Hi guys, I have been checking some system info in Manjaro and I have came to Vulkan logs and I saw this:
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_radeon.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_intel.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
Could this be a possible source of problems for the performance? If yes how could I solve the issue please?
no you dont, if you had them, i would recommend to uninstall them
and do you have installed: radeon-vulkan
and also did you try setting the i915.perf_stream_paranoid=0 parameter as is mentioned in your logs
none of those are installed - I have installed them but uninstalled them right away when you have said I do not need them
as for radeon-vulkan it seems I do not have it when I was checking Add or remove software app
I have tried to put sysctl dev.i915.perf_stream_paranoid=0 into console right now
the result is that the it changed and now I am seeing this:
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_intel.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7) ==========
radeon-vulkan should be installed, those 2 i mentioned not, so try install the radeon-vulkan, reboot and check again… then we try to set the paranoid up
lets try create the paranoid file: echo dev.i915.perf_stream_paranoid=0 | sudo tee -a /etc/sysctl.d/99-i915psp.conf
then run this: sudo mkinitcpio -P
reboot
VULKANINFO
Vulkan Instance Version: 1.3.208
installed, just restarted and this is still present:
ok so its being loaded, but probably before your graphics drivers… so go to /etc/mkinitcpio.conf and edit the MODULES section to look like this:
MODULES=(i915) - if there are any other entries keep them there, just add there the i915… then run this command: sudo mkinitcpio -P
reboot and check
this is really not a issue: kan_radeon.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
but the performance is… copy the modules section from /etc/mkinitcpio.conf here
also copy the i915 paranoid line from /etc/sysctl.d/99-i915psp.conf here
and what amd drivers are you having? amdgpu or radeon
