vmware workstation 15.5.6-1 doesn't work
The latest vmware-workatation version doesn't work, is there any solution to resolve?
The version 15.5.2 works without problems.
  Host: Workstation Kernel: 5.7.6-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.1.0 Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: Gigabyte model: GA-78LMT-S2P v: x.x serial: <filter>
  BIOS: Award v: F3 date: 10/18/2012
  Topology: Dual Core model: AMD Athlon II X2 250 bits: 64 type: MCP
  arch: K10 rev: 3 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 12057
  Speed: 800 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1800 2: 800
  Device-1: AMD RV730 PRO [Radeon HD 4650]
  vendor: Hightech Information System driver: radeon v: kernel
  bus ID: 01:00.0 chip ID: 1002:9498
  Display: x11 server: X.Org 1.20.8 driver: ati,radeon unloaded: modesetting
  alternate: fbdev,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD RV730 (DRM 2.50.0 / 5.7.6-1-MANJARO LLVM 10.0.0)
  v: 3.3 Mesa 20.1.2 compat-v: 3.0 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus ID: 00:14.2 chip ID: 1002:4383
  Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
  vendor: Hightech Information System driver: snd_hda_intel v: kernel
  bus ID: 01:00.1 chip ID: 1002:aa38
  Sound Server: ALSA v: k5.7.6-1-MANJARO
  Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: df00 bus ID: 02:00.0 chip ID: 1969:1091
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 223.58 GiB used: 29.45 GiB (13.2%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
  speed: 3.0 Gb/s serial: <filter> rev: 00RL scheme: MBR
  ID-2: /dev/sdb vendor: Samsung model: SSD 840 EVO 120GB size: 111.79 GiB
  speed: 3.0 Gb/s serial: <filter> rev: DB6Q scheme: GPT
  ID-1: / size: 111.79 GiB used: 28.70 GiB (25.7%) fs: btrfs dev: /dev/sda2
  ID-2: /home size: 111.79 GiB used: 28.70 GiB (25.7%) fs: btrfs
  dev: /dev/sda2
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: radeon temp: 62 C
  Processes: 228 Uptime: 31m Memory: 3.84 GiB used: 2.17 GiB (56.4%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: zsh v: 5.8
  running in: xfce4-terminal inxi: 3.0.37
I can't view that, can you post a screenshot of the error?
See if the comments on the AUR page help :slight_smile:
https://aur.archlinux.org/packages/vmware-workstation
It was a Video, I replaced the link
What is in the referenced log file?
2020-06-29T15:12:48.593+02:00| vmx| I005: Log for VMware Workstation pid=74463 version=15.5.6 build=build-16341506 option=Release
2020-06-29T15:12:48.593+02:00| vmx| I005: The process is 64-bit.
2020-06-29T15:12:48.593+02:00| vmx| I005: Host codepage=UTF-8 encoding=UTF-8
2020-06-29T15:12:48.593+02:00| vmx| I005: Host is Linux 5.7.6-1-MANJARO Manjaro Linux
2020-06-29T15:12:48.567+02:00| vmx| I005: VTHREAD 140345682688960 "vmx" tid 74463
2020-06-29T15:12:48.568+02:00| vmx| I005: DictionaryLoad: Cannot open file "/etc/vmware/vsphereFeatures/techPreview.cfg": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: [msg.dictionary.load.openFailed] Cannot open file "/etc/vmware/vsphereFeatures/techPreview.cfg": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: FeatureStateLib: Error while loading tech preview config file: /etc/vmware/vsphereFeatures/techPreview.cfg, using default (disabled) for all Tech Preview features.
2020-06-29T15:12:48.568+02:00| vmx| I005: LOCALE de_DE.UTF-8 -> de
2020-06-29T15:12:48.568+02:00| vmx| I005: Msg_SetLocaleEx: HostLocale=UTF-8 UserLocale=de
2020-06-29T15:12:48.568+02:00| vmx| I005: PREF early PreferenceGet(libdir), using default
2020-06-29T15:12:48.568+02:00| vmx| I005: DictionaryLoad: Cannot open file "/usr/lib/vmware/messages/de/vmware.vmsg": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/messages/de/vmware.vmsg": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| W003: Cannot load message dictionary "/usr/lib/vmware/messages/de/vmware.vmsg".
2020-06-29T15:12:48.568+02:00| vmx| I005: DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: Msg_Reset:
2020-06-29T15:12:48.568+02:00| vmx| I005: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: ----------------------------------------
2020-06-29T15:12:48.568+02:00| vmx| I005: ConfigDB: Failed to load /usr/lib/vmware/settings
2020-06-29T15:12:48.568+02:00| vmx| I005: DictionaryLoad: Cannot open file "/home/pheiduck/.vmware/config": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: [msg.dictionary.load.openFailed] Cannot open file "/home/pheiduck/.vmware/config": No such file or directory.
2020-06-29T15:12:48.568+02:00| vmx| I005: ConfigDB: Failed to load ~/.vmware/config
2020-06-29T15:12:48.568+02:00| vmx| I005: OBJLIB-LIB: Objlib initialized.
2020-06-29T15:12:48.568+02:00| vmx| I005: PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values.
2020-06-29T15:12:48.568+02:00| vmx| I005: PREF Optional preferences file not found at /home/pheiduck/.vmware/config. Using default values.
2020-06-29T15:12:48.568+02:00| vmx| I005: Fail to realpath: /usr/lib/vmware/lib/libcrypto.so.1.0.2-x86-64/libcrypto.so.1.0.2, errno=2
2020-06-29T15:12:48.568+02:00| vmx| I005: Denied library: /usr/lib/vmware/lib/libcrypto.so.1.0.2-x86-64/libcrypto.so.1.0.2
2020-06-29T15:12:48.584+02:00| vmx| I005: lib/ssl: OpenSSL using FIPS_drbg for RAND
2020-06-29T15:12:48.584+02:00| vmx| I005: lib/ssl: protocol list tls1.2
2020-06-29T15:12:48.584+02:00| vmx| I005: lib/ssl: protocol list tls1.2 (openssl flags 0x17000000)
2020-06-29T15:12:48.584+02:00| vmx| I005: lib/ssl: cipher list ECDHE+AESGCM:RSA+AESGCM:ECDHE+AES:RSA+AES
2020-06-29T15:12:48.584+02:00| vmx| I005: lib/ssl: curves list prime256v1:secp384r1:secp521r1
2020-06-29T15:12:48.638+02:00| vmx| I005: Hostname=localhost.localdomain
2020-06-29T15:12:48.638+02:00| vmx| I005: IP=127.0.0.1 (lo)
2020-06-29T15:12:48.638+02:00| vmx| I005: IP=192.168.178.201 (enp2s0)
2020-06-29T15:12:48.638+02:00| vmx| I005: IP=192.168.130.1 (vmnet1)
2020-06-29T15:12:48.638+02:00| vmx| I005: IP=172.16.160.1 (vmnet8)
2020-06-29T15:12:48.638+02:00| vmx| I005: System uptime 19989700000 us
2020-06-29T15:12:48.638+02:00| vmx| I005: Command line: "/usr/lib/vmware/bin/vmware-vmx" "-s" "vmx.stdio.keep=TRUE" "-#" "product=1;name=VMware Workstation;version=15.5.6;buildnumber=16341506;licensename=VMware Workstation;licenseversion=15.0;" "-@" "duplex=3;msgs=ui" "/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmx"
2020-06-29T15:12:48.638+02:00| vmx| I005: Msg_SetLocaleEx: HostLocale=UTF-8 UserLocale=de
2020-06-29T15:12:48.638+02:00| vmx| I005: DictionaryLoad: Cannot open file "/usr/lib/vmware/messages/de/vmware.vmsg": No such file or directory.
2020-06-29T15:12:48.638+02:00| vmx| I005: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/messages/de/vmware.vmsg": No such file or directory.
2020-06-29T15:12:48.638+02:00| vmx| W003: Cannot load message dictionary "/usr/lib/vmware/messages/de/vmware.vmsg".
2020-06-29T15:12:48.638+02:00| vmx| I005: Duplex socket: 3
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1316eff9bb7d4ef394f6573a20a34c9a
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/vmx-vigor-fd
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/vmx-vmdb-fd
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/mks-fd
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/remoteDevice-fd
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/configFile
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/vmx-live-fd
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: unlinking stale file /var/run/vmware/1000/19907040000_74303/testAutomation-fd
2020-06-29T15:12:48.638+02:00| vmx| I005: CnxUnlinkPath: removing stale directory /var/run/vmware/1000/19907040000_74303
2020-06-29T15:12:48.665+02:00| vmx| I005: WQPoolAllocPoll : pollIx = 1, signalHandle = 9
2020-06-29T15:12:48.665+02:00| vmx| I005: WQPoolAllocPoll : pollIx = 2, signalHandle = 11
2020-06-29T15:12:48.665+02:00| vmx| I005: VigorTransport listening on fd 12
2020-06-29T15:12:48.665+02:00| vmx| I005: Vigor_Init 1
2020-06-29T15:12:48.665+02:00| vmx| I005: Connecting 'ui' to fd '3' with user '(null)'
2020-06-29T15:12:48.665+02:00| vmx| I005: VmdbAddConnection: cnxPath=/db/connection/#1/, cnxIx=1
2020-06-29T15:12:48.708+02:00| vmx| I005: /run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmx: Setup symlink /var/run/vmware/1316eff9bb7d4ef394f6573a20a34c9a -> /var/run/vmware/1000/19989700000_74463
2020-06-29T15:12:48.708+02:00| vmx| I005: Vix: [mainDispatch.c:486]: VMAutomation: Initializing VMAutomation.
2020-06-29T15:12:48.708+02:00| vmx| I005: Vix: [mainDispatch.c:738]: VMAutomationOpenListenerSocket() listening
2020-06-29T15:12:48.712+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=1 additionalError=0
2020-06-29T15:12:48.713+02:00| vmx| I005: Transitioned vmx/execState/val to poweredOff
2020-06-29T15:12:48.713+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2020-06-29T15:12:48.713+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1877, success=1 additionalError=0
2020-06-29T15:12:48.713+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=3, newAppState=1881, success=1 additionalError=0
2020-06-29T15:12:48.714+02:00| vmx| I005: FeatureCompat: No EVC masks.
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID vendor: AuthenticAMD
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID family: 0x10 model: 0x6 stepping: 0x3
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID codename: K10 Opteron -- Unknown codename
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID name: AMD Athlon(tm) II X2 250 Processor
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 00000000, 0: 0x00000005 0x68747541 0x444d4163 0x69746e65
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 00000001, 0: 0x00100f63 0x00020800 0x00802009 0x178bfbff
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 00000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 00000004, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 00000005, 0: 0x00000040 0x00000040 0x00000003 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000000, 0: 0x8000001b 0x68747541 0x444d4163 0x69746e65
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000001, 0: 0x00100f63 0x10001b26 0x000037ff 0xefd3fbff
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000002, 0: 0x20444d41 0x6c687441 0x74286e6f 0x4920296d
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000003, 0: 0x32582049 0x30353220 0x6f725020 0x73736563
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000004, 0: 0x0000726f 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000005, 0: 0xff30ff10 0xff30ff20 0x40020140 0x40020140
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000006, 0: 0x20800000 0x42004200 0x04008140 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x000001f9
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000008, 0: 0x00003030 0x00000000 0x00002001 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000000a, 0: 0x00000001 0x00000040 0x00000000 0x0000000f
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 80000019, 0: 0xf0300000 0x60100000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000001a, 0: 0x00000003 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: hostCPUID level 8000001b, 0: 0x0000001f 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.714+02:00| vmx| I005: CPUID differences from hostCPUID.
