I use Borg & Vorta. I like the ease of Vorta’s GUI. I need to schedule 2 Vorta profiles, one at 00:00 & 12:00 the other at 06:00 & 18:00 I can not do this in the vorta scheduler which is a pain, however Vorta does allow you to execute the profiles with a command vorta --create <PROFILE>
which is handy. So i tried to create a crontab for each profile but crontab just errors.
Jul 15 12:20:01 greg-inspiron5767 CROND[230964]: (greg) CMDOUT (qt.qpa.xcb: could not connect to display )
Jul 15 12:20:01 greg-inspiron5767 CROND[230964]: (greg) CMDOUT (qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.)
Jul 15 12:20:01 greg-inspiron5767 CROND[230964]: (greg) CMDOUT (This application failed to start because no Qt platform plugin could be initialized. Reinstalling the applic
ation may fix this problem.)
If i look in the settings at the “Task scheduler” GUI of crontab i can check that the entry does work by hitting “Run Now”
and it works fine, it just does not work when the crontab is run by its own timing.
I have tried to make a bash executable for crontab to execute, but that does not work either.
I have briefly looked at the systemd timers but its all way over my head, plus im not even sure if i will just get the same result anyhow.
Why is creating a very simple timer such a head scratch, there must be a simple timer GUI, maybe a thing that starts at boot and sits in the tray as an icon, you can just add stuff and it just works?
