New on linux so i dont know what information should be provided but when moving my mouse on the desktop its the screen jitters it stops in most apps except firefox it also works well with the serch menu up
Run the command:
$ inxi -Fazy
And paste the output followind this post: How to provide good information
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=be6839b9-85cc-487c-9d69-2e4601a02c85 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: Z370 GAMING PLUS (MS-7B61) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.20 date: 12/20/2017
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB
bogomips: 88824
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1b80
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
Device-3: Razer USA Kraken Tournament Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2 chip ID: 1532:0520
serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 24.69 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 71E0
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: A750
ID-1: / raw size: 223.27 GiB size: 218.77 GiB (97.98%)
used: 19.64 GiB (9.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 21%
Processes: 310 Uptime: 5h 09m wakeups: 0 Memory: 15.6 GiB
used: 4.95 GiB (31.8%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1225 pacman: 1218 lib: 406 flatpak: 5 snap: 2 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.2.02