2020-06-29T15:12:48.714+02:00| vmx| I005: Physical APIC IDs: 0-1
2020-06-29T15:12:48.714+02:00| vmx| I005: CPUID Maximum Physical Address Bits supported across all CPUs: 48
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR       0x3a =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x480 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x481 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x482 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x483 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x484 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x485 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x486 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x487 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x488 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x489 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x48a =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x48b =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x48c =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x48d =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x48e =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x48f =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x490 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x491 =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR 0xc0010114 =                0x8
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR       0xce =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: Common: MSR      0x10a =                  0
2020-06-29T15:12:48.714+02:00| vmx| I005: UTIL: Current file descriptor limit: soft 16384, hard 524288.
2020-06-29T15:12:48.714+02:00| vmx| I005: VMMon_GetkHzEstimate: Calculated 3013327 kHz
2020-06-29T15:12:48.715+02:00| vmx| I005: TSC kHz estimates: vmmon 3013327, cpuinfo 3000000, cpufreq 3000000.  Using 3013327 kHz
2020-06-29T15:12:48.715+02:00| vmx| I005: TSC first measured delta 117
2020-06-29T15:12:48.715+02:00| vmx| I005: TSC min delta 114
2020-06-29T15:12:48.715+02:00| vmx| I005: PTSC: RefClockToPTSC 0 @ 1000000Hz -> 0 @ 3013327000Hz
2020-06-29T15:12:48.715+02:00| vmx| I005: PTSC: RefClockToPTSC ((x * 3159702372) >> 20) + -60227736028528
2020-06-29T15:12:48.715+02:00| vmx| I005: PTSC: tscOffset -60281352305454
2020-06-29T15:12:48.715+02:00| vmx| I005: PTSC: using TSC
2020-06-29T15:12:48.715+02:00| vmx| I005: PTSC: hardware TSCs are synchronized.
2020-06-29T15:12:48.715+02:00| vmx| I005: PTSC: current PTSC=86819
2020-06-29T15:12:48.715+02:00| vmx| I005: WQPoolAllocPoll : pollIx = 3, signalHandle = 17
2020-06-29T15:12:48.715+02:00| vmx| I005: MKSXlib: Initialized thread-safe Xlib
2020-06-29T15:12:48.718+02:00| vmx| I005: [0x55F12999F000-0x55F12A5E1722): /usr/lib/vmware/bin/vmware-vmx
2020-06-29T15:12:48.861+02:00| vmx| I005: ConfigCheck: No rules file found. Checks are disabled.
2020-06-29T15:12:48.861+02:00| vmx| I005: changing directory to /run/media/pheiduck/DATA/vmware/AL64bit/.
2020-06-29T15:12:48.861+02:00| vmx| I005: Config file: /run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmx
2020-06-29T15:12:48.861+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2020-06-29T15:12:48.861+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1878, success=1 additionalError=0
2020-06-29T15:12:48.900+02:00| vmx| W003: PowerOn
2020-06-29T15:12:48.900+02:00| vmx| I005: VMX_PowerOn: VMX build 16341506, UI build 16341506
2020-06-29T15:12:48.901+02:00| vmx| I005: libnuma.so found and in use.
2020-06-29T15:12:48.904+02:00| vmx| I005: NUMA topology found.
2020-06-29T15:12:48.904+02:00| vmx| I005: NUMA node 0: 3931MB, cpus 0x00000003 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:48.924+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1871, success=1 additionalError=0
2020-06-29T15:12:48.940+02:00| vmx| I005: HOST sysname Linux, nodename Workstation, release 5.7.6-1-MANJARO, version #1 SMP PREEMPT Wed Jun 24 22:06:49 UTC 2020, machine x86_64
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- GLOBAL SETTINGS /usr/lib/vmware/settings
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- NON PERSISTENT (null)
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- USER PREFERENCES /home/pheiduck/.vmware/preferences
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT   pref.lastUpdateCheckSec = "1593435534"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.keyboardAndMouse.vmHotKey.enabled = "FALSE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.keyboardAndMouse.vmHotKey.count = "0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT     prefvmx.defaultVMPath = "/run/media/pheiduck/DATA/vmware"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window.count = "1"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab.count = "1"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab0.cnxType = "vim"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.sidebar = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.sidebar.width = "207"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.statusBar = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tabs = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.thumbnailBar = "FALSE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.thumbnailBar.size = "0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.thumbnailBar.view = "same-folder"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.placement.left = "0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.placement.top = "0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.placement.right = "1920"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.placement.bottom = "1015"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.maximized = "FALSE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             hints.hideAll = "FALSE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab1.cnxType = "vim"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT   hint.vmui.poweroff.soft = "FALSE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT         hint.vmui.restart = "FALSE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT         vmWizard.guestKey = "other5xlinux-64"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT vmWizard.installMediaType = "iso"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab2.cnxType = "vmdb"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT  pref.sharedFolder.maxNum = "1"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.sharedFolder0.vmPath = "/vm/#63a4b0976e561066/"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.sharedFolder0.guestName = "DL"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.sharedFolder0.hostPath = "/home/pheiduck/Downloads"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.sharedFolder0.enabled = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT vmWizard.isoLocationMRU.count = "4"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT vmWizard.isoLocationMRU0.location = "/home/pheiduck/Downloads/archlinux-2020.06.01-x86_64.iso"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT vmWizard.isoLocationMRU1.location = "/home/pheiduck/Downloads/manjaro-architect-20.0.2-200601-linux56.iso"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab0.dest = "localhost"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab0.file = "folder:root"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab0.type = "cnx"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT pref.ws.session.window0.tab0.focused = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT vmWizard.isoLocationMRU2.location = "/home/pheiduck/Downloads/manjaro-architect-19.0.2-200324-linux54.iso"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT vmWizard.isoLocationMRU3.location = "/home/pheiduck/Downloads/Win10_1909_German_x64.iso"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- USER DEFAULTS /home/pheiduck/.vmware/config
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- HOST DEFAULTS /etc/vmware/config
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT              product.name = "VMware Workstation"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT           product.version = "15.5.0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT       product.buildNumber = "14665864"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT workstation.product.version = "15.5.0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT    player.product.version = "15.5.0"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        vix.config.version = "1"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                    bindir = "/usr/bin"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                    libdir = "/usr/lib/vmware"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                vix.libdir = "/usr/lib/vmware-vix"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             initscriptdir = "/usr/lib/systemd/scripts"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT           vmware.fullpath = "/usr/bin/vmware"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT            authd.fullpath = "/usr/bin/vmware-authd"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT           gksu.rootMethod = "su"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                NETWORKING = "yes"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT            VMBLOCK_CONFED = "no"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT               VMCI_CONFED = "no"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT              VSOCK_CONFED = "no"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT installerDefaults.autoSoftwareUpdateEnabled = "no"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT installerDefaults.dataCollectionEnabled = "no"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT installerDefaults.componentDownloadEnabled = "no"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT installerDefaults.transferVersion = "1"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             acceptOVFEULA = "yes"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                acceptEULA = "yes"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT         authd.client.port = "902"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT           authd.proxy.nfc = "vmware-hostd:ha-nfc"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- SITE DEFAULTS /usr/lib/vmware/config
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                  tag.help = "introduction.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT   tag.configurationEditor = "config_editor_newvm.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             tag.ideConfig = "devices_virtualdrive.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT          tag.floppyConfig = "devices_floppy.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT           tag.mouseConfig = "devices_mouse.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             tag.netConfig = "devices_netadapter.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        tag.parallelConfig = "devices_parallel.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT          tag.serialConfig = "devices_serial.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT           tag.soundConfig = "devices_sound.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             tag.memConfig = "configvm_memory.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT            tag.miscConfig = "configvm.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             tag.usbConfig = "devices_usb.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT         tag.displayConfig = "configvm_display-problems.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                 tag.tools = "vmtools.htm"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- NONPERSISTENT
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT            vmx.stdio.keep = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             gui.available = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- COMMAND LINE
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- RECORDING
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT --- CONFIGURATION /run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmx
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT            config.version = "8"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT         virtualHW.version = "16"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        pciBridge0.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        pciBridge4.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT     pciBridge4.virtualDev = "pcieRootPort"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT      pciBridge4.functions = "8"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        pciBridge5.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT     pciBridge5.virtualDev = "pcieRootPort"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT      pciBridge5.functions = "8"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        pciBridge6.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT     pciBridge6.virtualDev = "pcieRootPort"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT      pciBridge6.functions = "8"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        pciBridge7.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT     pciBridge7.virtualDev = "pcieRootPort"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT      pciBridge7.functions = "8"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             vmci0.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT             hpet0.present = "TRUE"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT                     nvram = "AL64bit.nvram"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT virtualHW.productCompatibility = "hosted"
2020-06-29T15:12:48.940+02:00| vmx| I005: DICT        powerType.powerOff = "soft"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         powerType.powerOn = "soft"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         powerType.suspend = "soft"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           powerType.reset = "soft"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT               displayName = "AL64bit"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT usb.vbluetooth.startConnected = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                   guestOS = "other5xlinux-64"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT            tools.syncTime = "FALSE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          sound.autoDetect = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT            sound.fileName = "-1"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             sound.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT               vcpu.hotadd = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                   memsize = "768"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                mem.hotadd = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          scsi0.virtualDev = "lsilogic"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             scsi0.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          scsi0:0.fileName = "AL64bit.vmdk"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           scsi0:0.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         ide1:0.deviceType = "cdrom-image"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           ide1:0.fileName = "/home/pheiduck/Downloads/archlinux-2020.06.01-x86_64.iso"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT            ide1:0.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT               usb.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  ethernet0.connectionType = "nat"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT     ethernet0.addressType = "generated"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT      ethernet0.virtualDev = "e1000"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          serial0.fileType = "thinprint"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          serial0.fileName = "thinprint"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         ethernet0.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           serial0.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT        extendedConfigFile = "AL64bit.vmxf"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           floppy0.present = "FALSE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                 uuid.bios = "56 4d ce d1 39 69 13 90-28 b8 81 c4 9a f0 91 b8"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             uuid.location = "56 4d ce d1 39 69 13 90-28 b8 81 c4 9a f0 91 b8"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT              scsi0:0.redo = ""
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  pciBridge0.pciSlotNumber = "17"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  pciBridge4.pciSlotNumber = "21"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  pciBridge5.pciSlotNumber = "22"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  pciBridge6.pciSlotNumber = "23"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  pciBridge7.pciSlotNumber = "24"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT       scsi0.pciSlotNumber = "16"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         usb.pciSlotNumber = "32"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT   ethernet0.pciSlotNumber = "33"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT       sound.pciSlotNumber = "34"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT       vmci0.pciSlotNumber = "35"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             svga.vramSize = "268435456"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT  vmotion.checkpointFBSize = "134217728"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT vmotion.checkpointSVGAPrimarySize = "268435456"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT ethernet0.generatedAddress = "00:0c:29:f0:91:b8"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT ethernet0.generatedAddressOffset = "0"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                  vmci0.id = "-1695510088"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT    monitor.phys_bits_used = "43"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             cleanShutdown = "FALSE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT              softPowerOff = "FALSE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT               usb:1.speed = "2"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             usb:1.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          usb:1.deviceType = "hub"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                usb:1.port = "1"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT              usb:1.parent = "-1"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             usb:0.present = "TRUE"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          usb:0.deviceType = "hid"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                usb:0.port = "0"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT              usb:0.parent = "-1"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT --- USER DEFAULTS ~/.vmware/config
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT --- HOST DEFAULTS /etc/vmware/config
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT              product.name = "VMware Workstation"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           product.version = "15.5.0"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT       product.buildNumber = "14665864"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT workstation.product.version = "15.5.0"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT    player.product.version = "15.5.0"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT        vix.config.version = "1"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                    bindir = "/usr/bin"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                    libdir = "/usr/lib/vmware"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                vix.libdir = "/usr/lib/vmware-vix"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             initscriptdir = "/usr/lib/systemd/scripts"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           vmware.fullpath = "/usr/bin/vmware"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT            authd.fullpath = "/usr/bin/vmware-authd"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           gksu.rootMethod = "su"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                NETWORKING = "yes"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT            VMBLOCK_CONFED = "no"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT               VMCI_CONFED = "no"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT              VSOCK_CONFED = "no"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT installerDefaults.autoSoftwareUpdateEnabled = "no"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT installerDefaults.dataCollectionEnabled = "no"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT installerDefaults.componentDownloadEnabled = "no"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT installerDefaults.transferVersion = "1"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             acceptOVFEULA = "yes"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                acceptEULA = "yes"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         authd.client.port = "902"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           authd.proxy.nfc = "vmware-hostd:ha-nfc"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT --- SITE DEFAULTS /usr/lib/vmware/config
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                  tag.help = "introduction.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT   tag.configurationEditor = "config_editor_newvm.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             tag.ideConfig = "devices_virtualdrive.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          tag.floppyConfig = "devices_floppy.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           tag.mouseConfig = "devices_mouse.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             tag.netConfig = "devices_netadapter.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT        tag.parallelConfig = "devices_parallel.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT          tag.serialConfig = "devices_serial.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT           tag.soundConfig = "devices_sound.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             tag.memConfig = "configvm_memory.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT            tag.miscConfig = "configvm.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT             tag.usbConfig = "devices_usb.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT         tag.displayConfig = "configvm_display-problems.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT                 tag.tools = "vmtools.htm"
2020-06-29T15:12:48.941+02:00| vmx| I005: DICT --- GLOBAL SETTINGS /usr/lib/vmware/settings
2020-06-29T15:12:48.941+02:00| vmx| I005: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2020-06-29T15:12:48.941+02:00| vmx| I005: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2020-06-29T15:12:48.942+02:00| vmx| I005: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2020-06-29T15:12:48.942+02:00| vmx| I005: ToolsISO: Selected Tools ISO 'linux.iso' for 'other5xlinux-64' guest.
