In the process of fixing a problem with SDDM (it didn’t recognize that there was a desktop environment installed for some reason) the theming that came packaged with the original install is no longer available in the system settings.
I am not certain how to get the artwork stuff from the Manjaro gitlab into the system themes so I can switch back to it, any guidance on that would be loveley
My question was how to reinstall it though.
It’s not available through pacman or the built in themes store so I was checking if there was a means to do it that didn’t involve manually placing all the relevant files.
As I said originally this is after fumbling around in the command line trying to fix SDDM, I suspect this has something to do with GDM but I’m not certain. But the breath theme must have been uninstalled in the process.
Weirdly the fonts, icons, and cursor settings were not affected by this.
I did, sorry for not saying so and thank you for the clarification.
I thought that it might not be available through through pacman for some reason, at the very least I had no way of finding out the name of the package, the issue is solved now in any case
