Hello
I am sure I saw this somewhere in the settings, but I can’t find it now
I want to pin certain apps to a particular Workspace.
I do not know if this is not visible now because I removed from the panel the section of currently open apps (and have the indicator of an open app in the dock - like on my macOS), but I can’t find it in Workspaces.
Right click on the app’s bar gives me option to move it to another Workspace, but not to pin/assign it.
Any hints how to do this in the Manjaro settings (I understand, that in terminal I can do it, but I am searching for the GUI solution).
Thanks in advance
I don’t think that feature is available in xfwm4.
You may need to use another window manager for that. I think i3 and awesome have that feature, there may be more.
I am using XFCE and like it, so neither i3 or Awesome are an option.
Does this mean that I can’t assign apps to open only in certain workspaces?
I did that before I asked And did search on the net. No luck on both
In XFCE, I believe you need to use wmctrl or similar.
Thanks for info
Check out devilspie at this link
https://gist.github.com/torgeir/401084929e678640b0cd36b3c92b5f0
maybe that will work for you.
thanks - issue is: 404. Page not found
