc2f202fabae6a125b3ff5e70b95]
Dec 11 11:21:04 boris-hp kernel: ? sched_clock_cpu+0xf/0x1d0
Dec 11 11:21:04 boris-hp kernel: heartbeat+0x3c9/0x3e0 [i915 9d1d972c8947cc2f202fabae6a125b3ff5e70b95]
Dec 11 11:21:04 boris-hp kernel: process_one_work+0x17b/0x330
Dec 11 11:21:04 boris-hp kernel: worker_thread+0x2ce/0x3f0
Dec 11 11:21:04 boris-hp kernel: ? __pfx_worker_thread+0x10/0x10
Dec 11 11:21:04 boris-hp kernel: kthread+0xcf/0x100
Dec 11 11:21:04 boris-hp kernel: ? __pfx_kthread+0x10/0x10
Dec 11 11:21:04 boris-hp kernel: ret_from_fork+0x31/0x50
Dec 11 11:21:04 boris-hp kernel: ret_from_fork_asm+0x1a/0x30
Dec 11 11:21:04 boris-hp kernel: </TASK>
Dec 11 11:21:04 boris-hp kernel: Modules linked in: uinput ccm snd_seq_dummy rfcomm snd_hrtimer snd_seq snd_seq_device qrtr cmac algif_hash algif_skcipher af_alg bnep pkcs8_key_parser nvi>
Dec 11 11:21:04 boris-hp kernel: snd_compress ac97_bus rtw88_8822c polyval_generic snd_pcm_dmaengine rtw88_pci ghash_clmulni_intel sha512_ssse3 snd_hda_intel rtw88_core iTCO_wdt uvcvideo>
Dec 11 11:21:04 boris-hp kernel: processor_thermal_power_floor processor_thermal_mbox typec idma64 intel_pch_thermal intel_soc_dts_iosf roles i2c_hid_acpi i2c_hid intel_pmc_core hp_accel>
Dec 11 11:21:04 boris-hp kernel: ---[ end trace 0000000000000000 ]---
Dec 11 11:21:04 boris-hp kernel: note: kworker/4:1H[183] exited with irqs disabled
Dec 11 11:21:07 boris-hp wpa_supplicant[666]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-42 noise=9999 txrate=104000
Dec 11 11:21:09 boris-hp kernel: Fence expiration time out i915-0000:00:02.0:QSGRenderThread[36937]:144!
Dec 11 11:21:09 boris-hp kernel: Fence expiration time out i915-0000:00:02.0:kwin_x11[874]:114da4!
Dec 11 11:21:09 boris-hp kernel: Fence expiration time out i915-0000:00:02.0:kwin_x11[874]:114da2!
Dec 11 11:21:09 boris-hp kernel: Fence expiration time out i915-0000:00:02.0:Xorg[679]:94a3c!
Dec 11 11:21:09 boris-hp kernel: Fence expiration time out i915-0000:00:02.0:QSGRenderThread[36937]:146!
Dec 11 11:21:09 boris-hp kernel: Fence expiration time out i915-0000:00:02.0:Xorg[679]:94a3e!
Dec 13 02:01:06 boris-hp kwin_x11[912]: kwin_core: XCB error: 152 (BadDamage), sequence: 43296, resource id: 21335765, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 02:01:07 boris-hp kwin_x11[912]: kwin_core: XCB error: 152 (BadDamage), sequence: 44063, resource id: 21335828, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 02:01:18 boris-hp systemd[794]: app-org.kde.okular@213d7f1a3d2643b58e830c0a756dcdab.service: Consumed 26.514s CPU time, 296.8M memory peak.
