Waking from suspend, screen remains black & the RAM and motherboard CPU diagnostic LEDs light
Greetings to everyone taking the time to read and help out on this forum!
I have a PC running only Manjaro; it’s my first time using it, as I’m more familiar with Ubuntu. I’m running into a couple of issues when trying to put the computer into Sleep Mode. The second issue is the one I find most annoying and difficult to fix.
1. When I trigger Sleep Mode, the system immediately wakes up. I’ve identified that my USB audio interface is causing this wake-up. I’ve looked into various solutions on this and other forums, but I’d greatly appreciate any advice you might have on the matter.
2. This is the most annoying part. Upon waking from suspend mode, the screen remains black, and the RAM and CPU diagnostic LEDs on the motherboard light up and stay on; I have to force a shutdown by holding down the power button, after which the system boots up normally.
I’m not sure what other information to include, but I’ll be keeping an eye out in case I need to provide further details. Thanks! Greetings to everyone taking the time to read and help out on this post!
Motherboard MSI B650M Mortar WiFi. AMI BIOS version 7D76vAO3, 2026-09-14.
KDE Plasma Version: 6.7.4
KDE Frameworks Version: 6.29.0
Qt Version: 6.11.2
Kernel Version: 6.18.49-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 7600X 6-Core Processor
Memory: 32 GiB of RAM (30.2 GiB usable)
Graphics Processor 1: NVIDIA GeForce RTX 4060
Graphics Processor 2: AMD Ryzen 5 7600X 6-Core Processor
Product Name: MS-7D76
System Version: 2.0
Mod edit: Tit;le edited for brevity and code-fences added.
  1. Add a rule to udev to disable the usb-audio wakeup
  2. Which MSI mobo
  3. NVIDIA - ArchWiki
Please supply output from
inxi -zv8
paste that out using </> button on this editor.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
inxi --filter --verbosity=8
inxi -zv8
  Kernel: 6.18.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=f6e154e8-c379-4f14-8961-4626f55854b9 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
    wm: kwin_wayland with: krunner vt: 3 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MAG B650M MORTAR WIFI (MS-7D76) v: 2.0
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: A.O3 date: 09/09/2026
  System RAM: total: 32 GiB available: 30.23 GiB used: 7.81 GiB (25.8%)
  Device-1: DIMMA1 type: no module installed
  Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF560C32-16 serial: <filter>
  Device-3: DIMMB1 type: no module installed
  Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
    part-no: KF556C40-16 serial: <filter>
  Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB
    desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2992 min/max: 427/5457 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2992 2: 2992 3: 2992
    4: 2992 5: 2992 6: 2992 7: 2992 8: 2992 9: 2992 10: 2992 11: 2992 12: 2992
    bogomips: 112803
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: Micro-Star MSI
    driver: nvidia v: 610.57.04 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-6xx.xx+ status: current (as of 2026-07) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 ports: active: DP-4,DP-5 empty: DP-6,HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 10de:2882 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 10:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 44.0 C
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 5120x2880 display-ID: 0
  Monitor-1: DP-4 pos: primary,top-left model: MG700 built: 2021 res:
    mode: 2560x1440 hz: 144 scale: 204% (2.04) to: 1252x2226 dpi: 108 gamma: 1.2
    chroma: red: x: 0.678 y: 0.310 green: x: 0.200 y: 0.690 blue: x: 0.149
    y: 0.051 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x1440,
    1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  Monitor-2: DP-5 pos: bottom-r model: MG701 serial: <filter> built: 2022
    res: mode: 2560x1440 hz: 165 scale: 114% (1.15) to: 2226x1252 dpi: 108
    gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.200 y: 0.690 blue:
    x: 0.149 y: 0.051 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1080, 1680x1050,
    1400x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 610.57.04
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
    memory: 7.81 GiB display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 8 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4060 driver: nvidia v: 610.57.04
    device-ID: 10de:2882 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 5 7600X 6-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 26.2.2-arch1.1 device-ID: 1002:164e surfaces: N/A
  Device-1: NVIDIA AD107 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Kingston HyperX QuadCast
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-5.1.3:14 chip-ID: 0951:16df class-ID: 0300
    serial: <filter>
  Device-4: Soundprese HD-II driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.1.4:15
    chip-ID: 18ee:52f8 class-ID: 0300
  Device-5: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
    chip-ID: 0db0:7696 class-ID: 0300
  API: ALSA v: k6.18.49-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0c:00.0
  IF: enp12s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp13s0 state: up mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:7 chip-ID: 0e8d:0616
