Since I connected my LG OLED C9 (HDMI) besides my Acer VG270U (DP), VSync is not working on startup. I have to change the setting to something different and then back to “automatic” to enable it. There is no difference, if the TV is turned on/off during startup. It even happens when the TV is disabled in the display configuration. So, it just needs to be connected to produce this phenomenon.
Has anybody an idea what the problem could be? In a pinch, an autostart-script automatically switching settings would be ok.
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+ 74.92
1920x1200 59.95
1920x1080 74.97 60.00 50.00 59.94
1600x1200 59.95
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x960 60.00
1280x800 59.81
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
HDMI-A-1 connected (normal left inverted right x axis y axis)
3840x2160 60.00 + 50.00 59.94 30.00 25.00 24.00 29.97 23.98
4096x2160 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
2560x1440 120.00
1920x1200 60.00
1920x1080 120.00 100.00 119.88 60.00 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1600x1200 60.00
1680x1050 60.00
1280x1024 60.02
1440x900 60.00
1360x768 60.02
1280x800 60.00
1152x864 59.97
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
DVI-D-0 disconnected (normal left inverted right x axis y axis)
“mhwd.d” is empty.
cat: '/etc/X11/mhwd.d/*': No such file or directory