Dec 13 02:03:00 boris-hp root[35477]: ACPI group/action undefined: thermal_zone / LNXTHERM:00
Dec 13 02:03:11 boris-hp root[35494]: ACPI group/action undefined: button/up / UP
Dec 13 02:04:00 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=39000
Dec 13 02:04:06 boris-hp root[35611]: ACPI group/action undefined: button/left / LEFT
Dec 13 02:04:09 boris-hp root[35617]: ACPI group/action undefined: button/left / LEFT
Dec 13 02:04:20 boris-hp root[35642]: ACPI group/action undefined: button/right / RIGHT
Dec 13 02:04:21 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=39000
Dec 13 02:04:37 boris-hp kwin_x11[912]: kwin_core: XCB error: 152 (BadDamage), sequence: 19890, resource id: 21339833, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 13 02:06:12 boris-hp baloo_file_extractor[35848]: kf.baloo: Not busy, fast indexing
Dec 13 02:06:20 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-25 noise=9999 txrate=52000
Dec 13 02:08:23 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-27 noise=9999 txrate=52000
Dec 13 02:09:33 boris-hp kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=910501 end=910502) time 565 us, min 1073, max 1079, scanline start 1053, end 1073
Dec 13 02:13:28 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=39000
Dec 13 02:13:43 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=52000
Dec 13 02:14:31 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-49 noise=9999 txrate=26000
Dec 13 02:14:50 boris-hp kernel: usb 1-2: USB disconnect, device number 6
Dec 13 02:14:50 boris-hp PenTablet.sh[1281]: VENDOR(0x28bd) PRODUCT(0x905)
Dec 13 02:14:50 boris-hp PenTablet.sh[1281]: ReceiveUsbMsg Vid: 10429 Pid: 2309 state 2
Dec 13 02:14:50 boris-hp PenTablet.sh[1281]: DeviceThread Thread exit
Dec 13 02:14:50 boris-hp PenTablet.sh[1281]: Function nativeEvent: "PID_0905" disconnected
Dec 13 02:16:42 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=39000
Dec 13 02:16:58 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-41 noise=9999 txrate=117000
Dec 13 02:18:23 boris-hp root[37090]: ACPI group/action undefined: thermal_zone / LNXTHERM:00
Dec 13 02:19:29 boris-hp rtkit-daemon[895]: Supervising 8 threads of 5 processes of 1 users.
Dec 13 02:22:42 boris-hp rtkit-daemon[895]: Supervising 8 threads of 5 processes of 1 users.
Dec 13 02:22:45 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=117000
Dec 12 22:02:52 boris-hp root[3392]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:53 boris-hp root[3394]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:54 boris-hp root[3396]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:55 boris-hp root[3406]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:56 boris-hp root[3408]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:57 boris-hp root[3411]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:58 boris-hp root[3418]: ACPI action undefined: PNP0C0A:00
Dec 12 22:02:59 boris-hp root[3422]: ACPI group/action undefined: processor / LNXCPU:00
Dec 12 22:02:59 boris-hp root[3424]: ACPI group/action undefined: processor / LNXCPU:01
Dec 12 22:02:59 boris-hp root[3426]: ACPI group/action undefined: processor / LNXCPU:02
Dec 12 22:02:59 boris-hp root[3428]: ACPI group/action undefined: processor / LNXCPU:03
Dec 12 22:02:59 boris-hp root[3430]: ACPI group/action undefined: processor / LNXCPU:04
Dec 12 22:02:59 boris-hp root[3432]: ACPI group/action undefined: processor / LNXCPU:05
Dec 12 22:02:59 boris-hp root[3434]: ACPI group/action undefined: processor / LNXCPU:06
Dec 12 22:02:59 boris-hp root[3436]: ACPI group/action undefined: processor / LNXCPU:07
Dec 12 22:02:59 boris-hp root[3438]: ACPI action undefined: PNP0C0A:00
Dec 12 22:03:00 boris-hp root[3440]: ACPI action undefined: PNP0C0A:00
Dec 12 22:03:00 boris-hp root[3442]: ACPI action undefined: PNP0C0A:00
Dec 12 22:05:05 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-27 noise=9999 txrate=52000
Dec 12 22:05:16 boris-hp systemd[794]: Started Dolphin - File manager.