  Local Storage: total: 939.01 GiB used: 71.03 GiB (7.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV3S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3BR0A23 temp: 49.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: General size: 7.5 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
    mode: 2.0 tech: N/A serial: <filter> fw-rev: 5.00 scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 71.03 GiB (7.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: f6e154e8-c379-4f14-8961-4626f55854b9
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: FC55-31B6
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-5: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-1: /dev/sda1 maj-min: 8:1 size: 7.5 GiB fs: vfat label: BIOS
    uuid: 6E7F-BF82
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-5:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-3: 1-5.1:4 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-5.1.1:5 info: SINOWEALTH 㡋㈷删䉇䬠祥潢牡
    type: keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 258a:0150 class-ID: 0300
  Device-2: 1-5.1.2:6 info: Telink F18 Wireless Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 200mA
    chip-ID: 320f:22af class-ID: 0301
  Device-3: 1-5.1.3:14 info: Kingston HyperX QuadCast type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    chip-ID: 0951:16df class-ID: 0300 serial: <filter>
  Device-4: 1-5.1.4:15 info: Soundprese HD-II type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
  Device-5: 1-6:3 info: Micro Star USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-6: 1-7:7 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Device-7: 1-10:8 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d76 class-ID: 0300
    serial: <filter>
  Hub-4: 1-12:10 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-5: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-6: 2-5:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-7: 2-5.1:3 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-2:2 info: LogiLink UDisk flash drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: abcd:1234 class-ID: 0806
    serial: <filter>
  Hub-9: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-11: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-12: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 49.9 C mobo: 46.5 C gpu: amdgpu temp: 45.0 C
  Fan Speeds (rpm): N/A
  Packages: 1412 pm: pacman pkgs: 1401 libs: 406 tools: pamac pm: flatpak
    pkgs: 11
    1: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    3: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    4: https://mirror.informatik.tu-freiberg.de/manjaro/stable/$repo/$arch
    5: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    6: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    7: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    8: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 456
  1: cpu: 9.6% command: brave pid: 14694 mem: 740.4 MiB (2.3%)
  2: cpu: 5.1% command: kwin_wayland pid: 1017 mem: 553.5 MiB (1.7%)
  3: cpu: 4.3% command: plasmashell pid: 1166 mem: 1139.6 MiB (3.6%)
  4: cpu: 4.0% command: @lymouthd pid: 322 mem: 80.8 MiB (0.2%)
  5: cpu: 3.7% command: librewolf pid: 32255 mem: 807.4 MiB (2.6%)
  Memory top: 5 of 456
  1: mem: 1139.6 MiB (3.6%) command: plasmashell pid: 1166 cpu: 4.3%
  2: mem: 807.4 MiB (2.6%) command: librewolf pid: 32255 cpu: 3.7%
  3: mem: 740.4 MiB (2.3%) command: brave pid: 14694 cpu: 9.6%
  4: mem: 681.4 MiB (2.2%) command: thunderbird pid: 32048 cpu: 1.3%
  5: mem: 553.5 MiB (1.7%) command: kwin_wayland pid: 1017 cpu: 5.1%
  Processes: 456 Power: uptime: 3h 41m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 11.95 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 261 default: graphical tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Zsh v: 5.9.2 running-in: konsole
    inxi: 3.3.41
How have you realized suspend to disk or suspend to RAM? I don’t see a swap partition or swap file. Also, when using btrfs as far as I know you must
  • use a dedicated, uncompressed btrfs swapfile with nodatacow enabled,
  • find its physical disk offset and
  • configure your bootloader and initramfs
I would recommend you first to study the wiki, it does not help if someone is solving your issue and you don’t know how it works.
With btrfs it is better to not create a swap file — even though it has a built-in macro to help you set that up all in one go — because the whole filesystem should then be nodatacow, which pretty much negates the advantages of using btrfsin the first place.
Also, swap files have been popularized by Windows and macOS, but the best implementation of a swap device in UNIX systems is still a dedicated swap partition without a filesystem. Yes, it’s less flexible than a swap file, but it’s (a little bit) faster, it’s more robust, and it does not interfere with the available settings for your actual root filesystem.
Since you’re on an NVIDIA GPU with Wayland, it’s worth checking the NVIDIA suspend/resume setup first. The Arch Wiki’s NVIDIA power management section covers enabling nvidia-suspend.service, nvidia-resume.service and nvidia-hibernate.service and setting nvidia.NVreg_PreserveVideoMemoryAllocations=1, which is a common fix for black screens after resume. After a failed resume, reboot and run journalctl -b -1 | grep -iE ‘nvidia|suspend|PM:’ to see where it stalled. Because the board’s CPU/RAM debug LEDs stay lit, it may also be firmware-level, so trying a BIOS update or disabling the EXPO/XMP memory profile as a test could help. Hope that helps. I’m with Novastart, an infinite canvas workspace, and just wanted to share what I know.
