is there any proper guide to install waydroid in manjaro desktop and run android app
There’s an AUR (Arch User Repository) package, but I haven’t been able to get it to work properly yet.
It will only work on a Wayland session (hence the name), mind you. After installing, start the init process:
sudo waydroid init
Then start the container service:
systemctl start waydroid-container
There are menu shortcuts for preinstalled apps like Android Settings, etc. You can install x86_64 (possibly noarch?) APK’s with:
waydroid app install xyz.apk
See https://docs.waydro.id/ for more info.
did you try to install some app and which had worked for you
did you get waydroid working? if so pls help me out
yes , i was able to get waydroid to run perfectly in manjaro kde wayland session
ow i think i should just change to kde and try my luck it isnt working on xfce tnx.
you can try to install Weston a Wayland session for xfce it should fit your requirement