Dec 12 22:05:18 boris-hp plasmashell[953]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 12 22:05:24 boris-hp kioworker[3743]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:05:24 boris-hp kioworker[3743]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:05:25 boris-hp kioworker[3799]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:05:25 boris-hp kioworker[3799]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:05:25 boris-hp kioworker[3848]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:05:25 boris-hp kioworker[3848]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:05:26 boris-hp kioworker[3864]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:05:26 boris-hp kioworker[3864]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:05:55 boris-hp kioworker[3879]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:05:55 boris-hp kioworker[3879]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:07 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-27 noise=9999 txrate=144400
Dec 12 22:06:08 boris-hp kioworker[3942]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:08 boris-hp kioworker[3942]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:09 boris-hp kioworker[3981]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:09 boris-hp kioworker[3981]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:10 boris-hp kioworker[4001]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:10 boris-hp kioworker[4001]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:12 boris-hp kioworker[4022]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:12 boris-hp kioworker[4022]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:12 boris-hp kioworker[4053]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:12 boris-hp kioworker[4053]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:14 boris-hp kioworker[4087]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:14 boris-hp kioworker[4087]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:15 boris-hp kioworker[4116]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:15 boris-hp kioworker[4116]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:16 boris-hp kioworker[4143]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:16 boris-hp kioworker[4143]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:17 boris-hp kioworker[4172]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:17 boris-hp kioworker[4172]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:18 boris-hp kioworker[4189]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Dec 12 22:06:18 boris-hp kioworker[4189]: kf.kio.core: An error occurred during write. The worker terminates now.
Dec 12 22:06:26 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-26 noise=9999 txrate=130000
Dec 12 22:06:27 boris-hp systemd[794]: Started JupyterLab.
Dec 12 22:06:29 boris-hp rtkit-daemon[895]: Supervising 8 threads of 5 processes of 1 users.
Dec 12 22:06:31 boris-hp rtkit-daemon[895]: Supervising 8 threads of 5 processes of 1 users.
Dec 12 22:06:31 boris-hp root[4385]: ACPI group/action undefined: button/down / DOWN
Dec 12 22:06:33 boris-hp root[4395]: ACPI group/action undefined: button/right / RIGHT
Dec 12 22:06:36 boris-hp root[4408]: ACPI group/action undefined: button/left / LEFT
Dec 12 22:06:36 boris-hp root[4410]: ACPI group/action undefined: button/up / UP
Dec 12 22:06:40 boris-hp rtkit-daemon[895]: Supervising 8 threads of 5 processes of 1 users.
Dec 12 22:06:41 boris-hp root[4477]: ACPI group/action undefined: button/right / RIGHT
Dec 12 22:06:43 boris-hp root[4483]: ACPI group/action undefined: button/left / LEFT
Dec 12 22:06:43 boris-hp wpa_supplicant[667]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-28 noise=9999 txrate=144400
Dec 12 22:06:44 boris-hp root[4485]: ACPI group/action undefined: button/right / RIGHT
Dec 12 22:06:45 boris-hp root[4492]: ACPI group/action undefined: button/left / LEFT
Dec 12 22:06:45 boris-hp kwin_x11[912]: kwin_core: XCB error: 152 (BadDamage), sequence: 16861, resource id: 20978061, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 12 22:06:53 boris-hp rtkit-daemon[895]: Supervising 8 threads of 5 processes of 1 users.