2020-06-29T15:12:48.942+02:00| vmx| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2020-06-29T15:12:48.944+02:00| vmx| I005: Monitor Mode: CPL0
2020-06-29T15:12:48.981+02:00| vmx| I005: OvhdMem_PowerOn: initial admission: paged   508188 nonpaged    35085 anonymous     3931
2020-06-29T15:12:48.981+02:00| vmx| I005: VMMEM: Initial Reservation: 2137MB (MainMem=768MB)
2020-06-29T15:12:48.981+02:00| vmx| I005: MemSched_PowerOn: balloon minGuestSize 6553 (80% of min required size 8192)
2020-06-29T15:12:48.981+02:00| vmx| I005: MemSched: reserved mem (in MB) min 128 max 3444 recommended 3444
2020-06-29T15:12:48.981+02:00| vmx| I005: MemSched: pg 508188 np 35085 anon 3931 mem 196608
2020-06-29T15:12:48.981+02:00| vmx| I005: MemSched: numvm 1 locked pages: num 0 max 873472
2020-06-29T15:12:48.981+02:00| vmx| I005: MemSched: locked Page Limit: host 934543 config 881664 dynam 8589934591
2020-06-29T15:12:48.981+02:00| vmx| I005: MemSched: minmempct 50 minalloc 0 admitted 1
2020-06-29T15:12:48.981+02:00| vmx| I005: numa: Hot add is enabled and vNUMA hot add is disabled, forcing UMA.
2020-06-29T15:12:48.981+02:00| vmx| I005: Host: Disabling thread priority boosting to work around Linux SMP bug.
2020-06-29T15:12:48.988+02:00| vmx| I005: LICENSE using: '/usr/lib/vmware/licenses/site/license-ws-150-e2-201804'
2020-06-29T15:12:48.989+02:00| vthread-74492| I005: VTHREAD 140345659389696 "vthread-74492" tid 74492
2020-06-29T15:12:48.990+02:00| vmx| I005: PolicyVMXFindPolicyKey: policy file does not exist.
2020-06-29T15:12:48.990+02:00| vmx| W003: VProbes facility is disabled.
2020-06-29T15:12:48.991+02:00| vmx| I005: ToolsISO: Refreshing imageName for 'other5xlinux-64' (refreshCount=1, lastCount=1).
2020-06-29T15:12:48.991+02:00| vmx| I005: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2020-06-29T15:12:48.991+02:00| vmx| I005: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2020-06-29T15:12:48.991+02:00| vmx| I005: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2020-06-29T15:12:48.991+02:00| vmx| I005: ToolsISO: Selected Tools ISO 'linux.iso' for 'other5xlinux-64' guest.
2020-06-29T15:12:48.998+02:00| deviceThread| I005: VTHREAD 140345650996992 "deviceThread" tid 74493
2020-06-29T15:12:48.999+02:00| vmx| I005: Host AMD-V Capabilities:
2020-06-29T15:12:48.999+02:00| vmx| I005: SVM Revision:           1
2020-06-29T15:12:48.999+02:00| vmx| I005: ASIDs Supported:        64
2020-06-29T15:12:48.999+02:00| vmx| I005: Nested Paging:          yes
2020-06-29T15:12:48.999+02:00| vmx| I005: SVM GMET:               no
2020-06-29T15:12:48.999+02:00| vmx| I005: LBR Virtualization:     yes
2020-06-29T15:12:48.999+02:00| vmx| I005: SVM Lock:               yes
2020-06-29T15:12:48.999+02:00| vmx| I005: NRIP Save:              yes
2020-06-29T15:12:48.999+02:00| vmx| I005: TSC Rate MSR:           no
2020-06-29T15:12:48.999+02:00| vmx| I005: VMCB Clean Bits:        no
2020-06-29T15:12:48.999+02:00| vmx| I005: Flush by ASID:          no
2020-06-29T15:12:48.999+02:00| vmx| I005: Decode Assists:         no
2020-06-29T15:12:48.999+02:00| vmx| I005: Pause Filter:           no
2020-06-29T15:12:48.999+02:00| vmx| I005: Pause Filter Threshold: no
2020-06-29T15:12:48.999+02:00| vmx| I005: Monitor_PowerOn: HostedVSMP skew tracking is disabled
2020-06-29T15:12:48.999+02:00| vmx| I005: Loaded crosspage: .crosspage. Size = 4096 bytes.
2020-06-29T15:12:48.999+02:00| vmx| I005: vmm64-modules: [vmm.vmm64, vmce-vmce.vmm64, viommu-none.vmm64, vprobe-none.vmm64, hv-svm.vmm64, gphys-npt.vmm64, callstack-none.vmm64, gi-none.vmm64, gmm-none.vmm64, !e1000Shared=0x0, !vmSamples=0x880, !theIOSpace=0x8c0, !ttGPPerVcpu=0x6c00, {UseUnwind}=0x0, numVCPUsAsAddr=0x1, {SharedAreaReservations}=0x6c40, {rodataSize}=0x1f860, {textAddr}=0xfffffffffc000000, {textSize}=0x88743, <MonSrcFile>]
2020-06-29T15:12:48.999+02:00| vmx| I005: vmm64-vcpus:   1
2020-06-29T15:12:49.007+02:00| deviceThread| I005: Device thread is alive
2020-06-29T15:12:49.023+02:00| vmx| I005: KHZEstimate 3013327
2020-06-29T15:12:49.023+02:00| vmx| I005: MHZEstimate 3013
2020-06-29T15:12:49.023+02:00| vmx| I005: NumVCPUs 1
2020-06-29T15:12:49.024+02:00| vmx| I005: UUID: Unable to open /sys/firmware/efi/systab: No such file or directory
2020-06-29T15:12:49.024+02:00| vmx| I005: UUID: Found _DMI_ signature.
2020-06-29T15:12:49.024+02:00| vmx| I005: UUID: SMBIOS UUID is reported as '37 34 44 34 33 35 33 34-32 30 31 37 ff ff ff ff'.
2020-06-29T15:12:49.024+02:00| vmx| I005: AIOGNRC: numThreads=18 ide=0, scsi=1, passthru=1
2020-06-29T15:12:49.024+02:00| vmx| I005: WORKER: Creating new group with maxThreads=18 (18)
2020-06-29T15:12:49.027+02:00| aioKernelPollWorker| I005: VTHREAD 140345572587264 "aioKernelPollWorker" tid 74494
2020-06-29T15:12:49.029+02:00| vmx| I005: AIOKERN: Manager initialized successfully
2020-06-29T15:12:49.029+02:00| vmx| I005: AIOKERN: PowerOn successfully added the 'Kernel' AIO manager interface
2020-06-29T15:12:49.042+02:00| vmx| I005: WORKER: Creating new group with maxThreads=1 (19)
2020-06-29T15:12:49.042+02:00| vmx| I005: MainMem: CPT Host WZ=0 PF=768 D=0
2020-06-29T15:12:49.042+02:00| vmx| I005: MainMem: CPT PLS=1 PLR=1 BS=1 BlkP=32 Mult=4 W=50
2020-06-29T15:12:49.042+02:00| vmx| I005: MsgHint: msg.mainMem.backing.noSwap
2020-06-29T15:12:49.042+02:00| vmx| I005+ VMware Workstation recommends 384 MB of system swap space for the set of currently running virtual machines. 0 bytes of system swap space is available. For optimum performance increase the amount of system swap space, or configure all virtual machine memory to use reserved host RAM under Preferences.
2020-06-29T15:12:49.042+02:00| vmx| I005+ ---------------------------------------
2020-06-29T15:12:51.263+02:00| vmx| I005: FILE: FileLockScanDirectory discarding M07921.lck from /run/media/pheiduck/DATA/vmware/AL64bit/564dced1-3969-1390-28b8-81c49af091b8.vmem.lck': invalid executionID 74303-1990697(vmware-vmx).
2020-06-29T15:12:51.278+02:00| vmx| I005: MainMem: Opened paging file, '/run/media/pheiduck/DATA/vmware/AL64bit/564dced1-3969-1390-28b8-81c49af091b8.vmem'.
2020-06-29T15:12:51.278+02:00| vmx| I005: MStat: Creating Stat vm.uptime
2020-06-29T15:12:51.278+02:00| vmx| I005: MStat: Creating Stat vm.suspendTime
2020-06-29T15:12:51.278+02:00| vmx| I005: MStat: Creating Stat vm.powerOnTimeStamp
2020-06-29T15:12:51.278+02:00| vmx| I005: VMXAIOMGR: Using: simple=Generic
2020-06-29T15:12:51.280+02:00| vmx| I005: WORKER: Creating new group with maxThreads=1 (20)
2020-06-29T15:12:51.281+02:00| vmx| I005: WORKER: Creating new group with maxThreads=16 (36)
2020-06-29T15:12:51.283+02:00| vmx| I005: FeatureCompat: No VM masks.
2020-06-29T15:12:51.283+02:00| vmx| I005: TimeTracker host to guest rate conversion 7739271390 @ 3013327000Hz -> 0 @ 3013327000Hz
2020-06-29T15:12:51.283+02:00| vmx| I005: TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + -7739271390
2020-06-29T15:12:51.283+02:00| vmx| I005: Disabling TSC scaling since host does not support it.
2020-06-29T15:12:51.283+02:00| vmx| I005: TSC offsetting enabled.
