Wait, did pacman -Syyu
successfully complete and update all packages?
yes
:: Starting full system upgrade…
there is nothing to do
Here’s what my linux510.preset looks like. It’s fairly standard across most installations:
# mkinitcpio preset file for the 'linux510' package
ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-5.10-x86_64"
PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-5.10-x86_64.img"
#default_options=""
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-5.10-x86_64-fallback.img"
fallback_options="-S autodetect"
You can create that file (while in chroot) under /etc/mkinitcpio.d/linux510.preset
I’m getting worried though. There’s quite a lot that isn’t working ever since you lost power during the update.
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘default’
→ -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> ERROR: specified kernel image does not exist: /boot/vmlinuz-5.10-x86_64' ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback' -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect ==> ERROR: specified kernel image does not exist:
/boot/vmlinuz-5.10-x86_64’
when I run mhwd-kernel -li
it happens:
Currently running: 5.10.34-1-MANJARO (linux510)
error: could not open file /var/lib/pacman/local/python-cryptography-3.4.8-2/desc: No such file or directory
- linux510
Unless someone more versed knows otherwise, something appears to have really borked on your system.
Sudden power loss can cause unpredictable and “scattered” issues, especially during a system update.
At this point, personally, I would re-install from scratch, and import my /home/username/ data.
It sounds like you had your home folder on the same partition as the root system?
Do you have an extra drive, such as an external USB, that you can temporarily transfer your entire /home/username/ directory?
After which you can reinstall Manjaro from scratch and then re-transfer your home folder back to the internal HDD/SSD.
In the chroot, what are the contents of /boot and /boot/efi ?
sh-5.1# cd boot
efi grub intel-ucode.img linux510-x86_64.kver memtest86+
sh-5.1# cd efi
sh-5.1# ls
EFI
What about,
pacman -Q linux510
sh-5.1# pacman -Q linux510
linux510 5.10.63-1
What happens if you clear the cache then try to force-reinstall linux510?
pacman -Scc
pacman -S linux510
sh-5.1# pacman -Scc
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N] y
removing all files from cache...
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] y
removing unused sync repositories...
sh-5.1# pacman -S linux510
warning: downgrading package linux510 (5.10.63-1 => 5.10.61-1)
resolving dependencies...
Packages (1) linux510-5.10.61-1
Total Download Size: 73.84 MiB
Total Installed Size: 78.23 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
linux510-5.10.61... 73.8 MiB 6.34 MiB/s 00:12 [##################] 100%
error: failed retrieving file 'linux510-5.10.61-1-x86_64.pkg.tar.zst.sig' from manjaro.re : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
@nihilistkaaos Try this:
- Remove this directory:
sudo rm -R /var/lib/pacman/local/python-cryptography-3.4.8-2/
(it is part of the database anyway, which will be updated)
- Retrieve a new mirrorlist:
sudo pacman-mirrors -c Germany && sudo pacman-mirrors -f 5
(replace Germany with your country)
- Update the database and upgrade:
sudo pacman -Syyuu
- Reinstall everything:
export pkg=( $(pacman -Qq) )
echo ${pkg[@]}
sudo pacman -S ${pkg[@]}
Total Download Size: 294.31 MiB
Total Installed Size: 1271.07 MiB
Net Upgrade Size: 298.80 MiB
linux510-5.10.61-1-x86_64 is up to date
Total ( 1/80) 294.3 MiB 9.58 GiB/s 00:00 [##################] 100%
Is your internet connection working?
ping -4 -c1 manjaro.re
I had not changed the country in the pacman mirrors command
now updated
this command returns error
warning: zlib-1:1.2.11-4 is up to date -- reinstalling
error: target not found: 1:1.2.11-4
warning: zsh-5.8-1 is up to date -- reinstalling
error: target not found: 5.8-1
warning: zsh-autosuggestions-0.7.0-1 is up to date -- reinstalling
error: target not found: 0.7.0-1
warning: zsh-completions-0.33.0-1 is up to date -- reinstalling
error: target not found: 0.33.0-1
warning: zsh-history-substring-search-1.0.2-1 is up to date -- reinstalling
error: target not found: 1.0.2-1
warning: zsh-syntax-highlighting-0.7.1-1 is up to date -- reinstalling
error: target not found: 0.7.1-1
warning: zsh-theme-powerlevel10k-1.15.0-2 is up to date -- reinstalling
error: target not found: 1.15.0-2
warning: zstd-1.5.0-1 is up to date -- reinstalling
error: target not found: 1.5.0-1
warning: zvbi-0.2.35-4 is up to date -- reinstalling
error: target not found: 0.2.35-4
warning: zxing-cpp-1.2.0-1 is up to date -- reinstalling
error: target not found: 1.2.0-1
warning: zziplib-0.13.72-1 is up to date -- reinstalling
error: target not found: 0.13.72-1
upps sorry… i forgot to add quiet:
corrected above
reinstalled. now i run exit and reboot?
Check first if the file is there now:
ls /boot
There must be the file available. Then I guess you can reboot.