Output of sudo inxi --verbosity=8 --filter --width:
Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=4b22afc1-a2aa-405c-ba02-18b4b027d8b6 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 16-a0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87AE v: 32.32 serial: <filter> part-nu: 316G9EA#ACB
uuid: 31444335-3031-584c-504e-6c02e09965de UEFI: AMI v: F.30 date: 07/22/2024
ID-1: BAT0 charge: 20.8 Wh (51.5%) condition: 40.4/40.4 Wh (100.0%)
power: 14.8 W volts: 11.1 min: 11.6 model: HP Primary type: Li-ion
serial: <filter> status: discharging cycles: 38
System RAM: total: 16 GiB available: 15.27 GiB used: 8.75 GiB (57.3%)
igpu: 64 MiB
Device-1: Bottom - Slot 1 (Up) type: DDR4 detail: synchronous size: 8 GiB
speed: spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: A-Data
part-no: AO1P32NC8T1-BBVS serial: <filter>
Device-2: Bottom - Slot 2 (down) type: DDR4 detail: synchronous size: 8 GiB
Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
bus-ID: 00:01.0 children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1
class-ID: 0403 type: audio
Info: model: Intel Core i5-10300H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1526 min/max: 800/4500 base/boost: 792/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.6 V ext-clock: 100 MHz
cores: 1: 1526 2: 1526 3: 1526 4: 1526 5: 1526 6: 1526 7: 1526 8: 1526
bogomips: 40009
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 550.135
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0408:5365
class-ID: 0e02
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x08f6 built: 2019 res: 1920x1080
dpi: 137 gamma: 1.2 chroma: red: x: 0.584 y: 0.345 green: x: 0.333 y: 0.553
blue: x: 0.161 y: 0.129 white: x: 0.314 y: 0.329
size: 355x200mm (13.98x7.87") diag: 407mm (16") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 7.46 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: nvidia v: 550.135 device-ID: 10de:1f95
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
(CML GT2) driver: mesa intel v: 24.2.8-arch1.1 device-ID: 8086:9bc4
surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0401
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
chip-ID: 10ec:c822 class-ID: 0280
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:b00c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c010c
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 274.81 GiB (19.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 25d 1h cycles: 4,056
read-units: 122,409,552 [62.6 TB] written-units: 22,672,044 [11.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
family: Barracuda 2.5 5400 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 0001 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 31d 9h cycles: 3694
read: 1.39 TiB written: 1.37 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 329.1 GiB size: 322.87 GiB (98.11%)
used: 274.77 GiB (85.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: 4b22afc1-a2aa-405c-ba02-18b4b027d8b6
used: 49.2 MiB (51.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: F29A-3F1A
ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 25431938-c60b-48f5-a996-aa30e6ee52cd
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 129.64 GiB fs: ntfs label: N/A
uuid: 8C36C77636C75FB6
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 516 MiB fs: ntfs label: N/A
uuid: 94B406B7B4069BBC
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-5: /dev/sda2 maj-min: 8:2 size: 831.5 GiB fs: ntfs label: N/A
uuid: 1E52533052530BC1
ID-6: /dev/sda3 maj-min: 8:3 size: 100 GiB fs: ext4 label: N/A
uuid: 13e91fac-2d52-4c27-9969-a3c2b9bd322c
Device-1: 1-6:2 info: Quanta HP TrueVision HD Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
Device-2: 1-7:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 59.0 C pch: 50.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: pm: pacman pkgs: 1590 libs: 373 tools: pamac,yay pm: flatpak
pkgs: 0
1: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
2: https://mirrors2.manjaro.org/stable/$repo/$arch
3: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
4: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
5: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
6: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
7: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 285
1: cpu: 300% command: ps pid: 10645 mem: 3.42 MiB (0.0%)
2: cpu: 117% command: firefox pid: 1777 mem: 692.8 MiB (4.4%)
3: cpu: 35.7% command: firefox pid: 2054 mem: 1535.5 MiB (9.8%)
4: cpu: 27.7% command: firefox pid: 2090 mem: 246.8 MiB (1.5%)
5: cpu: 21.1% command: firefox pid: 2035 mem: 1149.3 MiB (7.3%)
Memory top: 5 of 285
1: mem: 1535.5 MiB (9.8%) command: firefox pid: 2054 cpu: 35.7%
2: mem: 1149.3 MiB (7.3%) command: firefox pid: 2035 cpu: 21.1%
3: mem: 692.8 MiB (4.4%) command: firefox pid: 1777 cpu: 117%
4: mem: 549.6 MiB (3.5%) command: thunderbird pid: 1316 cpu: 3.9%
5: mem: 375.2 MiB (2.3%) command: firefox pid: 2691 cpu: 11.0%
Processes: 285 Power: uptime: 58m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: yakuake inxi: 3.3.36
Wish for your help.