2020-06-29T15:12:51.283+02:00| vmx| I005: timeTracker.globalProgressMaxAllowanceMS: 2000
2020-06-29T15:12:51.283+02:00| vmx| I005: timeTracker.globalProgressToAllowanceNS: 1000
2020-06-29T15:12:51.283+02:00| vmx| I005: MKS PowerOn
2020-06-29T15:12:51.317+02:00| mks| I005: VTHREAD 140345564194560 "mks" tid 74498
2020-06-29T15:12:51.317+02:00| mks| I005: MKS thread is alive
2020-06-29T15:12:51.318+02:00| mks| I005: MKS-RenderMain: PowerOn allowed MKSBasicOps
2020-06-29T15:12:51.318+02:00| mks| I005: MKS-RenderMain: Collecting RenderOps caps from MKSBasicOps
2020-06-29T15:12:51.318+02:00| mks| I005: MKS-RenderMain: Started MKSBasicOps
2020-06-29T15:12:51.318+02:00| mks| I005: MKS-RenderMain: Found Full Renderer: MKSBasicOps
2020-06-29T15:12:51.318+02:00| mks| I005: MKS-RenderMain: MinimalCaps: maxTextureSize=32768
2020-06-29T15:12:51.318+02:00| mks| I005: SOCKET creating new socket listening on /tmp/vmware-pheiduck/mksctrl/mksctrl-0000074463-000-63b42519
2020-06-29T15:12:51.318+02:00| mks| I005: SOCKET 1 (80) creating new listening socket on port -1
2020-06-29T15:12:51.324+02:00| mks| I005: KHBKL: Unable to parse keystring at: ''
2020-06-29T15:12:51.324+02:00| mks| I005: MKSRemoteMgr: Set default display name: AL64bit
2020-06-29T15:12:51.324+02:00| mks| I005: MKSRemoteMgr: Loading VNC Configuration from VM config file
2020-06-29T15:12:51.324+02:00| vmx| I005: VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 20000 us
2020-06-29T15:12:51.325+02:00| vmx| I005: VMXNET: send cluster threshold is 80, size = 2 recalcInterval is 20000 ticks, dontClusterSize is 128
2020-06-29T15:12:51.326+02:00| vmx| I005: Chipset version: 0x17
2020-06-29T15:12:51.353+02:00| vmx| I005: SOUNDLIB: SoundLib_CreatePulseBackend: waiting for connection to Pulse server
2020-06-29T15:12:51.372+02:00| vmx| I005: MigrateBusMemPrealloc: BusMem preallocation begins.
2020-06-29T15:12:51.372+02:00| vmx| I005: MigrateBusMemPrealloc: BusMem preallocation completes.
2020-06-29T15:12:51.373+02:00| worker-74492| A000: ConfigDB: Setting scsi0:0.redo = ""
2020-06-29T15:12:51.374+02:00| worker-74492| I005: DISK: OPEN scsi0:0 '/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk' persistent R[]
2020-06-29T15:12:51.374+02:00| worker-74492| I005: FILE: FileLockScanDirectory discarding M55537.lck from /run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk.lck': invalid executionID 74303-1990697(vmware-vmx).
2020-06-29T15:12:51.375+02:00| worker-74492| I005: DISKLIB-DSCPTR: Opened [0]: "AL64bit.vmdk" (0xa)
2020-06-29T15:12:51.375+02:00| worker-74492| I005: DISKLIB-LINK  : Opened '/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk' (0xa): monolithicSparse, 167772160 sectors / 80 GB.
2020-06-29T15:12:51.375+02:00| worker-74492| I005: DISKLIB-LIB   : Opened "/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk" (flags 0xa, type monolithicSparse).
2020-06-29T15:12:51.375+02:00| worker-74492| I005: DISKLIB-LIB_MISC   : DiskLib_GetStorageBlockSizes: Failed to get storage block sizes, The virtual disk requires a feature not supported by this program.
2020-06-29T15:12:51.375+02:00| worker-74492| I005: DiskGetGeometry: Reading of disk partition table
2020-06-29T15:12:51.376+02:00| vthread-74500| I005: VTHREAD 140345547347712 "vthread-74500" tid 74500
2020-06-29T15:12:51.377+02:00| worker-74492| I005: DISK: Disk '/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk' has UUID '60 00 c2 92 c2 0f 2e dd-20 5a 73 c1 22 f5 9e b2'
2020-06-29T15:12:51.377+02:00| worker-74492| I005: DISK: OPEN '/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk' Geo (10443/255/63) BIOS Geo (0/0/0)
2020-06-29T15:12:51.378+02:00| worker-74492| I005: DISK: DiskConfigureVirtualSSD:  Disk 'scsi0:0' identified as Virtual SSD device.
2020-06-29T15:12:51.378+02:00| vmx| I005: DISK: Opening disks took 5 ms.
2020-06-29T15:12:51.379+02:00| vmx| I005: SOCKET creating new socket, connecting to /var/run/vmware/usbarbitrator-socket
2020-06-29T15:12:51.382+02:00| vmx| I005: USB: Initializing 'Virtual Hub' backend
2020-06-29T15:12:51.382+02:00| vmx| I005: USB: Initializing 'Generic' backend
2020-06-29T15:12:51.382+02:00| vmx| I005: USB: Initializing 'Virtual HID' backend
2020-06-29T15:12:51.382+02:00| vmx| I005: USB: Initializing 'Remote Device' backend
2020-06-29T15:12:51.383+02:00| vmx| I005: RemoteUSBVMX: Retrieved hostId [37 34 44 34 33 35 33 34-32 30 31 37 ff ff ff ff]
2020-06-29T15:12:51.383+02:00| vmx| I005: RemoteUSBVMX: Protocol version min:15 current:17
2020-06-29T15:12:51.383+02:00| vmx| I005: RemoteUSBVMX: no delay setting is TRUE.
2020-06-29T15:12:51.383+02:00| vmx| I005: USB: Initializing 'Virtual Mass Storage' backend
2020-06-29T15:12:51.383+02:00| vmx| I005: USB: Initializing 'Virtual RNG' backend
2020-06-29T15:12:51.383+02:00| vmx| I005: USB: Initializing 'Virtual CCID' backend
2020-06-29T15:12:51.383+02:00| vmx| I005: USB-CCID:  dlopened default libpcsclite.so.1.
2020-06-29T15:12:51.383+02:00| vmx| I005: USB-CCID: Could not establish context: SCARD_E_NO_SERVICE(0x8010001d).
2020-06-29T15:12:51.384+02:00| vmx| W003: Could not initialize emulated USB smart card subsystem.
2020-06-29T15:12:51.384+02:00| vmx| I005: USB: Unable to initialize 'Virtual CCID' backend
2020-06-29T15:12:51.384+02:00| vmx| I005: USB: Initializing 'Virtual Bluetooth' backend
2020-06-29T15:12:51.384+02:00| vmx| I005: USB: Initializing 'Virtual Audio' backend
2020-06-29T15:12:51.384+02:00| vmx| I005: USB: Initializing 'Virtual Video' backend
2020-06-29T15:12:51.390+02:00| vmx| I005: USBGL: Skipping disk backing for file (/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmx).
2020-06-29T15:12:51.391+02:00| vmx| I005: USBGL: Skipping disk backing for file (/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmdk).
2020-06-29T15:12:51.391+02:00| vmx| I005: USBGL: Skipping disk backing for file (/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.vmsd).
2020-06-29T15:12:51.396+02:00| vmx| I005: USBGL: Skipping disk backing for file (/run/media/pheiduck/DATA/vmware/AL64bit/AL64bit.nvram).
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge4.pciSlotNumber = "-1"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge5.pciSlotNumber = "-1"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge6.pciSlotNumber = "-1"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge7.pciSlotNumber = "-1"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge4.pciSlotNumber = "21"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge5.pciSlotNumber = "22"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge6.pciSlotNumber = "23"
2020-06-29T15:12:51.397+02:00| vmx| A000: ConfigDB: Setting pciBridge7.pciSlotNumber = "24"
2020-06-29T15:12:51.438+02:00| vmx| I005: SCSI DEVICE (ide1:0): Computed value of ide1:0.useBounceBuffers: default
2020-06-29T15:12:51.438+02:00| vmx| I005: DISKUTIL: ide1:0 : capacity=0 logical sector size=2048
2020-06-29T15:12:51.438+02:00| vmx| I005: DISKUTIL: ide1:0 : geometry=0/0/0
2020-06-29T15:12:51.438+02:00| vmx| I005: SCSI: scsi0: intr coalescing: on period=50msec cifTh=4 iopsTh=2000 hlt=0
2020-06-29T15:12:51.438+02:00| vmx| I005: SCSI0: UNTAGGED commands will be converted to ORDER tags.
2020-06-29T15:12:51.438+02:00| vmx| I005: SCSI DEVICE (scsi0:0): Computed value of scsi0:0.useBounceBuffers: default
2020-06-29T15:12:51.438+02:00| vmx| I005: DISKUTIL: scsi0:0 : capacity=167772160 logical sector size=512
2020-06-29T15:12:51.438+02:00| vmx| I005: DISKUTIL: scsi0:0 : geometry=10443/255/63
2020-06-29T15:12:51.439+02:00| vmx| I005: SVGA-GFB: Config settings: autodetect=1, numDisplays=1, maxWidth=2560, maxHeight=1600
2020-06-29T15:12:51.439+02:00| vmx| I005: SVGA-GFB: Desired maximum display topology: wh(6688, 5016)
2020-06-29T15:12:51.439+02:00| vmx| I005: SVGA-GFB: Autodetected target gfbSize = 268435456
2020-06-29T15:12:51.439+02:00| vmx| I005: SVGA-GFB: Using Initial       gfbSize = 134217728
2020-06-29T15:12:51.439+02:00| vmx| I005: SVGA-GFB: MaxPrimaryMem      register = 268435456
2020-06-29T15:12:51.439+02:00| vmx| I005: SVGA-GFB: Max wh(6688, 5016), number of displays: 10
2020-06-29T15:12:51.440+02:00| vmx| I005: SVGA-GFB: Allocated gfbSize=134217728
2020-06-29T15:12:51.440+02:00| vmx| A000: ConfigDB: Setting vmotion.checkpointFBSize = "134217728"
2020-06-29T15:12:51.440+02:00| vmx| A000: ConfigDB: Setting vmotion.checkpointSVGAPrimarySize = "268435456"
2020-06-29T15:12:51.442+02:00| vmx| I005: SVGACaps: Device       caps : 0xfdff83e2
2020-06-29T15:12:51.442+02:00| vmx| I005: SVGACaps: Device       caps2: 0x00000007
2020-06-29T15:12:51.442+02:00| vmx| I005: SVGA: mobMaxSize=134217728
2020-06-29T15:12:51.442+02:00| vmx| I005: SVGA: graphicsMemoryKB=262144
2020-06-29T15:12:51.442+02:00| vmx| I005: SVGA: FIFO capabilities 0x0000077f
2020-06-29T15:12:51.453+02:00| vmx| I005: SVGA3dClamp: Renderer Provides     BC67Level:     0 (    0,     0)
2020-06-29T15:12:51.453+02:00| vmx| I005: SVGA3dClamp: Renderer Provides BaseCapsLevel:     0 (    0,     0)
2020-06-29T15:12:51.453+02:00| vmx| I005: SVGA3dClamp: Renderer Provides    ClampLevel:     0 (    0,     0)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dCaps: host, at power on: 3d disabled
2020-06-29T15:12:51.454+02:00| vmx| I005:   cap[ 19]: 0x00002000 (MAX_TEXTURE_WIDTH)
2020-06-29T15:12:51.454+02:00| vmx| I005:   cap[ 20]: 0x00002000 (MAX_TEXTURE_HEIGHT)
2020-06-29T15:12:51.454+02:00| vmx| I005:   cap[ 93]: 0x00000001 (TS_COLOR_KEY)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dClamp:     Host Provides     BC67Level:     0 (    0,     0)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dClamp:     Host Provides BaseCapsLevel:     0 (    0,     4)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dClamp:     Host Provides    ClampLevel:     0 (    0,     0)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dCaps: guest, compatibility level: 8
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dClamp:    Guest Requires     BC67Level:     0 (    0,     0)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dClamp:    Guest Requires BaseCapsLevel:     0 (    0,     0)
2020-06-29T15:12:51.454+02:00| vmx| I005: SVGA3dClamp:    Guest Requires    ClampLevel:     0 (    0,     0)
2020-06-29T15:12:51.454+02:00| svga| I005: VTHREAD 140345538397952 "svga" tid 74501
2020-06-29T15:12:51.454+02:00| vmx| I005: USB: Initializing 'UHCI' host controller
2020-06-29T15:12:51.455+02:00| vmx| A000: ConfigDB: Setting usb:0.present = "TRUE"
2020-06-29T15:12:51.455+02:00| vmx| A000: ConfigDB: Setting usb:0.deviceType = "hid"
2020-06-29T15:12:51.455+02:00| vmx| A000: ConfigDB: Setting usb:0.port = "0"
2020-06-29T15:12:51.455+02:00| vmx| A000: ConfigDB: Setting usb:0.parent = "-1"
2020-06-29T15:12:51.470+02:00| vmx| A000: ConfigDB: Setting usb:1.speed = "2"
2020-06-29T15:12:51.470+02:00| vmx| I005: Ethernet0 MAC Address: 00:0c:29:f0:91:b8
2020-06-29T15:12:51.472+02:00| vmx| I005: SOUND 992.540684 Alsa library version: 1.2.3.1.
