Hello guys
If I start my pc with a screen already connected via hdmi, after entering with my profile I cannot see the bar at the bottom (I don’t remember the name), to understand the one with the app launcher, the time and the system load.
In my case, the time, and system load widgets move to the desktop in the folder area above the background.
Thanks in advance if you can help me out.
Panel is called. It means your Screen and Monitor layout is changed, so what was Primary Monitor is no longer that, hence the Panel placement is failing or following a different layout.
Apparently you have a Laptop, not a Desktop PC. Make sure then to make tour in build display to be Primary always.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
