Vlc: codec undf for the subtitles
Hi,
Since the latest’s updates (and kernel 518 to 519), I have an issue with the subtitles in vlc.
vlc say for all sub files :
Codec : undf
And the subs are not displayed.
I installed vlc flatpack, with it there is no issue with the subs.
How do I find and fix the problem?
Probably related to this.
if this is the issue you will have to wait for vlc 3.0.17.4-9
Try this
sudo pacman -U https://archlinux.org/packages/extra/x86_64/vlc/download/
The latest update with vlc 3.0.17.4-9 does fix the issue.