2020-06-29T15:12:51.473+02:00| vmx| A000: ConfigDB: Setting vmci0.id = "-1695510088"
2020-06-29T15:12:51.520+02:00| vmx| I005: WORKER: Creating new group with maxThreads=1 (37)
2020-06-29T15:12:51.520+02:00| vmx| I005: DISKUTIL: (null) : max toolsVersion = 0, type = 0
2020-06-29T15:12:51.521+02:00| vmx| I005: DISKUTIL: Offline toolsVersion = 0, type = 0
2020-06-29T15:12:51.521+02:00| vmx| I005: TOOLS setting legacy tools version to '0' type 0, manifest status is 9
2020-06-29T15:12:51.521+02:00| vmx| I005: ToolsISO: Refreshing imageName for 'other5xlinux-64' (refreshCount=1, lastCount=1).
2020-06-29T15:12:51.521+02:00| vmx| I005: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2020-06-29T15:12:51.521+02:00| vmx| I005: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2020-06-29T15:12:51.521+02:00| vmx| I005: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2020-06-29T15:12:51.521+02:00| vmx| I005: ToolsISO: Selected Tools ISO 'linux.iso' for 'other5xlinux-64' guest.
2020-06-29T15:12:51.521+02:00| vmx| I005: TOOLS updated cached value for isoImageExists to 1.
2020-06-29T15:12:51.521+02:00| vmx| I005: VMXVmdb_SetToolsVersionStatus: status value set to 'noTools', 'noTools', install possible
2020-06-29T15:12:51.522+02:00| vmx| I005: ToolsISO: Refreshing imageName for 'other5xlinux-64' (refreshCount=1, lastCount=1).
2020-06-29T15:12:51.522+02:00| vmx| I005: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2020-06-29T15:12:51.522+02:00| vmx| I005: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2020-06-29T15:12:51.522+02:00| vmx| I005: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2020-06-29T15:12:51.522+02:00| vmx| I005: ToolsISO: Selected Tools ISO 'linux.iso' for 'other5xlinux-64' guest.
2020-06-29T15:12:51.522+02:00| vmx| I005: TOOLS updated cached value for isoImageExists to 1.
2020-06-29T15:12:51.522+02:00| vmx| I005: VMXVmdb_SetToolsVersionStatus: status value set to 'noTools', 'noTools', install possible
2020-06-29T15:12:51.522+02:00| vmx| I005: Tools: sending 'OS_PowerOn' (state = 3) state change request
2020-06-29T15:12:51.522+02:00| vmx| I005: Tools: Delaying state change request to state 3.
2020-06-29T15:12:51.522+02:00| vmx| I005: TOOLS INSTALL initializing state to IDLE on power on.
2020-06-29T15:12:51.523+02:00| vmx| I005: P9FS_PowerOn: 9PFS server is not enabled.
2020-06-29T15:12:51.523+02:00| vmx| I005: HgfsServerManagerVigorInit: Initialize: dev api
2020-06-29T15:12:51.523+02:00| vmx| I005: DEPLOYPKG: No pending deploy package name set
2020-06-29T15:12:51.523+02:00| vmx| I005: DEPLOYPKG: ToolsDeployPkgPublishState: state=0, code=0, message=(null)
2020-06-29T15:12:51.524+02:00| vmx| I005: MonPmc: ctrBase 0xc0010004 selBase 0xc0010000/1 PGC 0/0 SMM 0 drain 0 AMD 1
2020-06-29T15:12:51.524+02:00| vmx| I005+ MonPmc:   gen counters num: 4 width 48 write width 48
2020-06-29T15:12:51.524+02:00| vmx| I005+ MonPmc:   fix counters num: 0 width 0; version 0
2020-06-29T15:12:51.524+02:00| vmx| I005+ MonPmc:   unavailable counters: 0
2020-06-29T15:12:51.537+02:00| vmx| A000: ConfigDB: Setting monitor.phys_bits_used = "43"
2020-06-29T15:12:51.537+02:00| vmx| I005: Full guest CPUID with differences from hostCPUID highlighted.
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest vendor: AuthenticAMD
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest family: 0x10 model: 0x6 stepping: 0x3
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest codename: K10 Opteron -- Unknown codename
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest name: AMD Athlon(tm) II X2 250 Processor
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID       level eaxIn, ecxIn:        eax        ebx        ecx        edx
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 00000000,  0: 0x00000005 0x68747541 0x444d4163 0x69746e65
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 00000001,  0: 0x00100f63 0x00000800 0x80802001 0x078bfbff
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID *host level 00000001,  0: 0x00100f63 0x00020800 0x00802009 0x178bfbff
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 40000000,  0: 0x40000010 0x61774d56 0x4d566572 0x65726177
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 40000010,  0: 0x002dfacf 0x000101d0 0x00000000 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000000,  0: 0x8000001b 0x68747541 0x444d4163 0x69746e65
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000001,  0: 0x00100f63 0x10001b26 0x000003f9 0xefd3fbff
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID *host level 80000001,  0: 0x00100f63 0x10001b26 0x000037ff 0xefd3fbff
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000002,  0: 0x20444d41 0x6c687441 0x74286e6f 0x4920296d
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000003,  0: 0x32582049 0x30353220 0x6f725020 0x73736563
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000004,  0: 0x0000726f 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000005,  0: 0xff30ff10 0xff30ff20 0x40020140 0x40020140
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000006,  0: 0x20800000 0x42004200 0x04008140 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000007,  0: 0x00000000 0x00000003 0x00000000 0x00000100
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID *host level 80000007,  0: 0x00000000 0x00000000 0x00000000 0x000001f9
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000008,  0: 0x0000302b 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID *host level 80000008,  0: 0x00003030 0x00000000 0x00002001 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 80000019,  0: 0xf0300000 0x60100000 0x00000000 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 8000001a,  0: 0x00000003 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: guest vs. host CPUID guest level 8000001b,  0: 0x0000001f 0x00000000 0x00000000 0x00000000
2020-06-29T15:12:51.537+02:00| vmx| I005: Minimum ucode level: 0x010000c8
2020-06-29T15:12:51.537+02:00| vmx| I005: VPMC: events will use hybrid freeze.
2020-06-29T15:12:51.537+02:00| vmx| I005: VPMC: gen counters: num 4 mask 0xffffffffffff
2020-06-29T15:12:51.537+02:00| vmx| I005: VPMC: hardware counters: 0
2020-06-29T15:12:51.538+02:00| vmx| I005: SVGA-PCI: BAR gfbSize=134217728, fifoSize=8388608
2020-06-29T15:12:51.538+02:00| vmx| I005: SVGA: SVGA_REG_MEMORY_SIZE=134217728
2020-06-29T15:12:51.538+02:00| vmx| I005: SVGA: SVGA_REG_VRAM_SIZE=134217728
2020-06-29T15:12:51.538+02:00| vmx| I005: BusMemSampleSetUpStats: touched: initPct 75 pages 147456 : dirtied: initPct 75 pages 147456
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: caller 0 numvm 1 locked pages: num 1108 max 873472
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: locked Page Limit: host 934504 config 881664 dynam 8589934591
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: minmempct 50  timestamp 19989
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: VM 0 min 136872 max 235176 shares 196608 paged 508188 nonpaged 34637 anonymous 3931 locked 1108 touchedPct 75 dirtiedPct 75 timestamp 19989 vmResponsive is 1
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: locked 1108 target 235176 balloon 0 0 0 swapped 0 0 allocd 0 512 state 0 100
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: states: 0 1 : 1 0 : 2 0 : 3 0
2020-06-29T15:12:51.538+02:00| vmx| I005: MemSched: Balloon enabled 1 guestType 0 maxSize 0
2020-06-29T15:12:51.539+02:00| vmx| I005: PStrIntern expansion: nBkts=256
2020-06-29T15:12:51.539+02:00| vmx| I005: FeatureCompat: Capabilities:
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.sse3 = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.mwait = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.cmpxchg16b = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.popcnt = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.lahf64 = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.svm = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.extapicspc = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.cr8avail = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.abm = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.sse4a = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.misaligned_sse = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.3dnprefetch = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.nx = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.mmxext = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.ffxsr = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.pdpe1gb = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.rdtscp = 1
2020-06-29T15:12:51.539+02:00| vmx| I005: Capability Found: cpuid.lm = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: cpuid.3dnowplus = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: cpuid.3dnow = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: cpuid.svm_npt = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: cpuid.svm_nrip = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: cpuid.amd = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: hv.capable = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.microarchitecture.shanghai = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.numgenctrs = 4
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.genwidth = 0x30
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.genctr.0 = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.genctr.1 = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.genctr.2 = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: Capability Found: vpmc.genctr.3 = 1
2020-06-29T15:12:51.540+02:00| vmx| I005: FeatureCompat: Requirements:
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.sse3 - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.cmpxchg16b - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.popcnt - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.lahf64 - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.extapicspc - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.cr8avail - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.abm - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.sse4a - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.misaligned_sse - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.3dnprefetch - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.nx - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.mmxext - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.ffxsr - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.pdpe1gb - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.rdtscp - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.lm - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.3dnowplus - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.3dnow - Bool:Min:1
2020-06-29T15:12:51.540+02:00| vmx| I005: VM Features Required: cpuid.amd - Bool:Min:1
2020-06-29T15:12:51.548+02:00| vmx| I005: TOOLS received request in VMX to set option 'enableDnD' -> '1'
2020-06-29T15:12:51.550+02:00| vmx| I005: Active HV capabilities
2020-06-29T15:12:51.550+02:00| vmx| I005:    Address space identifiers
2020-06-29T15:12:51.550+02:00| vmx| I005:    MSR permission bitmap
2020-06-29T15:12:51.550+02:00| vmx| I005:    Nested paging A/D bits
2020-06-29T15:12:51.550+02:00| vmx| I005:    Next RIP
2020-06-29T15:12:51.550+02:00| vmx| I005:    Guest physical width
2020-06-29T15:12:51.550+02:00| vmx| I005:    Real-address mode
2020-06-29T15:12:51.550+02:00| vmx| I005+ OvhdMem: Static (Power On) Overheads
2020-06-29T15:12:51.550+02:00| vmx| I005:                                                       reserved      |          used
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem excluded                                  cur    max    avg |    cur    max    avg
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_MainMem                    :  196608 196608      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxText                    :    7168   7168      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxTextLibs                :   15360  15360      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem Total excluded                      :  219136 219136      - |      -      -      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem Actual maximum                      :         219136        |             -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem paged                                     cur    max    avg |    cur    max    avg
