Want to find executable filename/path for Vivaldi
Hello, I cannot run Vivaldi browser from Konsole. If I click Vivaldi icon on Manjaro Menu the browser starts with no problems. But when I type vivaldi in Konsole and press Enter the terminal says "Command not found". I tried to run firefox from the terminal and it opened with no problems, but it doesn't open for vivaldi. Anyone knows ways to fix this?
I need to open Vivaldi from terminal install media codecs as described in this instruction:
try "vivaldi-stable"
I looked in /usr/share/applications/vivaldi-stable.desktop for the executable name. FYI.
Good luck!
You can get a full file listing for an installed package with pacman -Ql $PACKAGENAME .
Then just look for an executable.
Thank you, Russ and jonathon, for tips :), vivaldi-stable has opened.
also whereis
like
whereis firefox
Sometimes it is more difficult :wink:
