These are the errors I’m getting, any clue?
The following packages will be installed:
linux61
linux61-headers
linux61-zfs
linux61-virtualbox-host-modules
Starting
resolving dependencies...
Packages (4) linux61-6.1.0-1 linux61-headers-6.1.0-1 linux61-virtualbox-host-modules-7.0.4-1 linux61-zfs-2.1.7-1
Total Download Size: 212.77 MiB
Total Installed Size: 326.73 MiB
:: Retrieving packages...
linux61-6.1.0-1-x86_64 downloading...
linux61-headers-6.1.0-1-x86_64 downloading...
linux61-zfs-2.1.7-1-x86_64 downloading...
linux61-virtualbox-host-modules-7.0.4-1-x86_64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux61...
Optional dependencies for linux61
wireless-regdb: to set the correct wireless channels of your country [installed]
installing linux61-headers...
installing linux61-zfs...
installing linux61-virtualbox-host-modules...
===> You must load vboxdrv module before starting VirtualBox:
===> # modprobe vboxdrv
(1/6) Arming ConditionNeedsUpdate...
(2/6) Updating module dependencies...
(3/6) Install DKMS modules
==> dkms install --no-depmod vmware-workstation/17.0.0_20800274 -k 6.1.0-1-MANJARO
Error! Bad return status for module build on kernel: 6.1.0-1-MANJARO (x86_64)
Consult /var/lib/dkms/vmware-workstation/17.0.0_20800274/build/make.log for more information.
==> WARNING: `dkms install --no-depmod vmware-workstation/17.0.0_20800274 -k 6.1.0-1-MANJARO' exited 10
==> dkms install --no-depmod nvidia/525.60.11 -k 6.1.0-1-MANJARO
Consult /var/lib/dkms/nvidia/525.60.11/build/make.log for more information.
==> WARNING: `dkms install --no-depmod nvidia/525.60.11 -k 6.1.0-1-MANJARO' exited 10
(4/6) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: 6.1.0-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
==> ERROR: module not found: `nvidia'
==> ERROR: module not found: `nvidia_drm'
==> ERROR: module not found: `nvidia_uvm'
==> ERROR: module not found: `nvidia_modeset'
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64-fallback.img
(5/6) Updating Kernel initcpios for Nvidia-DRM...
(6/6) Updating Grub-Bootmenu
error: command failed to execute correctly
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.0-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.0-x86_64.img
Found initrd fallback image: /boot/initramfs-6.0-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme3n1p1@/efi/Microsoft/Boot/bootmgfw.efi
done
Done ...