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_STATS_vmm                  :       2      2      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_STATS_device               :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SvgaMobFallback            :   32768  32768      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_DiskLibMemUsed             :    3075   3075      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SvgaSurfaceTable           :       6      6      - |      1      1      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SvgaBESurfaceTable         :      22     22      - |      6      6      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SvgaSDirtyCache            :      96     96      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SvgaCursor                 :      10     10      - |     10     10      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxGlobals                 :   10240  10240      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxGlobalsLibs             :    3584   3584      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxHeap                    :    8704   8704      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMks                     :      33     33      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMksRenderOps            :     552    552      - |    552    552      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMks3d                   :  131072 131072      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMksScreenTemp           :   69890  69890      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMksVnc                  :   74936  74936      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMksScreen               :  131075 131075      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMksSVGAVO               :    4096   4096      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxMksSwbCursor            :    2560   2560      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxPhysMemErrPages         :      10     10      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxSLEntryBuf              :     128    128      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VmxThreads                 :   35328  35328      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem Total paged                         :  508188 508188      - |    569    569      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem Actual maximum                      :         508188        |           569
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem nonpaged                                  cur    max    avg |    cur    max    avg
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SharedArea                 :     106    106      - |     89     89      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_BusMemTraceBitmap          :      10     10      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_PFrame                     :     881   1097      - |    881    881      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VIDE_KSEG                  :      16     16      - |     16     16      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VGA                        :      64     64      - |     64     64      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_BalloonMPN                 :       1      1      - |      1      1      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_P2MUpdateBuffer            :       3      3      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_ServicesMPN                :       3      3      - |      3      3      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_LocalApic                  :       2      2      - |      1      1      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_BusError                   :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_VBIOS                      :       8      8      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_LSIBIOS                    :       4      4      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_LSIRings                   :       4      4      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SAS1068BIOS                :       4      4      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SBIOS                      :      16     16      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_FlashRam                   :     128    128      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SMM                        :      63     63      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SVGAFB                     :   32768  32768      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_SVGAMEM                    :      64    512      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_HDAudioReg                 :       3      3      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_EHCIRegister               :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_XhciRegister               :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_HyperV                     :       2      2      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_ExtCfg                     :       4      4      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_vhvCachedVMCS              :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_vhvNestedAPIC              :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_MonWired                   :      33     33      - |     33     33      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_MonNuma                    :     228    228      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdUser_NVDC                       :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem Total nonpaged                      :   34421  35085      - |   1088   1088      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem Actual maximum                      :          35085        |          1088
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem anonymous                                 cur    max    avg |    cur    max    avg
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_Alloc                       :      97     97      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_BusMemFrame                 :     289    298      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_BusMem2MInfo                :       3      3      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_BusMem1GInfo                :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_BusMemZapListMPN            :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_MonAS                       :       1      1      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_GuestMem                    :      24     24      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_TC                          :     513    513      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_BusMemMonAS                 :       4      4      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_PlatformMonAS               :       5      5      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_HVNuma                      :       2      2      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_HV                          :       3      3      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_HVMSRBitmap                 :       2      2      - |      0      0      -
2020-06-29T15:12:51.550+02:00| vmx| I005: OvhdMem OvhdMon_VHVGuestMSRBitmap           :       2      2      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_VHV                         :       3      3      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_SVMIDT                      :       1      1      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_Numa                        :      24     24      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_NumaTextRodata              :     201    201      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_NumaDataBss                 :      27     27      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_BaseWired                   :      29     29      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_Bootstrap                   :    1703   1703      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_GPhysHWMMU                  :     612    612      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_GPhysNoTrace                :     264    264      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_PhysMemGart                 :     104    104      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_PhysMemErr                  :       6      6      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem OvhdMon_VProbe                      :       1      1      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem Total anonymous                     :    3922   3931      - |      0      0      -
2020-06-29T15:12:51.551+02:00| vmx| I005: OvhdMem Actual maximum                      :           3931        |             0
2020-06-29T15:12:51.551+02:00| vmx| I005+
2020-06-29T15:12:51.551+02:00| vmx| I005: VMMEM: Precise Reservation: 2134MB (MainMem=768MB)
2020-06-29T15:12:51.551+02:00| vmx| I005: Vix: [mainDispatch.c:1050]: VMAutomation_PowerOn. Powering on.
2020-06-29T15:12:51.572+02:00| vmx| I005: VMX_PowerOn: ModuleTable_PowerOn = 1
2020-06-29T15:12:51.572+02:00| vmx| A000: ConfigDB: Setting cleanShutdown = "FALSE"
2020-06-29T15:12:51.572+02:00| vmx| A000: ConfigDB: Setting softPowerOff = "FALSE"
2020-06-29T15:12:51.576+02:00| vcpu-0| I005: VTHREAD 140345533060864 "vcpu-0" tid 74502
2020-06-29T15:12:51.584+02:00| vcpu-0| I005: MonTimer APIC:0/0 vec: 0
2020-06-29T15:12:51.584+02:00| vcpu-0| I005: APIC: version = 0x10, max LVT = 5, LDR = 0x1000000, DFR = 0xffffffff
2020-06-29T15:12:51.586+02:00| svga| I005: SVGA thread is alive
2020-06-29T15:12:51.586+02:00| vcpu-0| I005: CPU reset: hard (mode Interp)
2020-06-29T15:12:51.588+02:00| vcpu-0| I005: GuestRpc: Successfully created RPCI listening socket.
2020-06-29T15:12:51.588+02:00| vcpu-0| I005: GuestRpc: Using vsocket for TCLO messaging is disabled.
2020-06-29T15:12:51.588+02:00| vcpu-0| A000: ConfigDB: Unsetting all entries with prefix "usb:0."
2020-06-29T15:12:51.627+02:00| vcpu-0| I005: USB: Disconnecting device 0x2000000400000000
2020-06-29T15:12:51.627+02:00| vcpu-0| I005: USB: Connecting device desc:name:VMware\ Virtual\ USB\ Mouse vid:0e0f pid:0003 speed:full family:hid deviceType:virtual-hid info:0000005 version:3 id:0x200000050e0f0003
2020-06-29T15:12:51.627+02:00| vcpu-0| I005: Policy_GetUSBDevAccess: allowConnect = YES
2020-06-29T15:12:51.627+02:00| vcpu-0| A000: ConfigDB: Setting usb:0.present = "TRUE"
2020-06-29T15:12:51.627+02:00| vcpu-0| A000: ConfigDB: Setting usb:0.deviceType = "hid"
2020-06-29T15:12:51.627+02:00| vcpu-0| A000: ConfigDB: Setting usb:0.port = "0"
2020-06-29T15:12:51.627+02:00| vcpu-0| A000: ConfigDB: Setting usb:0.parent = "-1"
2020-06-29T15:12:51.662+02:00| vcpu-0| I005: memoryHotplug: Node 0: Present: 767 MB (100 %) Size:3071 MB (100 %)
2020-06-29T15:12:51.662+02:00| vcpu-0| I005: PIIX4: PM Resuming from suspend type 0x0, chipset.onlineStandby 0
2020-06-29T15:12:51.684+02:00| vcpu-0| I005: VNET: 'ethernet0' enable link state propagation, lsp.state = 5
2020-06-29T15:12:51.684+02:00| vcpu-0| I005: VNET: MACVNetConnectToNetwork 'ethernet0' lsp.state = 4
2020-06-29T15:12:51.684+02:00| vcpu-0| I005: VNET: MACVNetConnectToNetwork 'Ethernet0' notify available.
2020-06-29T15:12:51.689+02:00| vcpu-0| I005: CDROM: Connecting ide1:0 to '/home/pheiduck/Downloads/archlinux-2020.06.01-x86_64.iso'. type=2 remote=0
2020-06-29T15:12:51.689+02:00| vcpu-0| I005: DMG_Open: Not an unencrypted .dmg file (footer signature 0x45464920).
2020-06-29T15:12:51.689+02:00| vcpu-0| I005: DMG_Close: max cached entries 8
2020-06-29T15:12:51.689+02:00| vcpu-0| I005: CDROM: Checking initial physical media state...
2020-06-29T15:12:51.689+02:00| vcpu-0| I005: CDROM:  initial physical CDROM state is 1 (sense)
2020-06-29T15:12:51.692+02:00| vcpu-0| I005: HGFSPublish: publishing 0 shares
2020-06-29T15:12:51.695+02:00| vcpu-0| I005: PolicyVMXFindPolicyKey: policy file does not exist.
2020-06-29T15:12:51.699+02:00| vcpu-0| I005: Vix: [mainDispatch.c:4200]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1872, success=1 additionalError=0
2020-06-29T15:12:51.699+02:00| vcpu-0| I005: Vix: [mainDispatch.c:4117]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=0, err=0).
2020-06-29T15:12:51.699+02:00| vcpu-0| I005: Vix: [mainDispatch.c:4117]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=2, err=0).
2020-06-29T15:12:51.699+02:00| vcpu-0| I005: Transitioned vmx/execState/val to poweredOn
2020-06-29T15:12:51.699+02:00| vcpu-0| I005: Tools: Adding Tools inactivity timer.
2020-06-29T15:12:51.707+02:00| vmx| I005: VUsbUpdateVigorFieldsAndAutoconnect: New set of 2 USB devices
2020-06-29T15:12:51.707+02:00| vmx| I005: USB: Found device [name:Cambridge\ Silicon\ Radio\ CSR8510\ A10 vid:0a12 pid:0001 path:3/2 speed:full family:wireless,bluetooth arbRuntimeKey:1 quirks:bluetooth version:3]
2020-06-29T15:12:51.707+02:00| vmx| I005: USB: Found device [name:Virtual\ Bluetooth\ Adapter vid:0e0f pid:0008 speed:full family:wireless,bluetooth deviceType:virtual-bluetooth info:0000001 version:3]
2020-06-29T15:12:51.709+02:00| vcpu-0| I005: AMD-V enabled.
2020-06-29T15:12:51.735+02:00| vmx| I005: serial0: try 0 failed to connect to the socket with error 2: No such file or directory
2020-06-29T15:12:51.735+02:00| vmx| I005: VNET: MACVNetLinkStateEventHandler: event, up:1, adapter:1
2020-06-29T15:12:51.735+02:00| vmx| I005: VNET: MACVNetLinkStateEventHandler: 'ethernet0' state from 4 to 6.
