Not sure what happened, it ran fine last time I opened it. Not sure where the .log is if 12 is somewhere.
And if you start from terminal, what error do you see?
09:24:31 [vokoscreenNG] Desktop session is a X11 session
09:24:32 [vokoscreenNG] Version: 4.4.2
09:24:32 [vokoscreenNG] Locale: en_US
09:24:32 [vokoscreenNG] Log from: 2025-03-01 09:24:32
09:24:32 [vokoscreenNG] Country: United States
09:24:32 [vokoscreenNG] Qt: 6.8.2
09:24:32 [vokoscreenNG] GStreamer 1.24.12
09:24:32 [vokoscreenNG] PulseAudio library version: 17.0.0
09:24:32 [vokoscreenNG] Virtual Maschine: none
09:24:32 [vokoscreenNG] Operating system: Manjaro Linux
09:24:32 [vokoscreenNG] KernelVersion: 6.12.12-2-MANJARO
09:24:32 [vokoscreenNG] CPU Architecture: x86_64
09:24:32 [vokoscreenNG] Count CPU: 16
09:24:32 [vokoscreenNG] vokoscreenNG running as: xcb client
09:24:32 [vokoscreenNG] vokoscreenNG running on: x11
09:24:32 [vokoscreenNG] Desktop: KDE
09:24:32 [vokoscreenNG] Icon-Theme: Breeze-Noir-White-Blue
09:24:32 [vokoscreenNG] Styles: QStyleSheetStyle
09:24:32 [vokoscreenNG] ExecutablePath: /usr/bin
09:24:32 [vokoscreenNG] Qt-PluginsPath: /usr/lib/qt6/plugins
09:24:32 [vokoscreenNG] Qt-TranslationsPath: /usr/share/qt6/translations
09:24:32 [vokoscreenNG] Qt-LibraryPath: /usr/lib
09:24:32 [vokoscreenNG] Settings: /home/nickj/.config/vokoscreenNG/vokoscreenNG.ini
09:24:32 [vokoscreenNG] Log: /home/nickj/.config/vokoscreenNG/log/2025-03-01_09-24-31.log
09:24:32 [vokoscreenNG] Default Videopath: /home/nickj/Videos
09:24:32 [vokoscreenNG] User Videopath: /home/nickj/Videos
09:24:32 [vokoscreenNG] [Audio] Found: Monitor of GA104 High Definition Audio Controller Digital Stereo (HDMI) Device: alsa_output.pci-0000_05_00.1.hdmi-stereo.monitor
09:24:32 [vokoscreenNG] [Audio] Found: Monitor of Starship/Matisse HD Audio Controller Analog Stereo Device: alsa_output.pci-0000_07_00.4.analog-stereo.monitor
09:24:32 [vokoscreenNG] [Audio] Found: Starship/Matisse HD Audio Controller Analog Stereo Device: alsa_input.pci-0000_07_00.4.analog-stereo
09:24:32 [vokoscreenNG] Pictures permission: Can write in /home/nickj/Pictures
Info: 09:24:32 Using Qt multimedia with FFmpeg version n7.1 GPL version 3 or later ((null):0, (null))
Info: 09:24:32 Available HW decoding frameworks: ((null):0, (null))
zsh: segmentation fault (core dumped) vokoscreenNG