2020-06-29T15:12:51.788+02:00| vmx| I005: USB: Connecting device desc:name:Virtual\ Bluetooth\ Adapter vid:0e0f pid:0008 speed:full family:wireless,bluetooth deviceType:virtual-bluetooth info:0000001 version:3 id:0x700000010e0f0008
2020-06-29T15:12:51.788+02:00| vmx| I005: Policy_GetUSBDevAccess: checking usb devices at policy path: /vm/#_VMX/mvm/policyState/val/policySet/usbDevices/#
2020-06-29T15:12:51.788+02:00| vmx| I005: Policy_GetUSBDevAccess: allowConnect = YES
2020-06-29T15:12:51.789+02:00| vmx| I005: VUsbUpdateVigorFieldsAndAutoconnect: New set of 2 USB devices
2020-06-29T15:12:51.789+02:00| vmx| I005: USB: Found device [name:Cambridge\ Silicon\ Radio\ CSR8510\ A10 vid:0a12 pid:0001 path:3/2 speed:full family:wireless,bluetooth arbRuntimeKey:1 quirks:bluetooth version:3]
2020-06-29T15:12:51.789+02:00| vmx| I005: USB: Found device [name:Virtual\ Bluetooth\ Adapter vid:0e0f pid:0008 speed:full family:wireless,bluetooth virtPath:usb:2 deviceType:virtual-bluetooth info:0000001 version:3], connected to usb:1 port 0.
2020-06-29T15:12:51.891+02:00| vcpu-0| I005: UHCI: HCReset
2020-06-29T15:12:51.914+02:00| mks| I005: MKSControlMgr: connected
2020-06-29T15:12:51.947+02:00| mks| I005: SWBWindow: Number of MKSWindows changed: 1 rendering MKSWindow(s) of total 1.
2020-06-29T15:12:51.948+02:00| mks| I005: MKSXInput: XI major version 2, minor version 3
2020-06-29T15:12:51.948+02:00| mks| I005: XINFO X fd is 17
2020-06-29T15:12:51.949+02:00| mks| I005: XINFO depth 24 bpp 32 class 4
2020-06-29T15:12:51.949+02:00| mks| I005: XINFO  ServerVendor: "The X.Org Foundation"
2020-06-29T15:12:51.949+02:00| mks| I005: XINFO VendorRelease: 12008000
2020-06-29T15:12:51.951+02:00| mks| I005: XINFO XKB available, version 1.0
2020-06-29T15:12:51.951+02:00| mks| I005: XINFO XTEST available, version 2.2
2020-06-29T15:12:51.951+02:00| mks| I005: XINFO Xinerama available
2020-06-29T15:12:51.951+02:00| mks| I005: XKeymap_PowerOn: use evdev keycode mapping.
2020-06-29T15:12:51.951+02:00| mks| I005: X11-Backend: successfully started by HWinMux to do window composition.
2020-06-29T15:12:51.951+02:00| mks| I005: X11-Backend: XINFO SHM available, version 1.2, shared pixmaps
2020-06-29T15:12:51.953+02:00| mks| I005: MKS-HWinMux: Started X11 presentation backend
2020-06-29T15:12:52.021+02:00| mks| I005: SWBWindow: Number of MKSWindows changed: 0 rendering MKSWindow(s) of total 1.
2020-06-29T15:12:52.027+02:00| mks| I005: SWBWindow: Number of MKSWindows changed: 1 rendering MKSWindow(s) of total 1.
2020-06-29T15:12:52.092+02:00| mks| I005: SWBWindow: Number of MKSWindows changed: 1 rendering MKSWindow(s) of total 2.
2020-06-29T15:12:52.097+02:00| vcpu-0| I005: SVGA: Registering MemSpace at 0xe8000000(0x0) and 0xfe000000(0x0)
2020-06-29T15:12:52.097+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:52.104+02:00| vcpu-0| I005: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2020-06-29T15:12:52.104+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:52.326+02:00| vmx| I005: VNET: MACVNetLinkStateTimerHandler: 'ethernet0' state from 6 to 1.
2020-06-29T15:12:52.366+02:00| vcpu-0| I005: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2020-06-29T15:12:52.366+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:52.375+02:00| vcpu-0| I005: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2020-06-29T15:12:52.375+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:52.375+02:00| vcpu-0| I005: SVGA: Registering IOSpace at 0x1070
2020-06-29T15:12:52.375+02:00| vcpu-0| I005: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2020-06-29T15:12:52.379+02:00| vcpu-0| I005: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.380+02:00| vcpu-0| I005: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.380+02:00| vcpu-0| I005: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.381+02:00| vcpu-0| I005: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.381+02:00| vcpu-0| I005: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.381+02:00| vcpu-0| I005: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.382+02:00| vcpu-0| I005: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.382+02:00| vcpu-0| I005: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.382+02:00| vcpu-0| I005: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.383+02:00| vcpu-0| I005: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.391+02:00| vcpu-0| I005: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.391+02:00| vcpu-0| I005: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.392+02:00| vcpu-0| I005: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.392+02:00| vcpu-0| I005: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.392+02:00| vcpu-0| I005: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.393+02:00| vcpu-0| I005: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.393+02:00| vcpu-0| I005: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.393+02:00| vcpu-0| I005: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.394+02:00| vcpu-0| I005: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.394+02:00| vcpu-0| I005: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.394+02:00| vcpu-0| I005: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.396+02:00| vcpu-0| I005: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.396+02:00| vcpu-0| I005: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.397+02:00| vcpu-0| I005: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.397+02:00| vcpu-0| I005: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.397+02:00| vcpu-0| I005: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.398+02:00| vcpu-0| I005: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.398+02:00| vcpu-0| I005: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.398+02:00| vcpu-0| I005: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.399+02:00| vcpu-0| I005: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.399+02:00| vcpu-0| I005: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.399+02:00| vcpu-0| I005: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.461+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:52.479+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:52.759+02:00| vcpu-0| I005: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.759+02:00| vcpu-0| I005: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.760+02:00| vcpu-0| I005: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.760+02:00| vcpu-0| I005: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.760+02:00| vcpu-0| I005: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.761+02:00| vcpu-0| I005: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.761+02:00| vcpu-0| I005: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.762+02:00| vcpu-0| I005: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.762+02:00| vcpu-0| I005: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.762+02:00| vcpu-0| I005: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.763+02:00| vcpu-0| I005: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.763+02:00| vcpu-0| I005: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.763+02:00| vcpu-0| I005: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.764+02:00| vcpu-0| I005: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.764+02:00| vcpu-0| I005: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.764+02:00| vcpu-0| I005: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.765+02:00| vcpu-0| I005: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.765+02:00| vcpu-0| I005: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.766+02:00| vcpu-0| I005: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.766+02:00| vcpu-0| I005: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.766+02:00| vcpu-0| I005: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.767+02:00| vcpu-0| I005: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.767+02:00| vcpu-0| I005: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.767+02:00| vcpu-0| I005: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.776+02:00| vcpu-0| I005: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.776+02:00| vcpu-0| I005: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.777+02:00| vcpu-0| I005: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.777+02:00| vcpu-0| I005: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.778+02:00| vcpu-0| I005: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.778+02:00| vcpu-0| I005: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.778+02:00| vcpu-0| I005: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.788+02:00| vcpu-0| I005: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2020-06-29T15:12:52.808+02:00| vcpu-0| I005: DISKUTIL: scsi0:0 : geometry=10443/255/63
2020-06-29T15:12:52.808+02:00| vcpu-0| I005: DISKUTIL: scsi0:0 : capacity=167772160 logical sector size=512
2020-06-29T15:12:53.621+02:00| vcpu-0| I005: BIOS-UUID is 56 4d ce d1 39 69 13 90-28 b8 81 c4 9a f0 91 b8
2020-06-29T15:12:54.722+02:00| vcpu-0| I005: SVGA: FIFO is already mapped
2020-06-29T15:12:54.722+02:00| svga| I005: SVGA enabling SVGA
2020-06-29T15:12:54.881+02:00| svga| I005: SVGA-ScreenMgr: Screen type changed to RegisterMode
2020-06-29T15:12:54+02:00[+0.000]| svga| W003: Caught signal 4 -- tid 74501 (addr 55F129BE30A0)
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: rip 0x55f129be30a0 rsp 0x7fa4bdf60870 rbp 0x0
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: rax 0x0 rbx 0x0 rcx 0x1 rdx 0x7fa4c5342ea0 rsi 0x0 rdi 0x7fa4bdf608fc
2020-06-29T15:12:54+02:00[+0.000]| svga| I005:         r8 0x0 r9 0x7fa47c03b508 r10 0x280 r11 0x0 r12 0x55f12aa74ba0 r13 0x0 r14 0x0 r15 0x0
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF60870 : 0x0000000000000000 0x0000000000000000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF60880 : 0x000055f12aa74ba0 0x000055f12aa74ba0
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF60890 : 0x00007fa4bdf608fc 0x000000000000014b
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF608A0 : 0x0000000000000000 0x000055f129c85f14
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF608B0 : 0x0000000000000001 0x000055f12aa74ba0
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF608C0 : 0x000055f12aa74ba0 0x00007fa4c5342ea0
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF608D0 : 0x0000000000000000 0x000055f129c011ac
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SIGNAL: stack 7FA4BDF608E0 : 0x0000000000000000 0x00007fa4bdf608fc
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace:
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[0] 00007fa4bdf60150 rip=000055f12a00f516 rbx=0000000000000000 rbp=000055f12a00f120 r12=00007fa4bdf60160 r13=00007fa4bdf6014c r14=00007fa4bdf608f0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[1] 00007fa4bdf601b0 rip=000055f12a147a45 rbx=0000000000000004 rbp=00007fa4bdf608f0 r12=00000000000003e8 r13=000055f12a419828 r14=00007fa4bdf608f0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[2] 00007fa4bdf603b0 rip=000055f12a148797 rbx=000055f12aa65ae8 rbp=0000000000000004 r12=00007fa4bdf60530 r13=00007fa4bdf60400 r14=00007fa4bdf611d0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[3] 00007fa4bdf60400 rip=00007fa4c6b30960 rbx=0000000000000000 rbp=0000000000000000 r12=000055f12aa74ba0 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[4] 00007fa4bdf60870 rip=000055f129be30a0 rbx=0000000000000000 rbp=0000000000000000 r12=000055f12aa74ba0 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[5] 00007fa4bdf608b0 rip=000055f129c85f14 rbx=000055f12aa74ba0 rbp=000055f12aa74ba0 r12=00007fa4bdf608fc r13=000000000000014b r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[6] 00007fa4bdf608e0 rip=000055f129c011ac rbx=000055f12aa74ba0 rbp=00007fa4c5342ea0 r12=0000000000000000 r13=000000000000014b r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[7] 00007fa4bdf60950 rip=000055f129faa2d5 rbx=00007fa4bdf60950 rbp=00007fa468000be0 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[8] 00007fa4bdf60a80 rip=00007fa4c6b25422 rbx=0000000000000000 rbp=0000000000000000 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[9] 00007fa4bdf60b40 rip=00007fa4c6a52bf3 rbx=00007fa4bdf64700 rbp=0000000000000000 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: Backtrace[10] 00007fa4bdf60b48 rip=0000000000000000 rbx=00007fa4bdf64700 rbp=0000000000000000 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[0] 00007fa4bdf60150 rip=000055f12a00f544 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[1] 00007fa4bdf601b0 rip=000055f12a147a45 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[2] 00007fa4bdf603b0 rip=000055f12a148797 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[3] 00007fa4bdf60400 rip=00007fa4c6b30960 in function (null) in object /usr/lib/libpthread.so.0 loaded at 00007fa4c6b1c000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[4] 00007fa4bdf60870 rip=000055f129be30a0 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[5] 00007fa4bdf608b0 rip=000055f129c85f14 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[6] 00007fa4bdf608e0 rip=000055f129c011ac in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[7] 00007fa4bdf60950 rip=000055f129faa2d5 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[8] 00007fa4bdf60a80 rip=00007fa4c6b25422 in function (null) in object /usr/lib/libpthread.so.0 loaded at 00007fa4c6b1c000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[9] 00007fa4bdf60b40 rip=00007fa4c6a52bf3 in function clone in object /usr/lib/libc.so.6 loaded at 00007fa4c6953000
2020-06-29T15:12:54+02:00[+0.000]| svga| I005: SymBacktrace[10] 00007fa4bdf60b48 rip=0000000000000000
2020-06-29T15:12:54+02:00[+0.000]| svga| E001: PANIC: Unexpected signal: 4.
2020-06-29T15:12:54+02:00[+0.000]| svga| W003+ Attempting a core dump using an unlimited size limit
2020-06-29T15:12:54+02:00[+1.661]| svga| W003: Core dumped.
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Core dump pipes to process /usr/lib/systemd/systemd-coredump %P %u %g %s %t %c %h, core file unreliable
2020-06-29T15:12:54+02:00[+1.661]| svga| W003: A core file is available in "/run/media/pheiduck/DATA/vmware/AL64bit/core.74516"
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace:
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[0] 00007fa4bdf5fc50 rip=000055f12a00f516 rbx=0000000000000000 rbp=000055f12a00f120 r12=00007fa4bdf5fc60 r13=00007fa4bdf5fc4c r14=00007fa4bdf608f0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[1] 00007fa4bdf5fcb0 rip=000055f129a8801d rbx=00007fa4bdf5fcd0 rbp=000055f12aa72008 r12=0000000000000001 r13=000055f12a419828 r14=00007fa4bdf608f0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[2] 00007fa4bdf601b0 rip=000055f12a147b91 rbx=0000000000000004 rbp=00007fa4bdf602e0 r12=00000000000003e8 r13=000055f12a419828 r14=00007fa4bdf608f0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[3] 00007fa4bdf603b0 rip=000055f12a148797 rbx=000055f12aa65ae8 rbp=0000000000000004 r12=00007fa4bdf60530 r13=00007fa4bdf60400 r14=00007fa4bdf611d0 r15=000000000000000b
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[4] 00007fa4bdf60400 rip=00007fa4c6b30960 rbx=0000000000000000 rbp=0000000000000000 r12=000055f12aa74ba0 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[5] 00007fa4bdf60870 rip=000055f129be30a0 rbx=0000000000000000 rbp=0000000000000000 r12=000055f12aa74ba0 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[6] 00007fa4bdf608b0 rip=000055f129c85f14 rbx=000055f12aa74ba0 rbp=000055f12aa74ba0 r12=00007fa4bdf608fc r13=000000000000014b r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[7] 00007fa4bdf608e0 rip=000055f129c011ac rbx=000055f12aa74ba0 rbp=00007fa4c5342ea0 r12=0000000000000000 r13=000000000000014b r14=0000000000000000 r15=0000000000000000
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[8] 00007fa4bdf60950 rip=000055f129faa2d5 rbx=00007fa4bdf60950 rbp=00007fa468000be0 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[9] 00007fa4bdf60a80 rip=00007fa4c6b25422 rbx=0000000000000000 rbp=0000000000000000 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[10] 00007fa4bdf60b40 rip=00007fa4c6a52bf3 rbx=00007fa4bdf64700 rbp=0000000000000000 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: Backtrace[11] 00007fa4bdf60b48 rip=0000000000000000 rbx=00007fa4bdf64700 rbp=0000000000000000 r12=00007ffe1c274dde r13=00007ffe1c274ddf r14=00007ffe1c274f70 r15=00007fa4bdf64700
2020-06-29T15:12:54+02:00[+1.661]| svga| I005: SymBacktrace[0] 00007fa4bdf5fc50 rip=000055f12a00f544 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[1] 00007fa4bdf5fcb0 rip=000055f129a8801d in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[2] 00007fa4bdf601b0 rip=000055f12a147b91 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[3] 00007fa4bdf603b0 rip=000055f12a148797 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[4] 00007fa4bdf60400 rip=00007fa4c6b30960 in function (null) in object /usr/lib/libpthread.so.0 loaded at 00007fa4c6b1c000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[5] 00007fa4bdf60870 rip=000055f129be30a0 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[6] 00007fa4bdf608b0 rip=000055f129c85f14 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[7] 00007fa4bdf608e0 rip=000055f129c011ac in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[8] 00007fa4bdf60950 rip=000055f129faa2d5 in function (null) in object /usr/lib/vmware/bin/vmware-vmx loaded at 000055f12999f000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[9] 00007fa4bdf60a80 rip=00007fa4c6b25422 in function (null) in object /usr/lib/libpthread.so.0 loaded at 00007fa4c6b1c000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[10] 00007fa4bdf60b40 rip=00007fa4c6a52bf3 in function clone in object /usr/lib/libc.so.6 loaded at 00007fa4c6953000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: SymBacktrace[11] 00007fa4bdf60b48 rip=0000000000000000
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: Printing loaded objects
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x55F12999F000-0x55F12A5E1722): /usr/lib/vmware/bin/vmware-vmx
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FFE1C377000-0x7FFE1C377C2C): linux-vdso.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C7004000-0x7FA4C70061F0): /usr/lib/librt.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6FFE000-0x7FA4C6FFF000): /usr/lib/libdl.so.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6EBD000-0x7FA4C6ED8200): /usr/lib/libX11.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6EA8000-0x7FA4C6EAB4B0): /usr/lib/libXext.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6E95000-0x7FA4C6E970B8): /usr/lib/libXi.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6E90000-0x7FA4C6E90A78): /usr/lib/libXinerama.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6E82000-0x7FA4C6E844A0): /usr/lib/libXcursor.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6E7A000-0x7FA4C6E7B2E8): /usr/lib/libXtst.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6C9D000-0x7FA4C6D32AA8): /usr/lib/libstdc++.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6B58000-0x7FA4C6B66478): /usr/lib/libm.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6B3E000-0x7FA4C6B40928): /usr/lib/libgcc_s.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6B1C000-0x7FA4C6B22AF0): /usr/lib/libpthread.so.0
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6953000-0x7FA4C6977970): /usr/lib/libc.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C7049000-0x7FA4C704A0F8): /lib64/ld-linux-x86-64.so.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6929000-0x7FA4C6934B90): /usr/lib/libxcb.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C691C000-0x7FA4C691D818): /usr/lib/libXrender.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6913000-0x7FA4C69143D0): /usr/lib/libXfixes.so.3
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C690E000-0x7FA4C690EBE8): /usr/lib/libXau.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C6904000-0x7FA4C6905260): /usr/lib/libXdmcp.so.6
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C5F55000-0x7FA4C61E28AC): /usr/lib/vmware/lib/libcrypto.so.1.0.2/libcrypto.so.1.0.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C5CE2000-0x7FA4C5D497D4): /usr/lib/vmware/lib/libssl.so.1.0.2/libssl.so.1.0.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C5CCE000-0x7FA4C5CD0640): /usr/lib/libnss_files.so.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C5396000-0x7FA4C5398E30): /usr/lib/libnuma.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C701D000-0x7FA4C701D740): /usr/lib/libaio.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF4B1000-0x7FA4BF4BD248): /usr/lib/libpulse.so
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF42D000-0x7FA4BF440F08): /usr/lib/pulseaudio/libpulsecommon-13.0.so
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF3E2000-0x7FA4BF3EF100): /usr/lib/libdbus-1.so.3
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF366000-0x7FA4BF36C118): /usr/lib/libsndfile.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF2BB000-0x7FA4BF2CC428): /usr/lib/libsystemd.so.0
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C5334000-0x7FA4C5335028): /usr/lib/libasyncns.so.0
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF27C000-0x7FA4BF284A60): /usr/lib/libFLAC.so.8
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF271000-0x7FA4BF272778): /usr/lib/libogg.so.0
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF243000-0x7FA4BF246190): /usr/lib/libvorbis.so.0
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF198000-0x7FA4BF1AB9A8): /usr/lib/libvorbisenc.so.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF170000-0x7FA4BF172D18): /usr/lib/liblzma.so.5
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF14E000-0x7FA4BF150048): /usr/lib/liblz4.so.1
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF030000-0x7FA4BF03B9D0): /usr/lib/libgcrypt.so.20
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BF016000-0x7FA4BF019CE0): /usr/lib/libresolv.so.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BEFEF000-0x7FA4BEFF3280): /usr/lib/libgpg-error.so.0
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4BDA4E000-0x7FA4BDA7A5C8): /usr/lib/libasound.so.2
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: [0x7FA4C702D000-0x7FA4C702EF18): /usr/lib/alsa-lib/libasound_module_pcm_pulse.so
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: End printing loaded objects
2020-06-29T15:12:54+02:00[+1.662]| svga| I005: Panic: panic from signal, skipping monitor coredump.
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: Msg_Post: Error
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: [msg.log.error.unrecoverable] VMware Workstation unrecoverable error: (svga)
2020-06-29T15:12:54+02:00[+1.666]| svga| I005+ Unexpected signal: 4.
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: [msg.panic.haveLog] A log file is available in "/run/media/pheiduck/DATA/vmware/AL64bit/vmware.log".
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: [msg.panic.requestSupport.withoutLog] You can request support.
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: [msg.panic.requestSupport.vmSupport.windowsOrLinux]
2020-06-29T15:12:54+02:00[+1.666]| svga| I005+ To collect data to submit to VMware support, choose "Collect Support Data" from the Help menu.
2020-06-29T15:12:54+02:00[+1.666]| svga| I005+ You can also run the "vm-support" script in the Workstation folder directly.
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: [msg.panic.response] We will respond on the basis of your support entitlement.
2020-06-29T15:12:54+02:00[+1.666]| svga| I005: ----------------------------------------
2020-06-29T15:12:54+02:00[+19.310]| svga| I005: Exiting
That is a pretty vague error. It is working fine for me in Arch. I can reboot into Manjaro to test it there but probably not until tonight when I finish work.
That is quite normal - Arch and thereby Manjaro is completely unsupported.
This is FUD. Just because it isn't officially supported doesn't mean it doesn't work. I have been using vmware-workstation on Manjaro for more than 2 years without a single interruption.
Please - I didn't say it doesn't work - referring that Arch and Manjaro is unsupported is not FUD but a fact.
I said it is normal if it doesn't - this often somtimes happens after an update.
So it is a Cat and Mouse Fight :smiley:
... it would be nice if vmware support it official :slight_smile: but this will be a lot of hustle :smiley:
you don't need to @linux-aarhus
Nope - I am not fighting ...
Right. That is the FUD part. I have never had it not work after any update. Since the AUR package was patched and switched to using a dkms module it has been flawless. This used to be a problem years ago but hasn't been for a long time.
any news @dalto?
Sorry. I forgot to test it last night. So I did it just now.
That being said, I am not sure how helpful it will be. After updating, I tested with 3 different kernels. 2 in stable and 1 after switching to unstable:
5.4.44-1 - Worked fine.
5.7.0-3 - No problems.
5.7.6-1 - Issue free.
I did a little poking around for that error and there are a lot of references to it. Most were tied to video drivers and/or 3d acceleration being enabled in the VM. I tested with both 3D acceleration on and off in the VMs and had no issue but my graphics hardware is a bit newer than yours.
Okay, this take me in the Place That I have to buy new hardware. - But other than that thanks a lot for testing it :+1: @dalto
Err....maybe. It could also be driver related or something else altogether.
I would hate to see you buy new hardware and still have the same issue. On the other hand, if you were looking for an excuse to upgrade......
All good, It is on my list to upgrade my hardware because it comes to the limit, in some Workflows. - little update version 14 works :slight_smile:
This is okay for now, until I have my new hardware.
Seems to be my CPU is not supported on the latest version
